Like Tree4Likes
 Old 05-10-2011, 05:10 PM   #1
jwilson0514's Avatar
Posts: 54   (View Stats)
jwilson0514 has a spectacular aura aboutjwilson0514 has a spectacular aura aboutjwilson0514 has a spectacular aura about
Default DSC off or on? While driving spirited or hard luanching?
Ok I have looked all over the forums for this topic and having trouble finding a solid answer. I also have mixed reviews about people opinions about it. So is DSC supposed to be on while spirited driving or hard launching or off? Cause I know I have hard launched before with DSC on and wow thought I was gonna lose control of the vehicle. Also read that it could damage the vehicle while hard launching or racing with DSC on? Lol cant find a solid answer. Comments concerns or thoughts? Thanks.
jwilson0514 is offline   Reply With Quote
 Old 05-10-2011, 05:18 PM   #2
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
If your tires spin and DSC is on it will correct the problem itself by applying the brakes to which ever side is spinning.
With it off your tires are free to do what your right foot tells them to do.
Its your choice do what you want.
The Following User Says Thank You to manelscout4life For This Useful Post:
jwilson0514 (05-10-2011)
 Old 05-10-2011, 05:23 PM   #3
dizzin9's Avatar
Posts: 1,807   (View Stats)
Groans: 77
with the car off, hold dsc then start the vehicle.
enjoy.
The Following 5 Users Say Thank You to dizzin9 For This Useful Post:
Alpha (06-29-2011), Juyoung (09-23-2013), jwilson0514 (05-10-2011), PunjabiPlaya (05-10-2011), xhymer (06-11-2011)
 Old 05-10-2011, 05:35 PM   #4
blakkat's Avatar
Posts: 572   (View Stats)
blakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the worldblakkat is the leader of the world
enjoy.
ive read about this, does it work on genpu's?
2011 black mica ms3.
Mods:
mounts- jbr 80duro rmm, jbr 80duro trans mount
engine- sure aeros,cs tip, forge v1 bpv, autotec internals,cnt catless dp, dizzy tuned
shift- sure shortcut, countershift, anchors
looks- ddm 6000k lows, 3000k fogs, rally armour mud flaps, cs led kit
blakkat is offline   Reply With Quote
 Old 05-10-2011, 05:43 PM   #5
Groans: 661
Neutral  +1 score
it makes no difference on the gen1 just an extra light lights up on the dash.
Nliiitend1 (05-10-2011)
 Old 05-10-2011, 05:45 PM   #6
CrystalShipMS3's Avatar
Posts: 40   (View Stats)
CrystalShipMS3 has a spectacular aura aboutCrystalShipMS3 has a spectacular aura aboutCrystalShipMS3 has a spectacular aura about
Groaned at 5 Times in 1 Post
If you're going to race someone turn it off. You're tires will spin but you'll have faster 1/4 mile times. Just donn't rev past 4k rpm when you drop the clutch or you'll liquify your tires.
As for "spirited driving" it really is just a matter of personal preference.
[SIGPIC]http://farm6.static.flickr.com/5129/5344538637_b922f03499.jpg[/SIGPIC]
that's my car...
CrystalShipMS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to CrystalShipMS3 For This Useful Post:
The Following 5 Users Say NO Thank You to CrystalShipMS3 For This Un-useful Post:
8.5MS3 (05-10-2011), cbusby (05-10-2011), drknyte (05-12-2011), manelscout4life (05-10-2011), silverspd3 (05-13-2011)
 Old 05-10-2011, 06:49 PM   #7
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
If you know how to drive, and I mean, really know, you'll be faster with it off.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 05-10-2011, 06:54 PM   #8
cbusby's Avatar
Posts: 156   (View Stats)
cbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond reputecbusby has a reputation beyond repute
Groaned at 10 Times in 1 Post
Originally Posted by CrystalShipMS3 View Post
It limits boost to something like 12 psi in 1st and 2nd gear.
That is most definitely not true. Gears 1 and 2 are limited to 10psi with DSC on or off. Get a boost gauge and watch. You can remove this limitation with an AP, SB, HT, etc.
2008 Mazdaspeed3 / Bolted (mostly) / Parting out.
cbusby is offline   Reply With Quote
The Following 2 Users Say Thank You to cbusby For This Useful Post:
CrystalShipMS3 (05-10-2011), Juyoung (09-23-2013)
 Old 05-10-2011, 06:54 PM   #9
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
my vote is for off.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
 Old 05-10-2011, 06:57 PM   #10
blakkat's Avatar
thought only gen2's did that
Mods:
 Old 05-10-2011, 06:59 PM   #11
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
1) Get in car
2) Start car
3) Plug in AP for live monitoring
4) Turn off dsc/tc
5) Drive
cbusby (05-10-2011)
 Old 05-10-2011, 07:00 PM   #12
cbusby's Avatar
Never driven a genpu, but I can assure you my 1st gen is limited that way.
 Old 05-10-2011, 07:08 PM   #13
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
OP you need the driver mod
quick easy way to tell you suck
1. go to autox4u.com
2. enroll in a local autox
3. attend said autox
4. do several runs with dsc on
5. do several runs with dsc off
the amount of extra time it took you to complete the course with dsc off is an indication that the computer is a better driver than you.
once you can reverse the time difference then you can drive with dsc off and actually have some sort of advantage
qkrthnu2 likes this.
The Following User Says Thank You to 8.5MS3 For This Useful Post:
blackrs99 (05-10-2011)
 Old 05-10-2011, 07:14 PM   #14
blakkat's Avatar
when i launch i have dsc off, and rev to 3000 and slip the clutch to avoid wheel spin, works like a charm.
Mods:
 Old 05-10-2011, 07:21 PM   #15
JNR5005's Avatar
Posts: 869   (View Stats)
JNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the worldJNR5005 is the leader of the world
Groaned at 9 Times in 9 Posts
My best track times have been with DSC on.
2008 Mazdaspeed3 GT
2.206 ~ 13.330 @ 107.98 MPH (I & AP only, DSC ON)
Cobb SRI | Cobb AP (Stage 2+ v200) | OBX TP | Hankook Ventus V12 Evos | Hawk HPSoftpenis Pads | Duplicolor Black Stock Wheels | 15% Tint | SuperRiceLEDs 9500k | SURE RMM Race | TRZ TMM | JBR PMM 80a | JBR Shifter Bushings | Fidanza Flywheel | Koni Sport Shocks
JNR5005 is offline   Reply With Quote
 Old 05-10-2011, 07:22 PM   #16
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
super_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the worldsuper_pablo_ is the leader of the world
dsc off. You will learn to be a better driver. Only time Id recommend dsc ON would be during rain. most of the time i have it on, but thats cause i dont care on a daily drive. When i wanna have fun in the city, making fast turns, i turn that shit off.
super_pablo_ is offline   Reply With Quote
 Old 05-10-2011, 07:42 PM   #17
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I never have DSC/TC on. Made it a habit to push the button when I start the car. I don't need the computer to tell me when I should be taking my foot off the happy pedal.
getoutandlive and Juyoung like this.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
jroc (06-11-2011), Juyoung (09-23-2013), MS3CB (08-22-2013), MSFer87 (06-11-2011)
 Old 05-10-2011, 07:43 PM   #18
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Neutral  -1 score
its second nature for me to hold the button while starting if somehow i forget i turn car back off and disable the torque control
 Old 05-10-2011, 07:46 PM   #19
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
Yah, same here. I always turn it off.
I have to remember to turn it on in the rain.
Beanfab / Tuned by Nishan
 Old 05-11-2011, 04:11 PM   #20
XLT_66's Avatar
Posts: 850   (View Stats)
XLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the worldXLT_66 is the leader of the world
What does holding the DSC during start up do?
Interested indeed....
2009 CWP MS3 Sport
Built Motor and Twinscroll T3 35r - 415WHP/400WTQ - 93 Pump Gas, No Meth - Mustang Dyno
Custom Tubular Manifold - HTP 3.5" Intake - 3" V-Band TBE - Custom COBB FMIC - COBB EBCS - COBB 44mm WG - KW V2 Coilovers
SOLD!
2008 Toyota Tacoma TRD Sport 4x4
XLT_66 is offline   Reply With Quote
 Old 05-11-2011, 04:15 PM   #21
cbusby's Avatar
Neutral  +1 score
Adds another annoying light in your cluster.
The Following 3 Users Say Thank You to cbusby For This Useful Post:
gtlaw (06-29-2011), MSFer87 (06-11-2011), Nliiitend1 (05-12-2011)
 Old 05-11-2011, 04:20 PM   #22
AegisKlein's Avatar
Posts: 209   (View Stats)
AegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the worldAegisKlein is the leader of the world
When stuck in the snow with summer tires, ensure that DSC if OFF or you will be stuck for awhile!
2011 MS3 Black Mica
Autotech Internals // Cobb AcessPORT (FREEKTUNEd) // CorkSport Racepipe; Springs; Camber Arms // Cp-e TMIC; SRI; TIP; RMM 75A // DDM 35W 6000K HIDs
Denso ITV22's // JBR SSP stage 2; Mud Flaps // Tenso-R Concept 9 rims // 35% Tint // OCC (Matt Damon) // Koni Yellow Sport
AegisKlein is offline   Reply With Quote
The Following User Says Thank You to AegisKlein For This Useful Post:
karl-hungus (06-11-2011)
 Old 05-11-2011, 05:15 PM   #23
Groans: 661
lol torque control?
What?
 Old 05-11-2011, 05:26 PM   #24
John's Avatar
Posts: 18   (View Stats)
John has much to be proud ofJohn has much to be proud ofJohn has much to be proud ofJohn has much to be proud ofJohn has much to be proud ofJohn has much to be proud ofJohn has much to be proud ofJohn has much to be proud ofJohn has much to be proud of
holding DSC down while turning the car on disables TC and SWAS (Steering Wheel Angle Sensor).
With just DSC off it turns off the TC in a straight line, but still kicks in when turning.
When I remember, I always turn DSC off off. I just hate the computer jumping in my fun. I actually drive in the rain with DSC off usually, makes starts more fun.
John is offline   Reply With Quote
The Following 3 Users Say Thank You to John For This Useful Post:
Alpha (06-29-2011), Juyoung (09-23-2013), MS3CB (08-22-2013)
The Following 2 Users Say NO Thank You to John For This Un-useful Post:
manelscout4life (05-11-2011), Nliiitend1 (05-12-2011)
 Old 05-11-2011, 05:41 PM   #25
Groans: 1,443
Holding down the DSC button at start up does not disable the SWAS.
It turns off the DSC (Dynamic Stability Control) and the TC (Traction Control)
gfather likes this.
The Following 3 Users Say Thank You to doubleflusher For This Useful Post:
gfather (06-11-2011), manelscout4life (05-11-2011), Tokay444 (05-11-2011)
 Old 05-11-2011, 06:30 PM   #26
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Holding it doesnt do anything for the gen 2, just press the button once the car is running. You can tell it is disabled by the light that comes on on your dash.
403whp/451ft/lb Dry Shot
 Old 05-11-2011, 07:46 PM   #27
AD_07's Avatar
Posts: 14   (View Stats)
AD_07 has a spectacular aura aboutAD_07 has a spectacular aura about
What (if any) difference does it make when "after" you have held the DSC button while starting the car, then, hold it again for another 10-15 seconds & the light disapperars of the dash??
Dont know if it resets or turns the DSC back on, or just gets rid of the dash light....
Any ideas...????
TXS SRI, GFB GT Hybrid BOV, Custom CBE, Hi-Flow 2nd Cat, TRZ Poly Mount, Cobb Springs.
AD_07 is offline   Reply With Quote
 Old 05-11-2011, 08:04 PM   #28
Tokay444's Avatar
Groans: 793
It won't let you use the button at all until you turn the car off, and k know for a fact that tcs is turned back on because when I was testing it out, my from brakes grabbed HARD when I was spinning in first. My seatbelt locked on me I flew forward so hard.
Demodded.
The Seals
 Old 05-11-2011, 08:10 PM   #29
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Groaned at 9 Times in 6 Posts
Simple question, tricky answer.
When drag racing, DSC off for sure. Car will bog down due to wheelspin.
When spirited driving (curves, etc) I've found it's better with the DSC on. With the DSC off the tires tend to spin when exiting turns (due the immediate torque). Even if the DSC reacts the limited power almost helps sometimes.
This is with summer and or all seasons so I don't know how much different it is with track tires.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
 Old 05-11-2011, 08:10 PM   #30
cbusby's Avatar
People this is so simple. We have two modes, DSC on and DSC off. When you press the button, the light comes on in the cluster, it is disabled. Press it again, the light goes away, it is disabled. That's all there is to it.
 Old 05-11-2011, 08:25 PM   #31
Tokay444's Avatar
Groans: 793
My right foot is my traction control, and my steering wheel is my stability control.
Demodded.
The Seals
Angr-E1 (06-11-2011), jroc (06-11-2011)
 Old 05-11-2011, 11:59 PM   #32
whitespeed's Avatar
Posts: 157   (View Stats)
whitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond reputewhitespeed has a reputation beyond repute
I prefer first gear with DSC off, when I shift into second I press the DSC button to turn it back on. Once I hit 4400RPM in 3rd I turn it back off...this seems to work pretty good for me.
2009 CWP Mazdaspeed 3 - Cobb SRI / Cobb TIP / Cobb AP Stage 2 / SU Boost Tubes & Recirc Tube / Forge BPV / CP-E HPFP / CP-E Safe Seals / 3.25" ETS TMIC / TRZ Transmission Mount / SU RMM / SU Shifter Bushings / JBR Heavy Shift Knob / JBR STSP / Bnoon Bolt / CNT Catted Downpipe / JBR TB & IM TIG / JBR EGR Delete / Denso ITV22's / HKS Hi-Power Catback Exhaust / Defi Boost Gauge in Ventpod / Dashhawk / H&R Springs / Bilstein Sport Dampers / JBR RSB / SPC Adjustable Camber Arms / 10 mm Project Kics Wheel Spacers / 18" Gold Advan RCIII wheels / 235/40/18 Hankook Ventus RS3 / 35% Tint
whitespeed is offline   Reply With Quote
 Old 05-12-2011, 12:44 AM   #33
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
Groans: 266
When do you have your hands on the wheel?
DONOTBUGME is offline   Reply With Quote
The Following 7 Users Say Thank You to DONOTBUGME For This Useful Post:
Angr-E1 (06-11-2011), Bucker (06-11-2011), emag remrofni (06-11-2011), gtlaw (06-29-2011), karl-hungus (06-11-2011), SeeMeGovan (01-17-2014), xhymer (06-11-2011)
 Old 05-12-2011, 02:34 AM   #34
whitespeed's Avatar
I just let torque steer run its course...
The Following 3 Users Say Thank You to whitespeed For This Useful Post:
Broxer (06-29-2011), emag remrofni (06-11-2011), WRX_Fan_0717 (06-11-2011)
 Old 05-12-2011, 08:30 PM   #35
Transam1998's Avatar
Posts: 25   (View Stats)
Transam1998 has a spectacular aura aboutTransam1998 has a spectacular aura aboutTransam1998 has a spectacular aura about
For god's sake, turn it off before staging at the drag strip, or you will look like an ass, like I did twice in a row, when your car falls flat on it's face as you try to launch it.
2008 Mazdapeed 3, black > stock 1/4 mile 14.3 @ 99 mph
mods: Cobb AP, Cobb TIP and SRI, Corksport airbox for Cobb SRI, Denso ITV22
2.13 60ft 13.76 @ 104 mph
Car 2: 1998 Firebird 6sp , Navy Blue stock 1/4 mile 13.6 @ 104 mph
Mods: Thunder Racing GTP Stg2 heads, rvrs split cam, FAST intake, 90mm, Nick Williams 90mm thrtl bdy, QTP long tube hdrs, Magnaflow exhaust !cats, !EGR, airbox mod, throttle body coolant bypass, MSD coils, Magnacore wires, NGK plugs, Moser 12 bolt, 4.11 Posi, Textralia OZ700 clutch, Pro 5.0 shifter Spohn Tq arm, tubular control arms and relocation brackets, boxed subframe connectors, tuned by Exotic Performanc Plus
441 rwhp,
weight 3500 lbs
1/4 mile with Nitto NT555R DRs, 11.72 @ 119 mph
Transam1998 is offline   Reply With Quote
 Old 05-12-2011, 10:37 PM   #36
LuczOr's Avatar
Posts: 462   (View Stats)
LuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the worldLuczOr is the leader of the world
Groaned at 15 Times in 12 Posts
Ok, seriously, just turn that shit off. TCS and DSC is for the random old 60 yr old guy who accidentally buys a speed. It's there so he wont kill himself from the ZOMG TORQUE STEER exiting a corner. Learn to manage your right foot.
If you notice, when you go from no throttle to full throttle there is a WHOLE RANGE in between that can be used. Develop those driving skills boys!
Cool sig coming soon.
LuczOr is offline   Reply With Quote
The Following User Says Thank You to LuczOr For This Useful Post:
Bucker (06-11-2011)
 Old 06-10-2011, 11:57 PM   #37
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
On the Speed6 it also helps for the annoying "falls on its face when you hit a bump and you have your foot in it" syndrome...
holy thats ghey...
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
The Following User Says Thank You to Caldazar For This Useful Post:
BigjohnB20 (06-12-2011)
 Old 06-11-2011, 02:33 AM   #38
Reedy's Avatar
Posts: 391   (View Stats)
Reedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the worldReedy is the leader of the world
A lot of people say leaving the DSC on in the MPS/Mazdaspeed3 results in better times but I have set my fastest laps with it turned off.
Its a driver thing tho, if you're a very ragged (bad) driver then DSC will almost certainly make you go quicker. But if you drive smoothly to begin with then I find DSC kicking in can jump in and kill all your speed at the worst possible times.
Either way, when you're on the road, please use DSC, always. Nobody cares about your shitty street racing skills and if you lose control and kill somebody because you had DSC turned off and drove like a lunatic then I hope you enjoy your prison term.
As for the track, drive with it, then drive without it, then drive with it again. Compare and draw your own conclusions.
Reedy is offline   Reply With Quote
The Following User Says Thank You to Reedy For This Useful Post:
 Old 06-11-2011, 06:55 AM   #39
Tokay444's Avatar
Groans: 793
If he's driving like a lunatic, having dcs on is going to do little to aid the situation.
Demodded.
The Seals
 Old 06-11-2011, 07:14 AM   #40
ztnedman1's Avatar
Posts: 338   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
OFF, always off.
Rain, snow, etc... off. I control the wheel spin how I want to or need to, I do not want the computer kicking in and fucking me up at the worst time.
2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD
2004 Corvette Z06
SCCA Bowling Green Match Tour - GS 1st place
SCCA Wilmington Champ Tour - GS 2nd place
SCCA National Championship - GS 3rd place
SCCA Grenada Match Tour - AS 1st place
ztnedman1 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/dsc-off-while-driving-spirited-hard-luanching-80313/
VWVortex.com - Traction Control Button Retrofit Kit on a 2014 SE 1.8TSI? This thread Refback 10-15-2014 11:38 AM
What does dsc mean rx8 - 1Q5A This thread Refback 08-11-2014 03:53 PM
VWVortex.com - Traction Control Button Retrofit Kit on a 2014 SE 1.8TSI? This thread Refback 12-05-2013 07:31 PM
Roads List - Cruise or Spirited Mizzle Mazdaspeed3/6 General Discussion 13 02-22-2011 06:47 PM
MAF must do mod!!!! I like driving the car again... ptperformance Mazdaspeed3/6 General Discussion 143 03-09-2010 01:31 PM
Movie Review: The Goods: Live Hard, Sell Hard *Warning: Spoiler Alert* [w/POLL] Haltech Automotive News 0 08-18-2009 02:10 PM
Drowsy driving is equal to drunk driving Haltech Automotive News 0 05-29-2008 06:30 AM
Page generated in 0.56756 seconds with 47 queries
