![]() Join Date: Jan 2012 Location: Kingston, ONTARIO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 82
(Thread Starter) | Not Ranked : 0 score I am bringing in my car to mazda for them to look at the turbo/smoking issue but sometimes I find it doesnt smoke that much and dont want them to give me any excuses. I was going to shoot a bit of oil in 02 sensor port but in all honestly dont know these cars yet and have no idea what the easiest way or where it is really... yes I will find it but in asking from you experienced guys where to do it from.. lift car or not. What should I use on the sensor to hope that it doesnt wreck the thread or damage itself? Thanks, I did search but havent found my answers.
__________________ 2007 MS6, COBB AP, SU RMM, TT DIF MOUNT, COBB SRI/TIP, AUTOTECH To be installed: CX racing FMIC, CS DP, TWM shifter, Oil catch can [SIGPIC][/SIGPIC] |
![]() Join Date: May 2011 Location: Sykesville, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 539
| Not Ranked : 0 score Well if you searched you would know that the sensors are a pain to take off and more than likely get ruined. Have fun committing fraud by putting oil in there
__________________ 2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03 FREEKTUNE |
| The Following User Says Thank You to Boost Addict For This Useful Post: | HavasuSpeed3 (02-10-2012) |
| Not Ranked : 0 score You can use an o2 sensor socket to remove it. 22mm iirc. Its right there on top just remove the tmic and heat shields (been so long since Ive looked at a stock car) Make sure when you are removing it when it starts to bind stop and re tighten. From there proceed to remove again. They are pretty easy to remove most of the time but heat helps a ton also some pb blaster just dont get it on the sensor. |
| The Following User Says Thank You to EdgeAutosport.com For This Useful Post: | SwineFLU (02-10-2012) |
Groans: 433
| Not Ranked : 0 score dude, by the time you drive your ass to the dealer, all the oil will have burned away anyways. get there, go in, but let the car idle while you're there, if it doesn't smoke after idling for 20 mins, you don't have fucked seals.
(Thread Starter) | Not Ranked : 0 score Well its burning a bit more oil then I think is acceptable and it does smoke at idle more then any other car especially when warmed up. We all know how the dealers are they will try and say that nothing is wrong with the car and in all honesty my warranty expires soon and if i can get this looked at and replaced id rather do that.
![]() Join Date: Feb 2010 Location: NoVA/ Norfolk
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,285
Groans: 133
Groaned at 7 Times in 4 Posts
__________________ 08.5 CWP MS3 GT PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC | |
| The Following User Says Thank You to ABSpeed3 For This Useful Post: | SwineFLU (02-10-2012) |
(Thread Starter) | Not Ranked : 0 score regardless its still burning oil, ill bring it in to get checked.. i got nothing to lose its under warranty.
![]() Join Date: Nov 2008 Location: Hutto, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
| Not Ranked : 0 score IIRC, warranty was extended on smoking turbos.
__________________ 2012 Black Mica with Tech package. Chock full of goodies and Dizzy tuned |
![]() Join Date: Feb 2010 Location: Daphne, Alabama
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
| Not Ranked : 0 score just throw a rock in your intake and drive it to the dealer. |
![]() Join Date: Sep 2011 Location: Olympia, WA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
| Not Ranked : 0 score really? my second gear was grinding when it was cold, but i didn't have to put water in the tranny for them to diagnose a known problem. just bring it in and don't let them give it back to you until it is fixed. this is a problem already acknowledged by mazda, so trying to fake it won't help you. |
| The Following User Says Thank You to mrtheandrew For This Useful Post: | SwineFLU (02-10-2012) |
__________________ 2007 MS6, COBB AP, SU RMM, TT DIF MOUNT, COBB SRI/TIP, AUTOTECH To be installed: CX racing FMIC, CS DP, TWM shifter, Oil catch can [SIGPIC][/SIGPIC] | |
| Easiest iPod install method suggestions | chadeckler | MazdaSpeed 6 - How-To's | 27 | 05-12-2012 07:36 PM |
| Easiest way to update stock map to reduce 1st and 2nd limits | Qtip | Cobb ATR Support | 7 | 02-10-2012 06:11 PM |
| easiest way to ship wheels/tires | ZoomByU | MazdaSpeed 3/6 - Wheels & Tires | 7 | 03-06-2011 04:49 AM |
| Easiest way to run wire in the doors | Hectik1 | MazdaSpeed 3/6 - Car Audio & Electronics | 2 | 06-24-2010 06:27 AM |
| Best/Easiest way to remove window tint? | squale | MazdaSpeed 3/6 - Appearance | 13 | 05-20-2010 02:02 PM |
