| Fermion | 01-28-2020 08:55 AM | Ebrake cable replacement Well I’m back in the game after not having a working ms3 for 3 yrs! Found an ms3 in my area with good compression numbers and instead of finishing my rebuild, I decided to just buy the working one for less than the rebuild. Already I have a love hate relationship with this car, just like my last one.
Anyways, it has some gremlins I need to address for sure. I’m currently doing the vvt bc I have all of the parts already and it definitely needed to be done. The other main issue is the ebrake is broken. Looks like there’s nothing connected at the caliper end, but the service manual graphic is so bad. Is it routed under the heat shielding and then to the calipers? Based on my reading I only see ebrake adjustment threads. Anyone replace the cable on these and can impart some words of wisdom in my direction? |
