 Old 10-09-2017, 10:10 PM   #1
darkmx-6's Avatar
Posts: 126   (View Stats)
darkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nicedarkmx-6 is just really nice
took the intake manifold off for cleaning. EGR was definitely clogged. but it was clogged in the intake manifold in the elbow right were the pipe comes in and it bends up in the cast manifold into the intake plenum. haven't put it back together yet but it looks like that was it.
it was so clogged I couldn't pass a wire through it. I kept poking it and spraying b12 on it till it gave and drained b12. then i kept cleaning more. It still needs more work but it is much better than it was.
miss fire is back though. I've done some upgrades and it seems to have made the misfire more pronounced and dangerous. I've melted 2 spark plugs.
I'm pretty sure it is a fuel injector problem. I'm looking into it now that the intake is off.
The injectors looked a really dirty. and I have a HPFP with good pressure that also points to the next point of fail which is the injectors.
the metal pipe was fine.
Last edited by darkmx-6; 10-09-2017 at 10:10 PM. Reason: MSF Database - Automerged Doublepost
darkmx-6 is offline   Reply With Quote
valve guides? valve seal? valve stem? WHAT IS BLOWN?!?!?! eroler1 Gen2 MS3 General Discussion 32 12-29-2016 03:29 AM
TPMS code U0127 and ABS code B1318 Z32_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 05-12-2015 06:34 AM
Intake Valve Cleaning using valve overlap and DI injection window shift Vansquish MazdaSpeed 3/6 - ECU Computer Tuning 33 05-06-2014 07:00 PM
P0401 code just got my mazdaspeed 3 and this code popped up Steezyms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 04-23-2014 02:20 PM
Page generated in 0.22637 seconds with 21 queries
