  • 1 Post By
 Old 10-26-2012, 01:05 PM   #1
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Below is just one of many similar bits that are out there.
Running just Redline Water Wetter and H20 summer - Bob Is The Oil Guy
Redline Water Wetter was designed for use in pure water cooling systems, as required by racing applications.
Coolant, when spilled onto a track, causes a slippery condition.....not good for drive fast turn left applications.
If you read the chart on the bottle, it shows a major increase in temperature transfer between the water and metal in the water only application.
The same chart shows a slight improvement when used with coolant.
Unless you are running beyond the capacity of your cooling system (design or some problem that has developed), you will not see your motor running cooler with/without this product as the thermostat will regulate the coolant temperature.
Actual head temperature might differ, but that would take some advanced measuring that is not built into passenger vehicles (temperature monitoring is of coolant temperature).
I recall reading the Redline indicated that the stuff you see separate out of the Redline Water Wetter in systems with coolant is not harmful to the system....and will re-mix when the coolant gets hot.
What we tend to see is this stuff that separates out.....building up in the overflow bottle.....and it does look nasty.
At the same time I read this (someplace on THIS website) the recommendation to avoid this separation was to use the Water Wetter that is for Diesel engines.....as it is designed to be used in coolant, not pure water.
The Diesel Water Wetter was purple in color.......and harder to locate.
However, my advice would be to contact Redline through their website and see what they have to say.
They seem to be very responsive to questions and they would be a better source of information than I am.
340hp / 371tq
easy (10-26-2012)
 Old 10-26-2012, 07:09 PM   #2
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
good info, that is exactly what happened with me
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/engine-coolant-128395/
Mazda FL-22 Coolant Cross-Reference_Wiki Searcher This thread Refback 04-26-2015 08:19 PM
Coolant in engine bay KillerAngel MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 05-23-2011 05:03 PM
Coolant boiling over exhaust in coolant bcmurphy87 MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-15-2010 02:39 PM
Video: Prestone melts GM 3.6-liter engine block with blowtorches to show importance of coolant Haltech Automotive News 1 06-30-2010 11:13 AM
coolant phillyb MazdaSpeed 3 - Engine, Transmission & Driveline 26 03-13-2010 06:24 PM
Page generated in 0.26143 seconds with 22 queries
