 Old 03-19-2009, 12:36 PM   #1
Speedie6's Avatar
Posts: 1,838   (View Stats)
Default Engine damper for MS6?
I've been bitchin' about the increased vibrations my car has since the BSD. Some vendor, I can't remember which, but some vendor was selling engine dampers for 3's. I'm not talking about the damper for the crank. What I'm talking about looks like a little shock absorber, and mounted somewhere around where the side motor mount goes. Such things are made for a lot of cars. Maybe something like that could be put on the MS6? Anybody know who makes the kit for the 3?
 Old 03-19-2009, 12:56 PM   #2
crlsnlopes's Avatar
Posts: 77   (View Stats)
crlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond reputecrlsnlopes has a reputation beyond repute
iirc M3M is the vendor doing the gb
WWP MS6
VG Shark Fin-Audio Link iPod-AEV interface-Prosport Boost gauge & Oil Preassure-AEM A/F gauge-HKS bov-CS FMIC-ITV24-CobbSRI-Cobb TIP-Cobb AP stage 2+TIPSF+exman-DNP manifold-CS cbe-SU TP-CPE DP-TWM S2+bushings-BC Coilovers-AWR Front&Rear links-SPC balljoints-CPE MM-corksport STB-LED Tails-CPE towplate-SM OCC-PTP IM spacer
242hp/267tq on a mustang dyno 11/21/09
293hp 9/26/10 @ theshop
crlsnlopes is offline   Reply With Quote
 Old 03-19-2009, 04:44 PM   #3
Speedie6's Avatar
YES, that is exactly what I was talking about. Now, can SOMEBODY do one for the MS6? John? Please?
 Old 03-29-2009, 11:20 PM   #4
ptperformance's Avatar
Posts: 4,123   (View Stats)
I need a 6 around me so I can take a look at where we have the room to mount it. Are the vibes really that bad? If so, damn it. We have done several locals cars with out one of them saying that they can tell a difference. I really don't want to say this but have you done a compression test lately? Checked the spark plugs? Let me know because this shouldn't be happening on just a BSD. Thanks.
 Old 03-30-2009, 09:14 AM   #5
Speedie6's Avatar
Well, I had a lot of vibes even before the BSD. I have a lot of solid mounts. It has been suggested that maybe I just remove my front mount as it may be superflous with all the other mounts I have. I did get somewhat more used to the vibes after driving it for a few days, but, yeah, it was still fairly significant if you ask me.
 Old 03-30-2009, 11:48 AM   #6
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
Don't do an engine torque damper on an AWD car. ETDs dampen engine movement, which means it still moves. You want to keep any odd angles eliminated from the tranfer case connection to the driveshaft.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
The Following User Says Thank You to ATE BALLER For This Useful Post:
06Speed6 (03-31-2009)
 Old 04-10-2009, 02:27 PM   #7
I say try this and get back to us. This might be the magic that makes the car drive better.
Koni FSD shock, strut, damper install FreeFlyFreak MazdaSpeed 3 - How-To's 346 09-24-2018 05:16 AM
Any feedback on Torque/Engine Damper? Qluber MazdaSpeed 3 - Engine, Transmission & Driveline 24 04-23-2009 02:48 AM
engine damper black-speed3-gt MazdaSpeed 3 - Engine, Transmission & Driveline 0 11-07-2008 06:19 PM
Weapon-R Engine Torque Damper TheDoc MazdaSpeed 3 - Engine, Transmission & Driveline 6 10-28-2008 10:43 AM
Engine Damper? Qluber MazdaSpeed 3 - Engine, Transmission & Driveline 3 09-24-2008 06:12 PM
Page generated in 0.28791 seconds with 23 queries
