 Old 09-30-2017, 03:34 PM   #1
Lilrobbie1127's Avatar
Posts: 2   (View Stats)
Lilrobbie1127 can only hope to improve
Groaned at 3 Times in 1 Post
Default Engine swap help
Okay so I loaned some friends my car. While they had it a radiator hose popped off and they drove the car till it stopped. I removed the spark plugs to find cylinders full of antifreeze. I turned the car over and the engine could barley spit any of the water out. At this point I'm cutting my loses and swapping the engine the car is a 2007 Mazda 3 with a 2.0L automatic transmission. I was wondering if anyone has a guide or step by step instructions on removal and installation. Also a list of parts/gaskets that I should swap along the way obviously I think to do the timing water pump plugs wires and coils but idk what other gaskets Or parts to replace as well. Any help I can get would be awesome I want this to go smoothly as possible I don't have a lift so the engine will have to come out from the top.
Lilrobbie1127 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Lilrobbie1127 For This Un-useful Post:
MS3Shadow (10-02-2017), stockms3 (09-30-2017), Thor Hammer (10-02-2017)
 Old 10-02-2017, 02:27 PM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Wrong forum.
 Old 10-03-2017, 02:36 PM   #3
Well these websites aren't exactly mobile friendly I searched the Internet for days for this info I just ended up buying myself a Haynes manual
 Old 10-11-2017, 12:38 PM   #4
E.Murray's Avatar
Posts: 35   (View Stats)
E.Murray is an unknown quantity at this point
There's an engine forum that has good info. A couple threads even have spreadsheets attached with part numbers. Head over and check it out! Can you tell what I'm working on...
I can sum up the Haynes manual and save you $21. "Take all the bolts out. Installation is reverse of removal." Ta-da. Free!
E.Murray is offline   Reply With Quote
Gen 2 Ms3 Engine Swap into a Gen 1 Ms3 550bomb MazdaSpeed 3 - Engine, Transmission & Driveline 63 09-21-2015 05:30 AM
swap engine from one MS6 to another aviator79 MazdaSpeed 3/6 - Build Diaries 24 11-17-2012 04:30 PM
Engine Swap caykilla MazdaSpeed 3 - Engine, Transmission & Driveline 2 10-15-2009 05:03 PM
Page generated in 0.25864 seconds with 22 queries
