Like Tree26Likes
Closed Thread
 Old 04-18-2012, 10:43 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Default Enkiworks Kalibrator (Build Thread)
Currently working on writing a log parser that will consume huge random AP logs and shit out a decent MAF calibration. I'm having to learn C# in the process, so it is rather painful.
This is where you (the reader) come into play; continued harassment will result in me eventually finishing this thing, which subsequently will mean no more manual MAF calibrations will be required on your part.
Here's a screenshot of the pretty near finished UI; I will likely replace the "enki" picture with more options down the road, but a simple setup will suffice for now.
For those that give a shit, I had gotten pretty far with the script only version, but found it to be infeasible to collate and average all the data from even a small log file using only scripting. Thus, the switch to C#, which I am pretty positive will ultimately prove successful.
Feel free to use this thread to suggest features, report bugs (when I start doing betas), ask questions, or post power ballads about well hung llamas.
REQUESTED FEATURES:
Easier initial scaling for big MAF housings
Allow for all closed or open loop operation without app shitting itself in endless loops
NOW RUNNING TRIALS!
I will be taking a COUPLE of samples from people (that can/will do a manual MAFCAL themselves) whom post in this thread the following information (within CODE tags; keep the tabs in there or my lazy ass will skip you):
1. Current MAF calibration
2. Current WOT AFR targets
3. Accelerator pedal open loop transition
4. Load open loop transition
5. Rev limit
6. The log file
7. Your manually created MAF calibration (for me to compare)
Note that the log file needs at least the following columns within it or it will not work at all (extra data doesn't matter, but fewer extra columns results in better data resolution and thus, higher accuracy):
Accel. Pedal Pos. (%)
Actual AFR (AFR)
Boost (PSI)
Calculated Load (Load)
Long Term FT (%)
MAF Voltage (V)
RPM (RPM)
Short Term FT (%)
Wastegate Duty (%)
Order of these columns within the log file does not matter. Also, please have everything in one post so I can go back to it later for further testing.
Enki is offline
The Following 109 Users Say Thank You to Enki For This Useful Post:
06Speed6 (04-19-2012), 2k4_8 (04-19-2012), 86AmishMs3 (04-18-2012), Adam is so pro (05-09-2012), alphasaur (04-19-2012), Angr-E1 (04-20-2012), Awesomesauce (05-04-2012), AZSPEED3 (04-20-2012), backward_0 (06-09-2012), BigRedSpecial (04-19-2012), BlckMs3 (04-18-2012), BlueStreak (04-19-2012), BobbleHead (04-21-2012), Boosted Beluga (05-04-2012), Boost_creep (04-20-2012), breakfasteatre (05-08-2012), breakfstincluded (06-18-2012), BrianB6 (04-19-2012), Broxer (04-20-2012), burn813 (08-01-2012), captain slow (04-19-2012), charlesfist (04-19-2012), Coaststarlight (04-27-2012), CosmicArkie (04-20-2012), cshunter (08-01-2012), Dano (06-17-2012), Death-From-A-Mile (04-18-2012), dereeek (04-18-2012), djuosnteisn (04-20-2012), dpolseno41 (04-18-2012), drknyte (05-05-2012), DuBz (08-01-2012), E.Tinker (04-19-2012), Easter Bunny (04-19-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-23-2012), Fobio (04-20-2012), forcedinduktion (04-18-2012), franz (04-19-2012), fywdyl (04-20-2012), G26 (04-20-2012), helmetface (04-19-2012), i8urgti (05-08-2012), IshiKage (04-19-2012), JacksonMS30 (04-27-2012), jack_hammer (04-23-2012), Jake_MS3 (04-19-2012), JmkC (06-17-2012), josurr (04-18-2012), jtt (04-19-2012), kgb (04-19-2012), kngeducate (04-19-2012), kunfu (04-22-2012), leon78 (04-19-2012), Lex (04-18-2012), magicka (04-20-2012), Magic_AoD (04-21-2012), MattJackson86 (04-18-2012), Meder (04-19-2012), meicalnissyen (04-26-2012), melly mel (04-19-2012), memin (05-18-2014), Micha (06-26-2012), Mizzle (04-20-2012), Monotonous ONE (04-19-2012), mrdouble99 (04-19-2012), mrmonk7663 (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), MS3inDC (04-26-2012), Ms3_Miami (04-20-2012), mzr0818 (04-19-2012), NCZ13 (05-07-2012), nighthawk358 (04-23-2012), nindoja (04-20-2012), Oliverms3 (04-19-2012), phate (04-19-2012), Pointless (04-19-2012), Pseud0logik (04-18-2012), Pu Manchu (04-20-2012), radioflyer (04-23-2012), RayRay (04-27-2012), Realgib3 (04-18-2012), rfinkle2 (04-19-2012), rigor (04-23-2012), ryno077 (04-22-2012), ScarMS3 (04-27-2012), Scribbles (04-19-2012), shawn. (05-04-2012), SilverDemon (04-19-2012), SLOWHATCH (04-30-2012), smoogs12 (04-26-2012), socks (04-20-2012), SpeedSixxx (04-19-2012), Spirry (04-21-2012), superskaterxes (04-23-2012), Takinato (06-11-2012), TexasSpeed3 (04-19-2012), themytb (04-19-2012), Todd98SE (08-28-2012), Tokay444 (04-20-2012), TWOptSL0W (04-19-2012), uncorked11 (04-21-2012), urbansurfer (07-15-2012), Vansquish (04-30-2014), vdgmcool (05-14-2012), warlord (04-19-2012), xb2ms3 (04-22-2012), Z32_MS3 (05-18-2014), Zbrit00x (05-05-2012)
 Old 04-18-2012, 11:00 PM   #2
Excellent! This will be a nice little app.
Lex is offline
Enki (04-18-2012)
 Old 04-18-2012, 11:37 PM   #3
chuckms6's Avatar
Posts: 1,618   (View Stats)
ive been comtemplating trying to code something like this since i started visual basic class, we just havent learned how to process large amounts of data like that yet lol
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
chuckms6 is offline
The Following 2 Users Say Thank You to chuckms6 For This Useful Post:
Enki (04-18-2012), Jh8909 (04-18-2012)
 Old 04-18-2012, 11:47 PM   #4
Enki's Avatar
Well in order to do it accurately (which is kind of a given) you need to go by .01 volts on the MAF scale; this means interpolating a FUCKLOAD of data if your dataset is small, or estimating (which is what generally is done on manual MAFCals).
What I was about to do in script is create a 500 row by 4 column table for the end result data...This didn't include the datasets where I take each individual .01 volt increment worth of data from the log and average it, remove outliers, classify as OL/CL, etc before dumping it into the table proper.
Basically, I gave up on the scripted portion after running through a simulated processing path in my head and figuring out that my computer would shit ram all over the place and bring a single thread to its knees trying to get through even a smallish log.
At least this way, I can use linq or at worst load the log into an (embedded) SQL backend for query rather than having to pre-sort before manipulation.
TLDR:
Old code would result in this:
Also, I am a huge nerd.
rfinkle2 and TexasSpeed3 like this.
Enki is offline
The Following 8 Users Say Thank You to Enki For This Useful Post:
Easter Bunny (04-19-2012), IshiKage (04-19-2012), Micha (06-26-2012), phate (04-19-2012), rfinkle2 (04-19-2012), SpeedSixxx (04-19-2012), TexasSpeed3 (04-19-2012), uncorked11 (04-21-2012)
 Old 04-18-2012, 11:54 PM   #5
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Sounds homo James
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
86AmishMs3 is offline
Tomas (04-26-2012)
 Old 04-18-2012, 11:57 PM   #6
MattJackson86's Avatar
Posts: 1,407   (View Stats)
Let me know if you need any help on this. Probably don't have the time to code it, but questions or if you need a 2nd set of eyes to look it over. I was looking to work on something like this (and other auto tune stuff) with me standback software I wrote.
MattJackson86 is offline
The Following User Says Thank You to MattJackson86 For This Useful Post:
Enki (04-18-2012)
 Old 04-19-2012, 12:00 AM   #7
Enki's Avatar
Originally Posted by 86azms3 View Post
Sounds homo James
Eat a bowl of dicks Corey
I'm learning as I go. I can read the languages just fine, it's getting my feet wet getting started on writing that's a pain in the ass. Already almost done with regex validation for the MAF table and AFR inputs:
MAF Values ([0-9]+\.[0-9][0-9][\t]){128,}?[0-9]+[\.][0-9][0-9]
WOT AFR Values ([0-9][0-9]\.[0-9][0-9][0-9][\t]){13,}?[0-9][0-9][\.][0-9][0-9][0-9]
Last edited by Enki; 04-19-2012 at 12:01 AM. Reason: MSF Database - Automerged Doublepost
Enki is offline
Easter Bunny (04-19-2012), phate (04-19-2012), rigor (04-23-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 12:04 AM   #8
This helps me with RegEx: Regex Tester Online
Enki (04-19-2012)
 Old 04-19-2012, 12:05 AM   #9
Enki's Avatar
Already checked my regex; tis good.
Enki is offline
phate (04-19-2012)
 Old 04-19-2012, 12:38 AM   #10
leon78's Avatar
Posts: 2,595   (View Stats)
2013 Scion FR-S (Whiteout)
Less parking more racing
leon78 is offline
The Following User Says Thank You to leon78 For This Useful Post:
Enki (04-19-2012)
 Old 04-19-2012, 04:27 AM   #11
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
This is going to be so nice, the one thing that I am starting to really hate is doing maf cals, its never perfect and it takes hours to even get it close.
2006 Mazdaspeed 6
06Speed6 is offline
The Following 2 Users Say Thank You to 06Speed6 For This Useful Post:
AZSPEED3 (04-20-2012), Enki (04-19-2012)
 Old 04-19-2012, 05:52 AM   #12
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
I had no idea something like this was even possible... Now what excuse will I have to randomly go out and burn half a tank of gas?
Needed: Driver mod
BigRedSpecial is offline
The Following 3 Users Say Thank You to BigRedSpecial For This Useful Post:
Broxer (04-20-2012), Enki (04-19-2012), Fatguy729 (04-22-2012)
 Old 04-19-2012, 06:01 AM   #13
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I think you should change the picture with "ENKI" in it to o e of T-Pain...he is the king of autotune after all.
In all seriousness though, this will be fucking amazing if you can get it to work.
NATOR PA
MS3-a(sore)ASS-rex is offline
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
alphasaur (04-19-2012), Broxer (04-20-2012), Enki (04-19-2012)
 Old 04-19-2012, 10:31 AM   #14
Enki's Avatar
I personally don't think it's *THAT* bad, but I'd rather drive around running errands for up to an hour and drop the whole fat log into an app like this and have it shit out a pretty good MAFCAL.
Anything is possible if you put your mind to it. Also, half a tank will probably be too big of a log (unless you're on full e85, in which case the fuel gauge will drop quickly). What kind of space does the AP have on it for logs, anyways?
That picture is already gone; I found something useful to put there after all. I really hate wasted space in my user interfaces, so I'll look for anything to stuff into open space or sometimes even completely re-design the UI to make it more compact and user friendly.
As for it working, it will; at some point anyways. My biggest hurdle right now is knowledge, but I'm already up to 200 lines of UI validation and content conformance (making sure people are passing the right data to the app). I probably need to make the regex a bit more strict, and plan ahead for larger MAF housings though.
As a side note, I already plan on adding wastegate integration in the future (making hitting those boost targets super easy); that will probably only be for WOT though, as running the entire table will be a pain in the ass.
TexasSpeed3 likes this.
Enki is offline
The Following 6 Users Say Thank You to Enki For This Useful Post:
06Speed6 (04-19-2012), AZSPEED3 (04-20-2012), phate (04-19-2012), rfinkle2 (04-19-2012), rigor (04-23-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 10:46 AM   #15
Groans: 56
lol... Not what I meant at all... I mean, if I can use logs from daily driving to calibrate my maf, what excuse will I use to leave the GF home at night to go out and just drive around for two hours?
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
Enki (04-19-2012)
 Old 04-19-2012, 11:05 AM   #16
Enki's Avatar
You could still tell her you're going out to get logs for tuning/calibrating. That part still hasn't changed.
Enki is offline
 Old 04-19-2012, 11:11 AM   #17
Be careful with delays if you're using STFTs or even AFRs since during throttle transitions these can really vary.
I would look for steady state throttle, then look at LTFTs, and then STFTs as well. I would average STFTs (just like the car does) in broken up regions of the MAF curve that is more granular than what the current LTFTs do.
Lex is offline
06Speed6 (04-19-2012), Bucker (04-19-2012), charlesfist (04-19-2012), Enki (04-19-2012), phate (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 12:36 PM   #18
Enki's Avatar
Well the plan is to average all but outlier data (stuff that exceeds a certain threshold of difference from the meat of the data) and use 100% of the LTFT but only 50% of STFT data (for now; thanks @phate for this idea!). I figure, if you want it more accurate, you can simply pull another log and run it back through again.
The whole averaging thing means the larger and more diverse the raw log file is, the more accurate this will become; doing the short little logs isn't going to cut it as there won't be enough intelligence in the code to discern situational changes like throttle lift or roll on, etc.
BTW, still making progress; currently loading logs into datatables for parsing!
Enki is offline
The Following 15 Users Say Thank You to Enki For This Useful Post:
06Speed6 (04-19-2012), Awesomesauce (05-04-2012), AZSPEED3 (04-20-2012), BigRedSpecial (04-19-2012), CosmicArkie (04-20-2012), dereeek (04-21-2012), Easter Bunny (04-19-2012), jack_hammer (04-26-2012), MS3-a(sore)ASS-rex (04-19-2012), phate (04-19-2012), Realgib3 (04-19-2012), rfinkle2 (04-19-2012), rigor (04-23-2012), Spirry (04-21-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 12:46 PM   #19
Wow Enki. To learn C++ just to bring this out is a feat all in itself. Thanks very much for this.
Arguably the most important part of the tune is being addressed with much less chance of error.
This is something that I will definitely use.
Thanks very much. Lots of effort.
rfinkle2 is offline
Enki (04-19-2012), kgb (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 12:50 PM   #20
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Subbed. The CL/OL transition range is always the trickiest part. You might want to incorporate some limit as to how much change between adjacent cells can occur. [I believe the derivative of the maf curve is almost linear, so you might just be able to assume this and limit it with a single value.]
IF someone has a leak, you get very bumpy maf curves if you tune around it. That should NOT be done, and the curve should always stay pretty dang smooth. If the calculated correction in one area falls outside of the norm, red flags and whistles should go off, because their setup needs inspected.
I foresee this tool being used (unknowingly) by folks to tune around things that should not be tuned around.
Edit: start praying to the gods of internal combustion for automatically calibrating a maf curve while spraying meth.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
The Following 10 Users Say Thank You to phate For This Useful Post:
06Speed6 (04-19-2012), Broxer (04-20-2012), Bucker (04-19-2012), CosmicArkie (04-20-2012), Enki (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), rfinkle2 (04-19-2012), SLOWHATCH (04-30-2012), TexasSpeed3 (04-19-2012), uncorked11 (04-21-2012)
 Old 04-19-2012, 12:52 PM   #21
Jake_MS3's Avatar
Posts: 859   (View Stats)
Jake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the world
Subbed for future reference. Thanks for all the hard work and time we all know you're spending!
2009 Mazdaspeed 3
Jake_MS3 is offline
The Following 2 Users Say Thank You to Jake_MS3 For This Useful Post:
Don06speed6 (04-20-2012), Enki (04-19-2012)
 Old 04-19-2012, 01:51 PM   #22
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
Wow,bthis will sure be nice! Another humble thanks!
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline
The Following User Says Thank You to 2k4_8 For This Useful Post:
Enki (04-19-2012)
 Old 04-19-2012, 02:12 PM   #23
Enki's Avatar
I'm making this more for the pro-tuners (whom I assume will drive the feature-set forward), and the noobies (whom will be reading/accepting a big fat list of caveats before allowed to even obtain this).
For now, final determination of acceptability will be on the end user; run at your own risk sort of thing. Ultimately, it shouldn't be too hard to leave calibration A as default and drop the apps output into B, and flip back and forth to determine if you want to use it or not.
Your input has been taken into advisement and will be considered (if I can figure out a nice, safe way to implement it) for inclusion in a later version.
Thanks for the input Phate!
Enki is offline
 Old 04-19-2012, 02:30 PM   #24
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
i want to suck your cock
Monotonous ONE is offline
The Following 3 Users Say Thank You to Monotonous ONE For This Useful Post:
Enki (04-19-2012), phate (04-19-2012), ryno077 (04-22-2012)
 Old 04-19-2012, 02:42 PM   #25
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
The 2nd derivative of the MAF curve is linear. I checked it out a while ago using numerical analysis methods.
I tried out a mathematically ideal MAF curve once. Didn't work too well.
Tapadatass
silvapain is offline
The Following 6 Users Say Thank You to silvapain For This Useful Post:
Enki (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), phate (04-19-2012), rfinkle2 (04-19-2012), Spirry (04-21-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 02:44 PM   #26
Enki's Avatar
Well shit, I guess I HAVE to finish it now (preferably while you finish me! )
Enki is offline
Monotonous ONE (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 02:45 PM   #27
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Totally awesome
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline
The Following User Says Thank You to mrdouble99 For This Useful Post:
Enki (04-19-2012)
 Old 04-19-2012, 02:45 PM   #28
Enki's Avatar
Care to elaborate? Last math class I had in high school the final project was to balance a checkbook.
Enki is offline
 Old 04-19-2012, 03:04 PM   #29
Eth Fiend
phate's Avatar
Tapadatass
Ah, yeah. We talked about that at one point.
-06 MS6
phate is offline
Enki (04-19-2012)
 Old 04-19-2012, 03:35 PM   #30
silvapain's Avatar
Groans: 136
I'm way too lazy to type it all out on my phone, but a derivative of a function with respect to an input is the change in that function's output WRT the input (I.e. the slope of the line for a given x). A numerical solution involves taking known discrete points (x1, y1), (x2, y2) and determining the changes in output (y2-y1) based on the change in input (x2-x1). That is the 1st derivative. repeat the process again for the 2nd derivative.
Tapadatass
The Following 7 Users Say Thank You to silvapain For This Useful Post:
06Speed6 (04-19-2012), 86AmishMs3 (04-19-2012), Enki (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), phate (04-19-2012), rfinkle2 (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 05:36 PM   #31
It will probably be easiest if the user does a MAF cal log that has very gentle throttle inputs and that extends into WOT to cover the whole range.
Have them log desired AFR as well as actual AFR along with the LTFT, STFT information.
Lex is offline
Enki (04-19-2012), rfinkle2 (04-20-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 05:58 PM   #32
TexasSpeed3's Avatar
Posts: 1,996   (View Stats)
TexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the worldTexasSpeed3 is the leader of the world
Groans: 273
damn this is making me want to get back into programming. but shit so many variables in this one. your a brave soul taking on learning a new language as well as this program by itself. cant wait to see how this works
2011 Black Mica - Daily
JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp
TexasSpeed3 is offline
The Following User Says Thank You to TexasSpeed3 For This Useful Post:
Enki (04-19-2012)
 Old 04-19-2012, 06:06 PM   #33
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
Gonna be badass, shit, az will have something to be proud of.
Can you please change the ENKI on the front to a unicorn shooting jizz outta his dick with a rainbow behind him?
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline
The Following User Says Thank You to Scribbles For This Useful Post:
Enki (04-19-2012)
 Old 04-19-2012, 06:19 PM   #34
Enki's Avatar
Gen 1 doesn't have commanded AFR parameter, sadly.
So far the required logged values are accel pedal position, afr, boost, calc load, both trims, maf voltage, rpm and wastegate. I thought about doing mass airflow, but it didn't seem to line up with the voltage sometimes.
As a side note, hit my first big hurdle and am currently working through it.
Enki is offline
rfinkle2 (04-20-2012), silvapain (04-19-2012)
 Old 04-19-2012, 06:21 PM   #35
Speeeeeed
06Speed6's Avatar
I wonder if someone could write a script that would check for improper curves that are out of a certain range. There has gotta be a way because that script would throw a flag for meth systems, aux fueling, intake leaks, and maybe some other stuff im not thinking of.
The math is way over my head but I know we have some math gurus around here that can make graph formula that fits.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 04-19-2012, 07:03 PM   #36
Enki's Avatar
Across the maf scale, there is a maximum jump from voltage to voltage. It should be possible to average these jumps out, and if higher than a certain percentage (a base/ots mafcal can be used for this), a flag can be thrown. Ultimately, it will be obvious as the curve will suddenly jump by a good amount when viewed in ATR.
Enki is offline
 Old 04-19-2012, 10:17 PM   #37
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Hellz yah. I've been waiting 2 months for an update on this...I'm glad you are making progress on it and will continue to wait for the beta release. The incorporation of larger maf housings...3", 3.25, 3.5, and 4" would be great!!!
Good Job Enki.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
mrmonk7663 is offline
 Old 04-20-2012, 01:14 AM   #38
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
wow! this would be great!!
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline
The Following User Says Thank You to ms6forthewin For This Useful Post:
Enki (04-20-2012)
 Old 04-20-2012, 04:52 AM   #39
JasonMzdSpd3's Avatar
Posts: 253   (View Stats)
JasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the worldJasonMzdSpd3 is the leader of the world
Groaned at 10 Times in 9 Posts
Sick! This should be one kick ass app when complete.
Sent from Epic 4G via tap & touch 2.
2012 Speed3 Tech~ Liquid Silver~
Mods - AP, CP-E Xcel 3.25 Maf Intake, ATP Catless DP, CP-E Triton 3" SS CBE, AT Internals, NGK 1 step colder plugs, TurboSmart BPV, GTX 2867r, 3 bar map, GS EBCS, HTP 3" TIP, JBR stage 2 OCC, CP-E Delta core FMIC, JBR Trilogy, JBR Solid Shifter Bushings
Ordered Mods -
Planned mods -safe seals. SSP oil return, CObb V3, Denso step colder plugs. My car hates NGK for some reason.
Mods here but not installed-
Purple Drank tuned!
Tinted 15% all the way around, 5% hatch.
I think the internet needs more Cowbell!
JasonMzdSpd3 is offline
The Following User Says Thank You to JasonMzdSpd3 For This Useful Post:
Enki (04-20-2012)
 Old 04-20-2012, 06:11 AM   #40
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
If you need any help with your methodology or have any questions in general, let me know. I'm just finishing up a class in C++, and although C# takes a departure from C++ in certain areas, they are relatively similar.
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline
The Following 2 Users Say Thank You to SRTie4k For This Useful Post:
Enki (04-20-2012), rfinkle2 (04-20-2012)
Closed Thread
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/enkiworks-kalibrator-111249/
fywdyl's logs - Page 4 This thread Refback 04-20-2012 12:41 PM
Page generated in 0.65190 seconds with 41 queries
