  • 1 Post By 4G63
 Old 02-14-2012, 10:22 AM   #1
rx7fc3s87's Avatar
Posts: 39   (View Stats)
rx7fc3s87 is a splendid one to beholdrx7fc3s87 is a splendid one to beholdrx7fc3s87 is a splendid one to beholdrx7fc3s87 is a splendid one to beholdrx7fc3s87 is a splendid one to beholdrx7fc3s87 is a splendid one to beholdrx7fc3s87 is a splendid one to behold
Default Exhaust Question
Does the Cobb downpipe mate to an HKS Cat Back or is there another pipe to connect the two?
rx7fc3s87 is offline   Reply With Quote
 Old 02-14-2012, 10:28 AM   #2
SS_27's Avatar
Posts: 103   (View Stats)
SS_27 is a glorious beacon of lightSS_27 is a glorious beacon of lightSS_27 is a glorious beacon of lightSS_27 is a glorious beacon of lightSS_27 is a glorious beacon of lightSS_27 is a glorious beacon of light
Groaned at 10 Times in 9 Posts
I have a ATP 3" on my HKs works great!
SS_27 is offline   Reply With Quote
 Old 02-14-2012, 10:31 AM   #3
4G63's Avatar
Posts: 1,479   (View Stats)
Groans: 123
[Downpipe]-----[Test pipe/mid pipe]-----[catback exhaust]
Edit: Here's a pic for the reading impaired
SS_27 likes this.
2003 Evo VIII
The Following 2 Users Say Thank You to 4G63 For This Useful Post:
Ingle (02-14-2012), zpele (02-14-2012)
 Old 02-14-2012, 02:39 PM   #4
Ingle's Avatar
Posts: 421   (View Stats)
The thing that has to be considered is "long" or "short" downpipe.. I spent about an hour reading the exhaust thread and the DP thread before I realized what was in bold red with the difference.
 Old 02-14-2012, 02:47 PM   #5
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
if your stock one mounts to the hks catback and the cobb dp mounts to a stock catback then yes, it will fit no problem.
@4G63, cobb only makes a long downpipe (that I know of) so the test pipe is eliminated and his question is valid. That street unit picture really needs to be updated since there are both long and short downpipes out there.
Blue Pu.
4G63 (02-14-2012)
 Old 02-14-2012, 04:11 PM   #6
rx7fc3s87's Avatar
Thank you everybody! Still new to Speed 3's... So from what I can tell a CNT or COBB long downpipe would bolt to a cat back where a Corksport short downpipe would need a midpipe to connect to a cat back exhaust.
Gracias!
 Old 02-14-2012, 05:36 PM   #7
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Generally if the downpipe has a cat it's long and connects to te catback...if it is catless it would require a test pipe/race pipe....Corksport actually makes both now...long downpipes with cat...and a short catless
 Old 02-14-2012, 05:36 PM   #8
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
The cnt dp needs that adapter thingy for a non-cnt cbe.
Exhaust set up question dpolseno41 MazdaSpeed 3/6 - Turbo Induction 7 02-01-2012 04:42 PM
exhaust question Bdillon MazdaSpeed 3 - Engine, Transmission & Driveline 7 03-08-2011 05:56 PM
exhaust question brandonms3 Mazdaspeed3/6 General Discussion 10 01-14-2011 05:10 PM
Question about Exhaust azokaei MazdaSpeed 3 - Engine, Transmission & Driveline 2 08-01-2010 07:23 AM
exhaust question speed_3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 09-16-2008 08:42 PM
Page generated in 0.29287 seconds with 26 queries
