 Old 04-21-2014, 07:22 PM   #41
aviator79's Avatar
Posts: 3,934   (View Stats)
I have EGR set to not ready so either I fix this or I have to install my EGR tube to pass emissions:
New thread
EVAP not ready and P0455 EVAP CEL issue
 Old 06-05-2014, 12:01 PM   #42
Bulgsta's Avatar
Posts: 120   (View Stats)
Bulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond reputeBulgsta has a reputation beyond repute
I failed inspection too because of 3 not ready monitors.
I do not have a cel because I have disabled the codes in ATR.
Currently my egr valve is sitting in the engine bay plugged in, hoping it would clear the monitor.
My question is. Say you have all monitors ready, when you flash a new map to the Ecu do these monitors reset and go into not ready state?
Also having the codes disabled in ATR will prevent the monitors from ever being ready?
And last, say I enabled the codes, monitors become ready but throw a cel, once the monitors are ready I throw in a new map with the codes erased would those monitors go back into a non ready state or stay ready until I disconnect the battery and the reset?
2007 Mazdaspeed 6
GTX3076 - CPE- EX-mani w/ 44mm EWG - CPE Safe Seals - COBB APv3 - COBB Shifter Weight - DO Stage 2 Meth - PnP Intake Mani - Catless TBE - Corksport FMIC - Corksport Rear Diff Mount - Corksport OCC - AWR RRM, TMM, PMM - TT Front Engine Mount - TT Front Diff Mount - HTP 3.5 " - GFB 50/50 - AT internals - GrimSpeed ECBS - 3 Bar Map - Perm PCV plate - JBR BSD w/ baffle - JBR TIGS - Sure Shortcut - Tower Strut Bar - EGR Delete - EGR Valve Deleted - Shifter Bushings - H&R Springs - Koni Yellow Shocks - Stoptech D&S rotors - EBC Pads - Stainless Steel Brake Lines - Denso ITV 22 - Whiteline RSB - Guardian Angel
Bulgsta is offline   Reply With Quote
 Old 06-05-2014, 12:05 PM   #43
Skierdood's Avatar
Posts: 3,847   (View Stats)
Skierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the world
I'm pretty sure when a map is flashed it resets the monitors. As for the other two questions I'm not sure as I've never had to mess with disabling anything.
2007 True Red MS3
AP V2 • CPE Xcel Nano • COBB TIP • UR TP • Autotech Internals • CS RMM Inserts • FD Wheels • Freek Tuned 3/9 E85 315whp/352wtq •
Skierdood is offline   Reply With Quote
 Old 06-05-2014, 05:47 PM   #44
Bulgsta's Avatar
Just flashed the Ecu with a new map and all the monitors reset. Time to stop flashing so often so I could have even the slightest chance of passing emissions. 3 months overdue so far
2007 Mazdaspeed 6
 Old 06-06-2014, 07:14 PM   #45
aviator79's Avatar
I was over a year overdue. Figure it out?
 Old 06-06-2014, 09:42 PM   #46
Bulgsta's Avatar
I am down to evap monitor and egr not ready.
All I need is to get one of those ready and I am set.
First time I had 4 not ready so this is an improvement
2007 Mazdaspeed 6
 Old 06-08-2014, 02:10 AM   #47
sidekick's Avatar
Posts: 3,093   (View Stats)
Get versatuner. Lol. I have a CEL hidden via VT for the intake runner flaps, and my car passes readiness for all tests and shows CEL inactive or not on via other scan tools.
 Old 06-08-2014, 07:56 AM   #48
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Those flaps aren't a readiness monitor
The Following User Says Thank You to Dizzy Turbo For This Useful Post:
Tokay444 (06-17-2014)
 Old 06-17-2014, 08:51 PM   #49
aviator79's Avatar
but the will cause a CEL so having them not checked will let you pass...can have 1 not ready but cant have a CEL.
 Old 06-19-2014, 12:10 PM   #50
sidekick's Avatar
I know, but it still shows that the CEL is not active. A CEL will not allow you to pass readiness. At least in CA, they specifically look at the flag that says whether the CEL is active or not, as well as readiness monitors.
 Old 10-07-2014, 08:50 PM   #51
Alpha's Avatar
Posts: 3,711   (View Stats)
Where can we buy a good readiness scan tool?
 Old 10-07-2014, 08:58 PM   #52
Bulgsta's Avatar
eBay. They are cheap. You don't need a expensive unit to read the readiness of the monitors.
This is the one I used:
Rakuten.com
2007 Mazdaspeed 6
The Following User Says Thank You to Bulgsta For This Useful Post:
Alpha (10-07-2014)
 Old 10-07-2014, 09:07 PM   #53
frothy's Avatar
Posts: 1,067   (View Stats)
The Torque app has Emissions Readiness...
 Old 10-08-2014, 10:43 AM   #54
Alpha's Avatar
Rakuten.com
Awesome, thanks!
 Old 12-12-2014, 09:12 AM   #55
Alpha's Avatar
Awesome, thanks!
Bump guys... Check this out:
Before, I had all my codes go into "READY" mode except for my CAT (Since I'm catless)
Now, I've started fresh and put a secondary O2 extender on and it worked like a charm! CAT is ready, but now the EVAP won't go "READY" for ANYTHING! I've done like 3 specific drives cycles for it and nothing. Before, it only took once... WTF?
Any ideas? Gas level is 1/2-3/4 everytime and my gas cap is tight (Clicked 4 times).
 Old 12-12-2014, 11:29 AM   #56
Skierdood's Avatar
I forget, is your egr functioning, or blocked off/disconnected?
2007 True Red MS3
 Old 12-12-2014, 11:31 AM   #57
Alpha's Avatar
EGR has been deleted for a long time. The DTCs for it have been disabled too.
Just weird that the EVAP set to ready before the CAT, and now it won't. I don't get it
 Old 12-12-2014, 11:39 AM   #58
Skierdood's Avatar
Hmm yeah that is odd. Have you tried a new gas cap?
2007 True Red MS3
 Old 12-12-2014, 11:46 AM   #59
Alpha's Avatar
I just ordered a new cap and purge valve just to try em, but it seems odd that they'd just magically go out when I'm right new my emissions cutoff date lol
 Old 12-12-2014, 11:46 AM   #60
Skierdood's Avatar
Yeah it'd be an odd coincidence.
2007 True Red MS3
CEL - P0441 ( EVAP ) Caldwell Mazdaspeed3/6 General Discussion 10 04-14-2014 01:39 PM
P0455, P02187... Evap leak ItalianSA MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 04-04-2012 03:05 PM
evap system delete mrkdspd MazdaSpeed 6 - Engine, Transmission & Driveline 1 02-17-2011 10:22 PM
Very Small Leak (evap code) CEL Mizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-16-2010 01:09 AM
Frankfurt 2009: Reva NXG looks ready to stomp, NXR is ready for order Haltech Automotive News 0 09-16-2009 04:00 PM
Page generated in 0.40757 seconds with 27 queries
