 Old 05-27-2014, 09:43 PM   #1
Deblaca's Avatar
Posts: 26   (View Stats)
Deblaca is a name known to allDeblaca is a name known to allDeblaca is a name known to allDeblaca is a name known to allDeblaca is a name known to allDeblaca is a name known to all
Default Fuel Cap Stuck/Broken
Searched and was surprised I didn't see any threads on this?
I searched google as well and found a few on regular Mazda3 forums.
My fuel cap got stuck today, and I broke the cap off trying to open it. The little white part that seals the filler neck is now stuck in there at a slight angle. I have no idea how this happened, the last time I got gas I don't recall putting it on like that.
Anyways, I need to take it to Mazda tomorrow. Is there any chance that they'll cover the repair? I read about it being a TSB for the Mazda3? I don't know if that could apply to the Speed as well.
Also worth noting is the rubber cord that the fuel cap hangs on was cut, leading me to assume that this happened before.
Has anyone else experienced this issue?
Deblaca is offline   Reply With Quote
 Old 05-29-2014, 08:25 PM   #2
Scribbles's Avatar
Posts: 861   (View Stats)
Scribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the worldScribbles is the leader of the world
LOL
07 MS3
Built motor with K1 rods/wesico pistons, ATP 3076r, SS Mani, ATP DP, Cobb FMIC V2, CPE FP, TurboSmart MBC, TurboSmart Dual Port BOV, Hotchkis RSB FSB, BC Coilovers, AP, Dashhawk, Trilogy JBR 88 duro's, JBR catch can, Guardian Angel
Perm
Scribbles is offline   Reply With Quote
 Old 05-29-2014, 08:33 PM   #3
hollar1211's Avatar
Posts: 495   (View Stats)
hollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond reputehollar1211 has a reputation beyond repute
I had the exact same thing happen to me a couple weeks ago. I have an 08 ms3. I'm very careful with the way I place the cap back in and only go 1 click past right. I basically spun the black lid off and the white "plug" was left at an angle. I haven't replaced it yet because the white piece still screws down tight with the o ring. Let me know what happens if you try to go the tsb route.
2008.5 Speed3 GT
Freek Tuned e33: Cobb AP, Autotech Internals, UR Test Pipe, CPE TMIC, JBR Power Path Stage 2 SRI-TIP/ Short Shifter/ Solid Shifter Bushings/ Heavy Shift Knob/ 88 Duro RMM/ EGR Delete & Block Off Plate/ Throttle Body TIG, NGK IX 6510, 18x8 +35 Drag DR-49
hollar1211 is offline   Reply With Quote
 Old 05-29-2014, 08:45 PM   #4
Deblaca's Avatar
I ended up getting pliers and forcing it off. I just went to the dealership and bought a new one, it was about $50.
Same thing happened, it somehow got angled in there. Guy at the dealership said he used to sell 3-4 of them a day.
Anyways if you decide to that just be careful not to get any plastic pieces in the fuel tank.
 Old 05-29-2014, 09:36 PM   #5
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
dafuq? don't force the shit if it doesn't come off easy. mine gets cockeyed sometimes, and I screw it back in, THEN unscrew it. don't hulk smash the thing, common sense here.
'08 CWP MS3 w/ T3 3071r
Easter Bunny (06-02-2014)
 Old 05-29-2014, 09:41 PM   #6
Deblaca's Avatar
I tried that, it was really jammed in there and I needed gas. It was that or nothing.
 Old 05-30-2014, 06:41 AM   #7
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
I had to use a screwdriver to get this out. Ordered one online for like $10 to replace it.
 Old 05-30-2014, 12:55 PM   #8
hollar1211's Avatar
lol at hulk smash. trust me, my cap wasn't going in either direction easily. it was a struggle, and my hand could barely fit around the plug that was left. my hand was all sorts of cut up from trying to twist broken plastic.
that's exactly what mine looked like.
 Old 05-30-2014, 04:08 PM   #9
Shawn_Diggidy's Avatar
Posts: 45   (View Stats)
Shawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to beholdShawn_Diggidy is a splendid one to behold
Same thing just happened to me. I could still use the black part of the cap to unscrew the plug enough to get my fingers under it. Dealer wanted $40 for a new one. O'Rileys had it for $15.
Shawn_Diggidy is offline   Reply With Quote
 Old 05-30-2014, 01:32 PM   #10
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Mine some how got wedged in there a few weeks ago. couldn't spin it off. Ended up tapping it with a rubber mallet that i had in the trunk and it came loose.
 Old 05-30-2014, 05:23 PM   #11
hollar1211's Avatar
You guys ever see those gas caps that you screw in once and then it has like a stiff spring loaded door on the filler cap? What's the verdict on those things, crap?
I figure if I gotta buy a new one, maybe I'll buy one that I only have to screw in one time.
2008.5 Speed3 GT
 Old 06-02-2014, 06:21 AM   #12
Yousuf's Avatar
Posts: 1,398   (View Stats)
Groans: 128
It's cool and I actually prefer it that way, I see cars come with that as something to boast or something nowadays, but I wouldn't bother on a car like ours that didnt come with it
Mod-bug's back...
HU stuck sega_rt MazdaSpeed 3/6 - Car Audio & Electronics 0 06-14-2013 11:32 AM
Broken piece of broken shit won't start turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 142 09-09-2011 07:51 PM
Fuel Gauge Stuck Bovine Delight MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 05-07-2010 03:02 PM
Broken fuel line clip vbt101 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 01-05-2010 12:19 AM
Page generated in 0.33845 seconds with 28 queries
