 Old 01-03-2019, 03:22 PM   #1
Dalacy14's Avatar
Posts: 1   (View Stats)
Dalacy14 is an unknown quantity at this point
Default Fuel pressure occasionally plummets
Hello I'm relatively new to this forum and currently wanted to reach out for a little help I drive a bone stock 2007 mazdaspeed6 I do have an accessport running the stage 1 91 tune, other than that there's nothing else done to the car. Recently the fuel pressure occasionally plummets and I get a code for a fuel pressure regulator low circuit I believe. The pressure is normally sitting around 330 while I'm at idle and around1600+ while driving (hpfp act. on accessport) but occasionally it will drop down to well below 100 and hesitate badly starving for fuel. Sometimes just for a few minutes sometimes longer. My question is, could this be the high fuel pressure pump or the in tank pump with the regulator or even another issue? Any help would be greatly appreciated and thanks to anyone that takes the time to read this. I just don't want to throw parts at it if it can be avoided and the correct part can be purchased first.
Dalacy14 is offline   Reply With Quote
 Old 01-04-2019, 01:35 PM   #2
thatguy0o0's Avatar
Posts: 148   (View Stats)
thatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond reputethatguy0o0 has a reputation beyond repute
I think I would pull the HPFP and clean it...or at least take a look at it first because it is pretty easy to get to and disassemble.
2013 Speed3 w/ tech
Autotech HPFP
Cobb APV3
ETS TMIC
JBR 3.5in SRI
UR catless DP
Corksport TP
Corksport Hoodscoop
JBR RMM
Stratified e30 tune
Other Stuff:
1992 Jeep Cherokee 202,000 miles (salt/snow work horse)
2009 Toyota Rav 4 (wife has to drive something practical)
2012 Yamaha R1 Full Two Brothers exhaust & ECU flash
thatguy0o0 is offline   Reply With Quote
 Old 01-05-2019, 06:31 AM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
When the fuel pressure drops, does the AFR go crazy rich?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 08-02-2019 11:09 PM
FUEL PRESSURE HELP riflex MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 5 02-14-2018 01:00 PM
Low Fuel Pressure Cawille MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 07-28-2014 01:50 PM
fuel pressure Super Unique MazdaSpeed 3/6 - ECU Computer Tuning 5 10-31-2008 05:27 AM
Fuel pressure dip myms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 05-03-2008 12:37 PM
Page generated in 0.23580 seconds with 22 queries
