 Old 08-15-2009, 06:39 PM   #41
bnoon's Avatar
Posts: 1,770   (View Stats)
F-it. I bought one. I'll put the stock banjo bolt back in and test everything again. I'm thinking the PCV pressures can mess with the oil pressure readings I was getting at the pre-turbo oil fitting. I hope we finally have the end all be all of oil fixes this time. I'm tired of the "works for me and him, but not that guy" reputation of previous fixes on this board and others.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 08-15-2009, 07:12 PM   #42
ptperformance's Avatar
Posts: 4,123   (View Stats)
Originally Posted by Speedie6 View Post
This part is obviously a no brainer. If you will CALL ME, I will take care of getting this on order, plus some other things we have discussed.
I'm still curious as to what else we should be doing for the PCV system. Are you still going to do that super-dulux, nuclear-powered explosion-proof catch can that you had talked about before? Are you still doing the PCV relocate?
I had thought about installing a Saiku Machi using the install instructions that Cobb did with dual check valves. But, I had been waiting to see what you were doing, and what Mazda was doing. It seems like the only thing Mazda is doing is a higher quality PCV check valve? At any rate, I'd really like to formulate a final plan on this so that I can get this issue behind me.
I will call you Monday if all goes well with the clutch install over the weekend. We are still doing that catch can, we are still doing the PCV relocate, I just need a little more time to dial in the issues with mounting locations for the catch can.
We will get you taken care of next week for sure, thanks.
ordered
Thanks Aaron, when you get it can you call me? I have some additional logging I want you to do for me in the terms of knock. We have been checking on this after installs with customers cars and so far we have seen a huge reduction in knock. If you have any knock with your set up I would like to get some details from you about it after the part is installed.
Originally Posted by RUMBLEFISH View Post
Oh boy cant wait to see how this does and thanks for the effort you put into this.
Money sent.
Thanks, we have seen many happy customers so far with this.
Originally Posted by crlsnlopes View Post
paid. couldn't have come at a better time. i just installed my TP and NOW i started to smoking a little .
Not a problem, please keep me posted after the install of the part.
Thanks, I hope this is the final fix for these. We have had a 100% success rate so far with every customer that has installed one, so I expect to see this trend continue.
Last edited by ptperformance; 08-15-2009 at 07:14 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-15-2009, 07:20 PM   #43
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
Paid. Thanks John. I just moved to VA and smoke at every light, every time, without digression. They have emissions testing and crazy tree huggin laws so hopefully this works. I smoke within 60 seconds of turning on the car.
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 08-15-2009, 07:22 PM   #44
You are the people we are trying to get this part out to. That is why we started to sell them before the pat pending process was started. Thanks for the order.
 Old 08-15-2009, 09:00 PM   #45
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
i dont know where your living in va but ive been living here for 22 years and i have never once had to get an emissions check to get my inspection completed nor heard of anyone getting a ticket for emissions.
09 MGM MS3
 Old 08-15-2009, 09:18 PM   #46
Poohster's Avatar
Posts: 353   (View Stats)
Originally Posted by ptperformance View Post
Thanks, there is still some testing that needs to get done with the part and knock control. We suspect that the knock at 2700 RPM might be coming from the PCV system shutting down, if that is the case we will be reporting back on this.
Thank you.
Hi John,
I was re-reading everything (probably because I am very excited!!) and noticed one of your replies. Am I mixing apples and oranges here? This testing is not the smoking turbo fix? or is this testing the PCV re-locate?
This little smoking turbo fix is not going to induce knock, right? Sorry, I got a little paranoid.
Again thanks for all the hard work.
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 08-15-2009, 09:27 PM   #47
just ordered john i hope this thing works. I will take out my bnoon bolt and give this a try. does it go in the upper pcv hose coming off of the valve cover or the one that you have to access from underneath?
09 MGM MS3
 Old 08-15-2009, 09:50 PM   #48
aragorn764's Avatar
Posts: 172   (View Stats)
aragorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond reputearagorn764 has a reputation beyond repute
Paid, hope this works!
Cobb:
Turbo Inlet
AP (St1+SF v1.05)
SRI
Springs
RSB
Forge BPV V2, TWM BB, TRZ MM, 18x8 OZ Ultralegarras (matte black), 235/40 FK452
aragorn764 is offline   Reply With Quote
 Old 08-15-2009, 10:38 PM   #49
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
john, Ill give you a call when I get mine in.... and we can discuss whatever it is you wanted to regarding the knock, more than happy to help
 Old 08-15-2009, 11:15 PM   #50
708
Erich's Avatar
Posts: 4,274   (View Stats)
Originally Posted by Poohster View Post
Hi John,
Quite the opposite. I have been working for a while to eliminate my part throttle knock with ATR with no luck. I can reproduce the part throttle knock fairly consistently at around 2750 RPM in 4th gear between .35 and .5 load (easiest to achieve on a slight incline.) In looking at the part throttle knock, one thing was always occurring, my intake pressure was in vacuum and transitioning from between -1 and -5 to between -7 and -10. It occurred to me that this may also be creating a condition where the PCV valve was going from closed to open.
Even though I wasn't smoking I asked John to install the fix to test if it had any effect on part throttle knock. Drove the 4 miles to John's house (intentionally inducing knock several times on the way) and had him install the part. I then drove around for a bit (about 10 miles total) trying to induce knock. I could not.
Now I am not willing to say that this fixed the knock yet as there are occasions (though rare) that I simply will not get any knock. I will do so more testing tomorrow, and then for the next week trying to induce part throttle knock. I will post back tomorrow and then after a week (or before if it turns out this actually has no effect on part throttle knock) but for now I will say that it looks encouraging.
The Following 3 Users Say Thank You to Erich For This Useful Post:
aragorn764 (08-15-2009), Poohster (08-16-2009), ptperformance (08-16-2009)
 Old 08-15-2009, 11:21 PM   #51
steven88's Avatar
Posts: 773   (View Stats)
steven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the worldsteven88 is the leader of the world
Groaned at 9 Times in 5 Posts
where does this exactly install? can we see a pic?
i am not smoking at the moment...running full catless exhaust....however I am still interested in purchasing this if this will benefit my car in the long run....and if it will help smooth en out any kind of unwanted knock retard
steven88 is offline   Reply With Quote
 Old 08-15-2009, 11:21 PM   #52
austin102085's Avatar
Posts: 1,195   (View Stats)
i got smoke so ill try anything..... paid
2008.5 Mazdaspeed 3
513whp MS3<-- for now (sold)
 Old 08-15-2009, 11:45 PM   #53
Speedie6's Avatar
Posts: 1,838   (View Stats)
He has said that he doesn't want to fully disclose as it is too easy to copy and he spent time/money figuring out the problem.
 Old 08-16-2009, 12:20 AM   #54
kgb
kgb's Avatar
Posts: 808   (View Stats)
kgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the worldkgb is the leader of the world
Groans: 88
I ordered and will but stock boone bolt back in. But I will also lower my idle a bit too. Assuming 1 month from now this fix is THE fix, what oil weight is the best to use and more specifically, for a Tampa resident? I have amsoil 10w-30 in now. I ask the question because people were changing their oil weights to combat the smoking issue although the change may not have been optimal.
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
kgb is offline   Reply With Quote
 Old 08-16-2009, 01:09 AM   #55
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
HAHAHA. I bought one. I'd love to see anything stop my chimney from smoking. Money Back guarantee FTW.
 Old 08-16-2009, 09:47 AM   #56
11cruzito11's Avatar
Posts: 824   (View Stats)
11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world11cruzito11 is the leader of the world
Groaned at 5 Times in 2 Posts
PTPerformance,
How long will this GroupBuy last for the Price of $25?
Also, I saw that there is money back guarantee, is it 100% refunded back?
Thanks,
11cruzito11 is offline   Reply With Quote
 Old 08-16-2009, 10:25 AM   #57
stealthspeed6's Avatar
Posts: 136   (View Stats)
stealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant futurestealthspeed6 has a brilliant future
well we will all find out when we get them so then what will he do?
stealthspeed6 is offline   Reply With Quote
 Old 08-16-2009, 10:43 AM   #58
Miembro
nighthawk358's Avatar
Posts: 725   (View Stats)
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
ptp is it $25 shipped?
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 08-16-2009, 11:16 AM   #59
m4tic's Avatar
Posts: 4,928   (View Stats)
patent pending....
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 08-16-2009, 11:27 AM   #60
Speedn3's Avatar
Posts: 642   (View Stats)
Speedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond reputeSpeedn3 has a reputation beyond repute
funds sent....
Order Number: 4101
small price to pay for your time on the r&d john.
thanks
Speedn3 is offline   Reply With Quote
 Old 08-16-2009, 11:37 AM   #61
708
Erich's Avatar
patent pending....
Or just plain common decency.
 Old 08-16-2009, 11:44 AM   #62
Hi John,
Yes this is the smoking turbo fix not the PCV relocate. It will not induce knock but probably cure knock (still testing). So your good to go with zero negative side effects. Thanks.
You will see when you get the directions for the part where it goes, it does go in a hose but not the one you would think.
Thank you.
Sounds good, we need some people that can induce knock so we can verify that this is fixing the part throttle knock issues.
There will be pictures posted up Tuesday as to where this part goes.
This should fix your smoking issues.
I would run what the FSM says to run. The oil weights was just a bandaid to try and fix the problem, our fix is correcting the system faults.
Thanks, keep me posted on the part install and if it fixes the chimney.
Originally Posted by 11cruzito11 View Post
PTPerformance,
Thanks,
Yes, 100% refund if the smoking doesn't stop.
I will be posting pictures on Tuesday where the part goes. We have an appointment on Monday with the patent attorney to get the papers started. That is how we are going to protect this idea.
Yes it is.
Originally Posted by Speedn3 View Post
funds sent....
Order Number: 4101
thanks
Thanks, that was the idea. Charge something that was fair but still allowed me to recoup the R&D time. Several people said to sell if for $99 and others said $50, I said get this out there for the masses and rely on the fact that people will start talking about it across the internet that the smoking turbo, part throttle knock (still testing) and possible better motor life are all attainable with a $25 part. We determined that 4000 units/sales would be market saturation and if the part works 1/2 as good as we have seen, that should be easy.
We will see, never hurts to have a back up plan (pat pend). I would suspect that Mazda might catch wind of this as well and we might be in talks with them before to long, but that might be a stretch of the possibilities. Only time will tell.
Last edited by ptperformance; 08-16-2009 at 11:46 AM. Reason: MSF Database - Automerged Doublepost
 Old 08-16-2009, 12:10 PM   #63
When does the group buy for $25 end?
 Old 08-16-2009, 12:33 PM   #64
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
just sent payment. thanks.
GoSpeed3Go is offline   Reply With Quote
 Old 08-16-2009, 01:32 PM   #65
708
Erich's Avatar
To update on knock. I was able to induce knock this morning going from cold. However, just hitting operating temperature from cold, I can usually induce knock at will (like 99% of the time) over and over. This morning, I was only able to get knock twice, slightly lower in the RPM range and just before operating temperature was achieved. Once the car was up to temperature, just like last night, I could no longer induce knock at all no matter how hard I tried.
This will obviously require a bunch more testing to determine if this does in fact help to reduce part throttle knock. I will be going out on random drives a bunch this week when I start from a cold car. Will keep this thread updated with my results. I will also pull the part out at some point and see if I can induce knock again with it out (after driving with it in and not being able to induce knock.)
 Old 08-16-2009, 02:03 PM   #66
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
ordered, cant wait to try this!!!!!!!
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 08-16-2009, 02:46 PM   #67
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Just paid for pcv fix... Also purchased your HPFP!
 Old 08-16-2009, 02:52 PM   #68
Redsand426's Avatar
Posts: 134   (View Stats)
Redsand426 can only hope to improve
just ordered. going to put my test pipe back on!
06 Black Mica MS6
Redsand426 is offline   Reply With Quote
 Old 08-16-2009, 05:12 PM   #69
It will end after we have sold 50 units.
Thank you!
Erich, thanks for all the help and testing data. I appreciate it and I am sure that all the others here on the forums appreciate it as well. I will have one other local that is going to start monitoring the knock condition as well. I will also be starting a thread as customers start to get there oil burning fix to report back on any and all knock issues.
Thank you!
Thanks, all should be shipping out Tuesday.
Let us know how it works for you after you get the test pipe on. Thanks for the order.
 Old 08-16-2009, 07:51 PM   #70
black-speed3-gt's Avatar
Posts: 46   (View Stats)
black-speed3-gt will become famous soon enough
count me in plz thx
black-speed3-gt is offline   Reply With Quote
 Old 08-16-2009, 07:58 PM   #71
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
Just purchased you part! i have tried every option possible and i still smoke! i even ordered a pg rerworked k04 just finally came in this saturday. But now im thinking if i should wait and test this part before i install the turbo. I kinda wish i had ordered your sst insteed but it to late now
 Old 08-16-2009, 08:04 PM   #72
Realgib3's Avatar
Posts: 2,443   (View Stats)
really really really wish I would have picked this up before I blew up today
 Old 08-16-2009, 08:07 PM   #73
John,
My order has been paid and submitted. Can wait to try this fix!
 Old 08-16-2009, 09:20 PM   #74
Miembro
Groans: 27
ptp..when i went to your site it said that the total price would be $35 because of shipping to PR.. is there an extra shipping cost of $10 in the purchase if i buy it right now in the GB?
 Old 08-16-2009, 09:40 PM   #75
tagkat's Avatar
Posts: 269   (View Stats)
tagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to beholdtagkat is a splendid one to behold
Just ordered. No DP but hope that this will solve the PT knock. Plan on getting one in the future so maybe this will prevent problems.
tagkat is offline   Reply With Quote
 Old 08-16-2009, 09:48 PM   #76
JmkC's Avatar
Posts: 871   (View Stats)
JmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the worldJmkC is the leader of the world
Groans: 109
payment sent.
JmkC is offline   Reply With Quote
 Old 08-17-2009, 12:07 AM   #77
kgb
kgb's Avatar
Groans: 88
Como what? What happened? Can you give us details on what happened just before you blew like was the clutch vibrating, did you hear anything funny, etc...were you datalogging by any chance?
If you would like to share your story, can you start a new thread about it?
Sorry to hear
 Old 08-17-2009, 12:08 AM   #78
essejkcamraw's Avatar
Posts: 922   (View Stats)
im smoking within a couple minutes of startup so, PAYMENT SENT!
 Old 08-17-2009, 02:40 AM   #79
evidence's Avatar
Posts: 1,033   (View Stats)
Sorry to hear
I checked out his last posts and found he commented in his own thread below, also asked him to make a new post a while ago, I guess we can use this one to prod him for now though so we don't clutter ptp's:
http://www.mazdaspeedforum.org/forum/foru...ean-w-ffs.html
Some things.
 Old 08-17-2009, 03:16 AM   #80
Cosmic3MPS's Avatar
Posts: 355   (View Stats)
Cosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the worldCosmic3MPS is the leader of the world
Groans: 31
Groaned at 22 Times in 10 Posts
Hi John,
I would like to try this. Can you ship to Australia? There is now option for this on your website.
Cheers
How to deflower virgins:
At the crucial point the guy bites her on the ear. Distracts from the pain. Ever try that?
Mitch: Hell no, I sock 'em in the jaw and yell, "Pop goes the weasel."
Cosmic3MPS is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/gb-smoking-turbo-fix-35601/
Veivhus/topplokk ventilasjon? This thread Refback 07-05-2013 10:04 AM
TurboNines.com - VRT smoke problem This thread Refback 06-18-2013 05:52 PM
Blown engine theory - Page 19 This thread Refback 04-04-2012 05:40 AM
Fixing "white smoke" problem (not in warranty) - in Melb - Page 5 This thread Refback 04-01-2012 07:07 PM
VWVortex.com - VRT smoke problem This thread Refback 11-04-2010 04:55 PM
Veivhus/topplokk ventilasjon? - VACN Medlemsforum This thread Refback 06-22-2010 01:29 AM
VRT smoke problem This thread Refback 06-14-2010 12:09 PM
Fixing This thread Refback 04-29-2010 11:45 PM
Blown engine theory This thread Pingback 04-14-2010 10:43 PM
Turbo seals toast??? - Page 5 - Ottawa Mazda This thread Refback 08-20-2009 03:54 PM
Modified car? - Ottawa Mazda This thread Refback 08-20-2009 03:50 PM
PTP's Smoking Turbo Fix - TorontoMazda3 This thread Refback 08-18-2009 03:50 PM
PTP's Smoking Turbo Fix - TorontoMazda3 This thread Refback 08-18-2009 10:08 AM
Im in the smoking turbo club.:( SharkDiver MazdaSpeed 3/6 - Turbo Induction 154 09-26-2012 10:16 AM
Smoking turbo issue - Gone for me! kgb MazdaSpeed 3 - Engine, Transmission & Driveline 16 05-27-2009 03:56 PM
Causes/Solutions: Smoking turbo after DP Install kgb MazdaSpeed 3/6 - Turbo Induction 28 02-25-2009 10:58 AM
ANOTHER Smoking Turbo... div2 MazdaSpeed 3/6 - Turbo Induction 23 10-22-2008 07:27 PM
My turbo was replaced under warranty last month and it's smoking again!! BlackMS3 MazdaSpeed 3/6 - Turbo Induction 34 07-26-2008 09:34 PM
Page generated in 0.62158 seconds with 50 queries
