![]() | | #41 | ![]() |
| Big Titty Sucker ![]() Join Date: Nov 2010 Location: NY
Rep Power: 744 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 579
Groans: 139
![]() | | #42 | ![]() |
![]() Join Date: Mar 2010 Location: Athens GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 491
Groans: 214
Groaned at 114 Times in 83 Posts
| Not Ranked : 0 score Correct. My apologies for any slight misunderstanding. Usually when we speak of a car being "faster" we mean 0-60 and 1/4 times.
__________________ |
![]() | | #43 | ![]() |
![]() Join Date: May 2009 Location: Orange County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 806
Groaned at 9 Times in 5 Posts
| Not Ranked : 0 score No hate from me on the Gen 2. They fixed my major grip from the Gen 1 - suspension. The wider tires are nice plus as well. I think the low end grunt people experience are just a result of retaining the factory intake. Having said that, there's really no substitute for the sleeper appeal of the Gen 1. The Alecantra and piano black accents are just icing on the cake. |
![]() | | #44 | ![]() |
![]() Join Date: Mar 2010 Location: Chicago
Groaned at 3 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score Question about the gearing on Gen 2. Everyone always talks about how the gearing is longer, and the specs as well. Yet the shifting points are almost exactly the same, I mean 1st gear is roughly 30mph, 2nd is 50mph, doesnt go to 60...3rd is about 80, same as gen1..Is this because the tire diameter of the gen2 is smaller than gen1? I figured longer gearing would mean higher speeds in each gear! |
![]() | | #45 | ![]() |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
Groans: 31
| Not Ranked : 0 score 1st gear is the same, so it should be very similar. 2nd-5th are geared higher, and the main area that you notice this is roll racing from proven speeds in a given gear on the gen 1. A 40mph roll in 3rd on a gen 1 is the sweet spot, but the gen 2 will bog there. Get the gen 2 up to about 45mph in 3rd, and it's perfect. The gearing isn't going to be extremely different, but it is definitely higher. |
![]() | | #46 | ![]() |
| Ur moms boyfriend ![]() Join Date: Jul 2010 Location: Chicago, ILL
Rep Power: 1272 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 923
Groans: 70
| Not Ranked : 0 score 1st gen is faster in 0-60, but the 2nd gen is faster in the 1/4 |
![]() | | #47 | ![]() |
| Two nuns and a pack mule ![]() Join Date: Jan 2010 Location: Virginia Beach, VA
Rep Power: 595 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 459
| Not Ranked : 0 score Oh no, not this shit again...
![]() | | #48 | ![]() |
![]() Join Date: Mar 2008 Location: Oceanside, CA
Rep Power: 2852 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 676
Groans: 106
| Not Ranked : 0 score who fucking cares. same engine. they both arent in the 11's... so they both SUCK!!!!
__________________ 13.2@111 CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
http://jpnutritionandfitness.blogspot.com/ Sponsored By: CP-E | |
