 Old 09-06-2008, 01:15 AM   #81
Jackal
Breakdown81's Avatar
Posts: 869   (View Stats)
Breakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the worldBreakdown81 is the leader of the world
Groans: 56
Im very interested as well. I think the tmic options out right now are very limited, in part because most people are used to seeing fmic setups so thats what the market gravitates towards. I don't see any reason why with a bit of R&D TMIC setups wouldnt be able to perform in the same capacity as FMIC setups.
Breakdown81 is offline   Reply With Quote
 Old 09-06-2008, 08:37 AM   #82
evo2ms3's Avatar
Posts: 287   (View Stats)
evo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the worldevo2ms3 is the leader of the world
Originally Posted by jahman View Post
I also need a little more info on installation. I'm trying to figure out exactly what tru boost was saying you need to cut. If I cant put the car back to stock condition, thats also going to be a problem for me.
Same here, but still interested regardless.
evo2ms3 is offline   Reply With Quote
 Old 09-06-2008, 12:46 PM   #83
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
yeah, it needs to be able to be put back to stock since a lot of people want to be able to go back to stock quickly... if this isn't possible i'll just go with a fmic.
 Old 09-06-2008, 01:35 PM   #84
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
Originally Posted by subparpunk03 View Post
A thought about the coils inside the intercooler.... if you run CO2 through them, won't condensation form? Potentially large droplets?
I like the idea of those coils, but I think I'd prefer to just run my water injection and call it a day. Any way to get the IC without the CO2 stuff?
Hmm... good point there. Definitely worth some investigation. Common sense would probably say it would. It's on the cold side, so it's close to the throttle body. CO2 goes from a gas to a liquid at abou minus 57 degrees C. That shit's pretty cold!
Frequentflyer is offline   Reply With Quote
 Old 09-06-2008, 02:02 PM   #85
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
There would need to be a LARGE amount of condensation before it could damage anything.
 Old 09-06-2008, 02:07 PM   #86
NEC
subparpunk03's Avatar
Posts: 1,267   (View Stats)
Thats what I'm thinking... and big droplets of water have no business inside a cold pipe. My AC lines get condensation... and super cold CO2 will almost certainly cause whatever moisture is in the air to cling to the coil... Even if its not spraying CO2 the coil will stay cold and under light throttle the air is moving slowly enough to cause the condensation to form... then when you go FT it'll pick those poorly atomized droplets up.
Probably won't cause too much issue.... but I don't like the idea of not having control over that. With my water injection I know I'm getting high atomization that will spread evenly through the intake, and I know WHEN its injecting.
I dig this IC... but I'd like to see more technical details... does condensation actually form, what is it capable of flowing, etc.
I really think this IC would be better without the CO2 stuff... but I'd like to know what TRZ thinks about that and whether or not I'm talking out of my ass here.
2006 Lotus Elise: Toy car
2007 Mazdaspeed 3: *sold*
2005 Corolla XRS: *sold*
 Old 09-06-2008, 04:05 PM   #87
Groans: 60
I think your reading too much into it. There will be very little if any condensation if your not running the CO2(you probably pull in more water when it rains), if you do run the CO2through it, any condensation on the pipe will freeze and you'll only get a small amount of water vapor as it melts away...
 Old 09-06-2008, 05:15 PM   #88
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
the little dropplets wont be nearly as much as water injection would inject, and if anything will only help cool the mixture more. i plan on testing it soon. there is only one other company i have found using a similar design and they have AWESOME results.
i could have went TMIC for even cheaper if i had TRZ do it for me, but i dont want it.
in MOST situations you dont get extra benefits from it. but hey thats a whole nother debat thread !
TRU-BOOST is offline   Reply With Quote
 Old 09-06-2008, 09:39 PM   #89
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
could they offer the c02 as a option. that would keep it price competitive at least. just curious.
 Old 09-06-2008, 09:57 PM   #90
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
so just to summarize ... this TMIC is supposed to lower boost temps by 20% below AMBIENT?
Are my Dashhawk numbers that far off... Today my AAT was 63deg, while my IAT was 84deg .... and my boost temps were 105deg and only dropping to 95 under boost. Is the stock intercooler that bad, or are my numbers off.
GQ_WhiteMS3 is offline   Reply With Quote
 Old 09-06-2008, 10:13 PM   #91
NEC
20% below ambient is with the CO2 system.
As far as condensation on the CO2 coils... I know a small amount of water won't hurt the engine, but actually helps. The thing is that its just another X-factor... and theres no way for me to control the amount of water that goes into the engine like there is with the WI.
Maybe I'm just being paranoid about it.
 Old 09-07-2008, 10:31 AM   #92
bnoon's Avatar
Posts: 1,770   (View Stats)
Interested in seeing if there are any NON-CO2 gains over ETS. Offer it without the CO2 as an option perhaps?
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 09-07-2008, 03:46 PM   #93
TRU-BOOST's Avatar
your numrs are right. so the temp at your MAF is 84 degrees and after it is heated by the turbo and then cooled by the IC it is 105. that is actually pretty good. that is about an 81% efficiency rate. thats is actually fantastic for a TMIC..... hell i bet most FMIC's dont see much better than that.
the 20% below ambeint temp statement was based on use with the co2 running. and yes i do believe IF this is offered it can be added as an option. even without it, the cost would still be more than ETS though. for the simple fact that ETS makes their own cores. TRZ has to buy their cores for $300 by itself !!
 Old 09-07-2008, 04:07 PM   #94
skeeter149's Avatar
Groans: 91
well at least the option is there.
 Old 09-08-2008, 02:04 PM   #95
wisniaPl's Avatar
Posts: 933   (View Stats)
wisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond repute
so when they are going sell them??
wisniaPl is offline   Reply With Quote
 Old 09-08-2008, 02:10 PM   #96
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
hey how do the coils work? they don't spit co2 into the engine do they?
 Old 09-08-2008, 05:50 PM   #97
ILL3ST
xcoldricex's Avatar
co2 makes the coil cold which makes the air cold.
 Old 09-09-2008, 12:27 AM   #98
CaptainKRM's Avatar
Posts: 620   (View Stats)
CaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the worldCaptainKRM is the leader of the world
after talking to Mike down at TRZ today, he is reviewing this thread to gauge interest and base his decision based in part on that and pending install of this intercooler
CaptainKRM is offline   Reply With Quote
 Old 09-09-2008, 08:21 AM   #99
TRU-BOOST's Avatar
my guy at forge told me my couplers shipped last FRI. so i should be getting them any day now. once they get here i am ready to install !!
to answer your question GSRTYPE1.........
no the co2 is not injected. it simply goes in one side and out the other. you can just let it vent to the atmosphere or try to use it further like i will. i will be purging the system through a spray bar mounted on top of it.
 Old 09-09-2008, 02:14 PM   #100
Alittle Faster
bioevolve's Avatar
Posts: 3,522   (View Stats)
Awaiting results, cuz that will solve my FMIC vs TTFMM.
bioevolve is offline   Reply With Quote
 Old 09-12-2008, 11:51 AM   #101
jahman's Avatar
Posts: 903   (View Stats)
jahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the worldjahman is the leader of the world
Groaned at 9 Times in 7 Posts
updates?
07 Mazdaspeed3
jahman is offline   Reply With Quote
 Old 09-12-2008, 03:41 PM   #102
zer0's Avatar
Posts: 50   (View Stats)
zer0 is a jewel in the roughzer0 is a jewel in the roughzer0 is a jewel in the rough
that was going to be my question, if the system could be hooked up to a spray bar on top. . . .. .
but something i havent heard anyone address, is .. . .. . Is anyone tried using a TMIC spray bar yet? im very curious if there is going to be clearance issues, or if it will even fit on top..
i would really like to run a TMIC with co2 and with a sprayer. insted of a FMIC. so if this all works out i might be very intrested. and would like to know if anyone has had success with a TMIC co2 sprayer.
zer0 is offline   Reply With Quote
 Old 09-12-2008, 03:49 PM   #103
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
I used to spray nitrous on my stock tmic over a year ago. It deffinately made a difference, but the heatsoak fried the solenoid after a winter of not being used at all. I don't think there's room for a spraybar in the duct with an ets though. Mine was rubbing against the tmic shroud and even wore through it a little.
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 09-12-2008, 05:43 PM   #104
CaptainKRM's Avatar
we have a customer who will be running the Cryo2 system and coil atop his intercooler. it should clear without a problem, just placing the tank and running the lines would be at the customer's discretion.
tru-boost called me from the road today, its on the car and he showed Dash Hawk gains of 3psi over the stock TMIC. i'll let him post more impressions and such when he gets time.
 Old 09-13-2008, 08:15 AM   #105
wisniaPl's Avatar
so i ahve question whe3n they gona release them??
 Old 09-13-2008, 08:17 AM   #106
3 psi? nice, should call it the big mouth top mount if its pulling that much boost down over stock.
 Old 09-13-2008, 09:57 AM   #107
CaptainKRM's Avatar
production could be started any time, the issue is seeing actual demand. everyone on a forum could say that they want one, then half of the people will commit, then half of those still will back out and leave standing the actual number of people who'd pay for one. not to sound like a pessimist, this is just what tends to happen on a product like this on a forum
preliminary details are out there, price (generally) is out there, pictures are out there. everything else aside, i'd like a list - cut and paste your name to it - of people who really want this intercooler and want to see it happen. this will be what i'll pass along to TRZ to push forward.
example;
1) tru-boost
2) captainkrm
3)
 Old 09-13-2008, 11:56 AM   #108
wisniaPl's Avatar
1) tru-boost
2) captainkrm
3) wisniaPl
 Old 09-13-2008, 12:07 PM   #109
TRU-BOOST's Avatar
OK let me address this stuff..... the CO2 sprayer will fit on this IC with no problem what so ever. this IC does not use the big eye sore shroud like ETs and auto exe. that being gone leaves plenty of room for the lines to be ran up to the bar. i will be installing this set up soon. i hope to fix my cut/spark issue first, so i can see maximum gains with high boost.
i did in fact see a 3psi gain with no changes other than the IC swap !! the car spools up very fast and i see the extra 3psi through most of the mid range. up top it seems to hold 1-2psi more at redline. last night 4th gear held 17psi until the rev limiter hit !!
i think much of the gains are from the cold pipe. that stock thing is TRASH ! i feel sorry for those with another TMIC upgrade. all that great flow from a good core that gets bottlenecked by that pipe is a waste !
look at this bad boy ! if you really want one add your name to the list to let TRZ know !
 Old 09-13-2008, 12:30 PM   #110
wisniaPl's Avatar
what couplers are those?? will trz include them with tmic??
 Old 09-13-2008, 12:31 PM   #111
arkenzo's Avatar
Posts: 218   (View Stats)
arkenzo is a jewel in the rougharkenzo is a jewel in the rougharkenzo is a jewel in the rougharkenzo is a jewel in the rough
Groaned at 84 Times in 39 Posts
I WANT!!!!
arkenzo is offline   Reply With Quote
 Old 09-13-2008, 12:37 PM   #112
TRU-BOOST's Avatar
those are silicone coupler from FORGE. yes TRZ will provide everything that is needed to do a complete install. if they decide to go ahead with production they want to get a car in their shop in KISSIMMEE FL to make another one. mine fits well but they say with a car in their shop they can make it perfect.
i know i mentioned it before but for those new to this thread you do have to remove the rubber seal that hangs down under the hood. you also have to cut out a chunk of the plastic under the hood to fit the massive 3" cold pipe.
i know some people are weary abou that kind of stuff, but trust me ITS WORTH IT !! that is what makes it better than all the comp as an IC by itself. add the CO2 option and nothing can come close !
 Old 09-13-2008, 01:46 PM   #113
ILL3ST
xcoldricex's Avatar
can you show what needs to be modified?
i think many people are interested because they want to keep warranty and have an easy way to go back to stock. if a large noticable chunk has to be cut out and is not replaceable - then i think interest would be a bit less - especially since the price difference between this and a FMIC isn't all that much.
 Old 09-13-2008, 02:58 PM   #114
TRU-BOOST's Avatar
i will get a pic of it later i have to roll out for the night in a min. it is a good size chunk and wont be replaceable.
 Old 09-13-2008, 04:38 PM   #115
Waiting for prices with/without the CO2 coil.
 Old 09-13-2008, 07:08 PM   #116
Alittle Faster
bioevolve's Avatar
I've been looking at the 3.5" ETS for awhile now, but this TRZ one looks better. I just can't wait! I've got an itchy "Buy Now" finger and ain't afraid to use it. The waiting is killing me.
 Old 09-13-2008, 07:18 PM   #117
MZRDISI4
Lurkers
MZRDISI4's Avatar
Posts: n/a
helloooo people
1) tru-boost
2) captainkrm
3) wisniaPl
4) MZRDISI4
 Old 09-13-2008, 07:58 PM   #118
black leaf's Avatar
Posts: 18   (View Stats)
black leaf will become famous soon enough
I'd like to firm commit, but to do that, I need to know the firm price. It's only fair.
black leaf is offline   Reply With Quote
 Old 09-13-2008, 08:24 PM   #119
NEC
Ah what the hell....
1) tru-boost
2) captainkrm
3) wisniaPl
4) MZRDISI4
5) subparpunk03
 Old 09-13-2008, 08:35 PM   #120
shadesofgray19's Avatar
Posts: 794   (View Stats)
I am not a fan of how long the couplers are, maybe this is part of what they need a test fit car for. It appears the cold pipe could be fabricated a little better to decrease the coupler lengths. I also am having a hard time of seeing where the BPV is located and how easily it mates up to the intake for the recirc hose. Another question, how do you see 3 psi more boost from just installing a tmic? This is a pressurized system that should bleed off boost over the stock 15ish psi no matter the pressure lost through the IC. I would like to see core testing for efficiency, pressure drop, and dyno numbers for completely stock car with this IC. Still early and too many questions to commit to an almost $700 tmic.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/gi-trz-top-mount-intercooler-10928/
TRZ about to release a TMIC for speed3/6s!! - Carolina Mazdas This thread Refback 11-18-2008 02:35 PM
MS3 TRZ TMIC upgrade Pics UP !! This thread Refback 09-07-2008 01:45 AM
MS3 TRZ TMIC upgrade Pics UP !! This thread Refback 09-05-2008 06:00 PM
MS3 TRZ TMIC upgrade now available.... This thread Refback 09-04-2008 06:26 PM
MS3 TRZ TMIC upgrade now available.... This thread Refback 09-04-2008 11:14 AM
MS3 TRZ TMIC upgrade now available.... This thread Refback 09-04-2008 12:14 AM
MS3 TRZ TMIC upgrade now available.... This thread Refback 09-03-2008 05:27 PM
MS3 TRZ TMIC upgrade now available.... This thread Refback 09-03-2008 01:13 AM
MS3 TRZ TMIC upgrade now available.... This thread Refback 09-03-2008 01:02 AM
MS3 TRZ TMIC upgrade now available.... This thread Refback 09-03-2008 12:56 AM
Cobb Tuning Mazdaspeed 3 FMIC (Front Mount Intercooler) Part 2 - Follow Up Haltech Mazdaspeed Forums Performance Parts Reviews 0 06-23-2008 02:26 AM
Cobb Tuning Mazdaspeed 3 FMIC (Front Mount Intercooler) Haltech Mazdaspeed Forums Performance Parts Reviews 0 06-19-2008 06:00 AM
front mount or top mount? occschemguy MazdaSpeed 3/6 - Turbo Induction 32 05-06-2008 10:15 PM
I need this intercooler Zeya Mazdaspeed3/6 General Discussion 5 04-19-2008 03:56 AM
Page generated in 0.55795 seconds with 40 queries
