  • 1 Post By MSMS3
  • 1 Post By Fstrnyou
 Old 01-11-2019, 11:32 PM   #1
Zaos's Avatar
Posts: 9   (View Stats)
Zaos is an unknown quantity at this point
Default Good color within engine bay? MS6
I have a red speed 6 if it helps (engine bay is red)
Kinda wondering, I just finished priming both the intake manifold and the valve cover. What color should I make them? Really torn between an aluminum gray, or a darker bronze dark gold kind of color (red and gold look alright imo).
You guys think doing a gold type paint would look too ricey?
Zaos is offline   Reply With Quote
 Old 01-12-2019, 10:55 AM   #2
MSMS3's Avatar
Posts: 2,826   (View Stats)
Aliminum Gray. Like new OEM. If you must change color, how about a wrinkle texture satin black? Bright colors seem like rice to me.
LenSpeed6 likes this.
 Old 01-12-2019, 11:44 AM   #3
Zaos's Avatar
The only reason im really meh in black js because it'll make it harder to see if there's an oil leak. I'm not talking about a bright gold that'd be terrible, more so a very dark satin sort of gold. Thanks
 Old 01-12-2019, 11:48 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Any time I had dirty engine parts off, I cleaned and repainted them an aluminum/silver or light gray color.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
MSMS3 (01-13-2019)
 Old 01-13-2019, 05:01 AM   #5
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
I vote silver, sorry for the huge picture if it even went threw...
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 01-13-2019, 07:06 AM   #6
Fstrnyou's Avatar
Damn Len. You went HAM with the silver.
I painted my timing cover and oil pan a color called "Cast Aluminum". It's not quite as sparkly silver as the aluminum color. I'll have to find the pic. I think it's on my other device.
Other rides:
History:
 Old 01-15-2019, 02:12 PM   #7
LenSpeed6's Avatar
yes most everything silver lol even intake manifold, maybe when I take everything back out I'll even do the trans and pro lol
06 Speed6
 Old 01-13-2019, 11:29 PM   #8
Jayzon's Avatar
Posts: 103   (View Stats)
Jayzon has disabled reputation
between your two options I vote aluminum gray
Back to Stock
Jayzon is offline   Reply With Quote
 Old 01-15-2019, 06:18 PM   #9
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
wrap dat shit in carbon fiber bruh
94 M
MS6
IS350
 Old 01-16-2019, 08:03 AM   #10
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
light colors help to see oil leaks source lol Black is bad at that.
Since i'm not washing my engine bay every week, flashy colors and cleared parts are worst with dirt on them.
I personally likes the wrinkle paint red or black for the VC. It remember me older engine at time they don't hide it with plastics....
Don't forget you may need to sell it someday so a softer color choice may help.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 01-16-2019, 09:02 AM   #11
Fstrnyou's Avatar
Don't forget you may need to sell it someday...
That's blasphemy. You should be demoted.
Other rides:
History:
 Old 01-17-2019, 06:23 AM   #12
Jeff23spl's Avatar
Right!
Btw i sent you a question by pm.
Wife drive 2010 CX7
 Old 01-17-2019, 07:42 AM   #13
Fstrnyou's Avatar
I had responded to that, but apparently got cock blocked because my inbox was full...because I haven't renewed my account...yet.
Other rides:
History:
 Old 01-16-2019, 02:34 PM   #14
LenSpeed6's Avatar
Just me personally, I think that bright colors are tacky. Thats why I went with silver, actually it was called aluminum oddly enough haha. I don't have a good picture of the engine bay to show everything I painted so far, damn TMIC ruins it.
Sorta off topic, I had a 03 Grand Am back in the day that I painted the calipers orange because it looked cool but the upkeep on them to keep them looking good sucked and painted them black. I now paint brake stuff semi-gloss black. Its way easier if you run in a situation where you have to replace a caliper or something quick in the winter, you can just rattle can it until you have time to put the good paint on it. Im even anal enough to paint the hats and vines on rotors black if they arent already.
06 Speed6
 Old 01-16-2019, 03:44 PM   #15
Fstrnyou's Avatar
When I serviced my rear brakes, I painted the calipers black. If/when I upgrade the fronts, they will be black.
Other rides:
History:
ETC: How A Car Engine Works infographic moves us in a good way Haltech Automotive News 0 09-08-2013 11:40 AM
Good accent color for cosmic blue? MazdaSpeed3NY Appearance - COSMIC BLUE 2 07-19-2012 01:45 PM
HP Color LaserJet 1600 - printer - color - laser $149.99 or less Haltech Hot Deals Section 0 04-04-2008 09:50 AM
Page generated in 0.34543 seconds with 27 queries
