 Old 04-01-2008, 10:42 AM   #1
Performance Racing's Avatar
Posts: 193   (View Stats)
Performance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nicePerformance Racing is just really nice
Default Got Gauges? Defi, Autometer, Blitz, GReddy, AEM, More!
We've got an incredible amount of stock on a wide variety of gauges!
I want to start by stating ALL items are shipped FREE Ground with Insurance and Tracking within 1-2 days unless specified.
I'll first introduce the Defi Racer Gauges.
Available in the New red, White, and Blue
Defi Racer Series 52mm Gauges
Defi Racer gauges read out in US Measurements (i.e. PSi, Fahrenheit, etc.) They feature a 52mm (2 1/16") design, and come with a black face and illumination in red using high-brightness LEDs. Boost, pressure, temperature, exhaust temperature, and volt gauges are available. Defi Red Racer gauges are standalone gauges, and do not require the Defi-Link Control Unit for use.
Features:
  • * Does not require and can't be used with the Defi-Link Control Unit
  • * Ignition ON initiates self-luminescence gauge.
  • * Lightning-like Opening / Closing mode with Red illumination using high-brightness LEDs
  • * Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
  • * The red triangle of the regular position bezel can be used as a warning indicator.
  • * Full 270 degrees sweep dial provides ultimate visibility.
  • * Gauges have peak hold and warning features All Gauges are 52mm (2 1/16")
  • * Temperature gauge used for Water or Oil- Pressure Gauge used for Fuel or Oil
Pricing:
Boost - $168.00
Pressure (Oil/Fuel) - $204.50
Temperature (Oil/Water) - $143.00
Voltage - $113.00
Exhaust Gas Temp (EGT) - $195.00
Defi BF Series Gauges also IN STOCK!
Requires use of Defi Control Unit Link. Please PM or post for pricing/information.
AEM UEGO Wideband 02 Gauge Controller
AEM's Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! AEM's Gauge-Type Wideband UEGO Controller features an LED readout and sweeping LED 'needle' that changes colors as AFR changes from rich to lean. The unit's 52mm (2-1/16'') gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. No laptop required for monitoring!
Key Features: Bosch sensor included with the AEM kit, 24 Color-coded LED display lights provide immediate reference to engine's air/fuel ratio (AFR) or Lambda, Integrated three-digit display reveals AFR or Lambda in real time user-programmable 0-5v analog output included for use with data loggers and ANY engine management system, Ideal AFR monitoring tool for carbureted applications and engine dynamometers, does not oscillate AFR like narrow band sensors, serial data stream included for output of AFR (RS 232), accurate to 0.1 AFR, 6 gauges in 1, one part number and you can have black or silver bezel with black or white face with a reading in lambda or AFR
Price: $243.00 - 12 in stock.
FULL Line of Autometer Sport Comp, Ultra Lite, Carbon Fiber, Lunar, Cobalt, etc series gauges are IN STOCK.
I have hundreds of gauges in stock! All ship FREE ground within 1-3 days.
We accept PayPal, Credit Card, Check/Money Orders.
Any questions at all, please contact us of reply to this thread.
Thank you all for your interest,
Pathik
Performance Racing
Performance Racing is offline   Reply With Quote
The Following User Says Thank You to Performance Racing For This Useful Post:
occschemguy (04-02-2008)
gReddy ti-c catback exhaust... bombdotcom MazdaSpeed 3/6 - Turbo Induction 6 04-08-2008 03:06 PM
Page generated in 0.23698 seconds with 20 queries
