Groans: 433
(Thread Starter) | Not Ranked : 0 score Here are a couple logs and a map. I messed with ignition timing a little big. I think there's more to be had. I've since tried to adjust the points down where the knock occurred, did so in the OL high throttle (no knock) map as well as the Max A and Max B tables. This is on MBC. Grimmspeed goes on this weekend. Lotta tuning left to do, if you plug into Virtual dyno, log 2's curve at smoothing 3 is pretty bad, haha. Once the clutch gets installed hardcore tuning CAN BEGIN! NOTE: Ignv1.2 is the map with the corrections made to timing based on these logs.
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
| Not Ranked : 0 score looking good man
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC |
![]() Join Date: May 2009 Location: Clw/ NPR Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,516
Groans: 89
| Not Ranked : 0 score You don't have a speed6 silly ! Post in your own section !!
__________________ [SIGPIC][/SIGPIC] 2013 EVO X GSR Wicked White w/Areo H&R springs/H&R 15mm spacers MAP modified 3" Magna Flow cat back MAP catless testpipe MAP UICP Grimmspeed 3 port Cosworth filter SSP relay kit TWM Desert Eagle shift knob AEM wideband gauge Prosport boost gauge EvoX piller pod 30%Tint Slowpoke Tuned 339hp/336tq **** SOLD ***** 2006 speed6 " A woman's asshole is like a 9-volt battery..U know its wrong, but sooner or later ur gonna put ur tongue on it !! " |
| Bullet Bitten, wallet empty. GTX3076R project begins | Chimmike | MazdaSpeed 3/6 - Big Turbo Builds | 102 | 10-13-2011 06:25 AM |
| First AP logs | robertof | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 07-27-2011 04:14 AM |
| first logs | reidclark | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 07-26-2011 10:26 PM |
| Can someone please look at these logs | bcmurphy87 | MazdaSpeed 3/6 - ECU Computer Tuning | 2 | 12-26-2010 10:42 PM |
| My Logs | Eskareon | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 11-09-2010 10:54 AM |
