 Old 10-03-2014, 08:59 AM   #1
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
Groaned at 7 Times in 4 Posts
Default Guardian Angel - How do you Run Yours?
Hey Guys:
Just recently purchased a GA to use as a failsafe for my meth install. Contemplating running it in VTA mode. Was curious to know how most of you that have a GA installed currently run it. Are you VTA or recirculating? Why did you chose one method over the over? Which would you recommend? Any advice you could lend would be appreciated!
Thanks in advance!
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
 Old 10-03-2014, 11:25 AM   #2
speed3 britz's Avatar
Posts: 1,155   (View Stats)
I run mine in VTA, purely based on fact that I have BOV and the recirc hose is pita and doesn't fit correctly with my fmic setup... and also cause Im a total ricer. Otherwise there is no benefit to run VTA over recirc. The GA is a nice precautionary piece on my BNR.
 Old 10-03-2014, 11:42 AM   #3
radbrad's Avatar
Posts: 538   (View Stats)
I know @dale_gribble; has a some knowledge of using the GA as a meth fail safe. Maybe he can direct you to some good reading material.
07Speed3
radbrad is offline   Reply With Quote
Guardian Angel Cevaes_64 Stratified Automotive Controls 6 06-09-2013 07:45 PM
Guardian Angel VTA...how? iammike 2010 MS3 - Engine, Transmission & Driveline 21 11-23-2012 12:41 AM
Page generated in 0.24242 seconds with 22 queries
