 Old 05-16-2018, 04:49 PM   #1
greg08's Avatar
Posts: 480   (View Stats)
Default Hard to start Speed 6
I'm having a hard time starting my speed 6 but it's starting if im pumping the gas pedal, but when i have it started and holding revs at 3k the revs will drop and rise again without me moving the pedal at all. I went to the fuze box and the Electronic throttle control relay is extremely hot. I rotated the relays and it still gets hot.. Is something wrong with my throttle control/throttle body??
 Old 05-17-2018, 11:58 AM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
The relay gets hot due to overcurrent. Either a bad connection or something is drawing too much current. Time to get out the voltmeter and start checking connections. Check grounds too.
 Old 05-17-2018, 10:39 PM   #3
greg08's Avatar
Ok, good call.
 Old 05-18-2018, 06:09 AM   #4
GroceryGtr's Avatar
Posts: 472   (View Stats)
check your IAC circuit/sensor as well.
Thor Hammer (05-18-2018)
 Old 05-18-2018, 08:48 AM   #5
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
We have an IAC circuit? Hmm.
Quota for learning something new today: complete.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 05-18-2018, 09:06 AM   #6
GroceryGtr's Avatar
lol i meant 'circuit' as in the iac path of wiring and connectors, not an actual circuit. So to clarify, check the IAC sensor itself(if its dirty it will affect idle quality) and also check the wiring and connectors.
As not to rain on your learning parade I have substitute knowledge that is relevant with the royal wedding almost here. The Royal Family were't always the Windsors. They changed their last name from Saxon und Goth to Windsor during the world war to avoid anti-german sentiment. A backup is that ketchup's top speed is .028 MPH.
 Old 05-18-2018, 09:26 AM   #7
Groans: 211
The IAC is the throttle body. There is no IAC valve on our cars. Threw me off for a moment there!
 Old 05-18-2018, 10:15 AM   #8
Fstrnyou's Avatar
That's what had me confused. I thought IAC was controlled by the TB. In the end, I still walk away learning something. Thanks @GroceryGtr;.
Other rides:
History:
 Old 05-19-2018, 05:51 PM   #9
greg08's Avatar
Ok guys. I made progress. I got it idling with no extra gas. I drove her around town. Over 3000 rpms she flies. but under 3k rpms she's stuttering and hesitating..
Just to clarify.. the ETC relay. Is this Electronic Traction Control, or Electronic Throttle Control.
BECAUSE, the traction loss light is on in my dash cluster.. I'm thinking maybe its cutting power because something is faulty in the ETC system?
I'm getting close.
 Old 05-19-2018, 02:31 PM   #10
greg08's Avatar
I'm happy to see so much activity on this thread. It seems like the engine starts when im pushing the throttle in and out repeatedly, and then when it get running it's smooth as hell above 1.5k rpms, but anything lower and it starts to stall.. Like the throttle body is closing too much. Can you guys check your ETC Relay and head relay and tell me if it's normal for them to get warm? not hot
Hard start / slow start TaagMan MazdaSpeed 3/6 - Troubleshoot/Diagnostics 32 02-13-2018 02:58 AM
Hard to start warm + P2096 heftybags 2010 MS3 - Troubleshoot/Diagnostics 3 04-17-2014 12:37 PM
Hard start when warm after vvt repair quad4svtspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 9 12-27-2012 05:53 AM
MS6 Hard start but new battery LTHorn Mazdaspeed3/6 General Discussion 12 10-08-2012 05:05 PM
Pls help...Hard Start up after long sit. Zimmer MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 07-22-2009 12:30 PM
Page generated in 0.30712 seconds with 23 queries
