 Old 12-26-2014, 11:03 AM   #1
rob ms6gt's Avatar
Posts: 416   (View Stats)
Default Hardwire Dashhawk Power
I hard wired the Dashhawk power source today so it turns on and off with the ignition. First, carefully cut into the harness and verify with a meter which wire is the power source. Do this with the key off. In my case it was the orange wire. They are probably all the same, but it's best to check. Then cut the power wire, cap the end leading to the OBDII connector, and splice the other end to a +12v ignition source. Do it nice. Solder all connections. Use heat shrink tube.
ROB MS6GT
 Old 12-26-2014, 12:43 PM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
Doesnt the dashhawk turn on and off with the ignition already?
The Following 2 Users Say Thank You to speed23 For This Useful Post:
Agent_Orange (12-28-2014), kgb (12-27-2014)
 Old 12-28-2014, 06:39 AM   #3
rob ms6gt's Avatar
No, it doesn't. I'm not certain, but I don't believe there is a switched ignition source in the OBDII connector. You can buy a DH cable with a power switch on it, but then you have to reach under the dash to switch it on and off every time.
ROB MS6GT
 Old 12-28-2014, 07:30 AM   #4
Micha's Avatar
Posts: 3,436   (View Stats)
Yes. The DH does turn off on its own when you turn the car off.
I am slow again.
I modded it a little.
The Following 2 Users Say Thank You to Micha For This Useful Post:
Agent_Orange (12-28-2014), speed23 (12-28-2014)
 Old 12-28-2014, 12:13 PM   #5
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Awesome solution to a problem that doesn't exist.
littleloogy (12-28-2014), rymanmazda (12-28-2014)
convert dash cam cig power plug to hardwire jack_hammer MazdaSpeed 3/6 - Car Audio & Electronics 10 12-18-2014 09:42 AM
How To: Hardwire a second OBD-II connector into your MS3 klafaille 2010 MS3 - How-To's 13 06-15-2013 11:58 PM
Mirrortap hardwire kit for MS3 JDMJOSH 2010 MS3 - Car Audio & Electronics 0 08-07-2012 08:10 PM
Hardwire Cobb AP...? amoosenamedhank MazdaSpeed 3/6 - Car Audio & Electronics 8 05-08-2011 12:13 AM
Best way to hardwire GPS? 79BlueSC 2010 MS3 - Car Audio & Electronics 1 06-30-2010 01:55 PM
Page generated in 0.25588 seconds with 23 queries
