 Old 01-22-2020, 08:23 AM   #1
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
If they are HID, check connections to the ballast and to the bulb.
If all that checks out then It's probably the ballast or bulb is failing. What you can do is swap the left and right bulbs and see if the problem moves to the other headlight.
HIDs work by sending an electric arc between two electrodes. For whatever reason the system can't start or maintain that arc it will shut off.
2018 Audi RS3
2007 Acura TSX 6MT
How To Change A Headlight Bulb | Autoblog Wrenched Haltech Automotive News 0 10-26-2016 01:30 PM
Headlight Bulb Tiner Mazdaspeed3/6 General Discussion 8 07-26-2015 08:26 PM
2011 tech package headlight bulb chintastic Exterior 24 08-18-2012 04:33 PM
headlight bulb size MSPmemelvin Appearance - WHITE 4 11-10-2010 06:22 AM
Headlight out... it's not the bulb Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 02-11-2009 12:57 AM
Page generated in 0.22395 seconds with 21 queries
