Like Tree7Likes
 Old 11-15-2011, 04:36 PM   #1
kehbleh's Avatar
Posts: 46   (View Stats)
kehbleh is a glorious beacon of lightkehbleh is a glorious beacon of lightkehbleh is a glorious beacon of lightkehbleh is a glorious beacon of lightkehbleh is a glorious beacon of light
Default Hearing conflicting things about boost at low RPM...
Experts of MSF, I am confused regarding boosting at low (I guess that's a relative term) RPM in our cars. I've seen it on here, and I've heard it from my friend who's owned a pretty heavily modded Speed 6 for quite some time (GT3071 turbo): DON'T boost in the low RPMs unless you want to throw a rod.
Well, I've been doing my searching like a good noob. I've been looking at SRIs and TIPs because I plan on doing a nice bundle purchase of the two aforementioned mods and a COBB AP. And possibly a fuel pump if the numbers from the AP show that I need it. But in a lot of TIP reviews, everyone says "Oh the boost comes in at least 500 RPM sooner, it's so nice."
From what I've heard, boosting below 3k RPM is a no-no. But, I know with the torque curve on our car, we've already hit pique torque at 3k. There's still plenty of torque to be had at 2.5k, maybe even 2k, but everyone says to keep it out of boost until 3k. Well, what's the benefit of having a small turbo with such an early spool up if we can't use it?! In 1st, 2nd, 3rd, and to a lesser extent 4th, as I build to the 3k before I put my foot down, I can feel the torque already building..if I put my foot down at 2.5k, I know it's gonna go.
I think you guys see where I'm going with this. Is it safe in the lower gears to get on it at 2.5k or 2k? I could see if you upgraded to a bigger turbo that you'd need to avoid flooring it at 2.5k, because there'd probably be no boost at all and you'd be putting a tremendous load on the engine. But in the car as it is now, stock, seems like it would be more than happy to frolick around at 2.5k, even 2k in 2nd.
Are people over-exagerrating the 3k mark? I feel like I can feel when the engine is willing to run and where it'd struggle. I'm not gonna floor it at 2.5k in 6th...but 3rd? Doesn't seem like the car would mind...
kehbleh is offline   Reply With Quote
The Following User Says NO Thank You to kehbleh For This Un-useful Post:
kmac (11-17-2011)
 Old 11-15-2011, 04:42 PM   #2
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
Test it out and see how it goes
2010 Black Mica
rghispanic88 is offline   Reply With Quote
The Following 4 Users Say Thank You to rghispanic88 For This Useful Post:
8.5MS3 (11-16-2011), BeastMS3 (11-16-2011), kmac (11-16-2011), Zdraveca (11-15-2011)
 Old 11-15-2011, 04:46 PM   #3
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
no reason to be going wot below 3000rpm anyway.
 Old 11-15-2011, 04:48 PM   #4
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Ahahahahaha THIS^!!!!!!
Sent from my T-Mobile G2
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
 Old 11-15-2011, 04:49 PM   #5
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Don't go WOT below 3k.
Problem solved.
Close this thread.
Inthepocket likes this.
 Old 11-15-2011, 04:54 PM   #6
stupidslow_ms3's Avatar
Posts: 39   (View Stats)
stupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud ofstupidslow_ms3 has much to be proud of
I usually race people in the 3500-3800 rpm range in 2nd or 3rd gear. 2500 seems way to low to be flooring it from unless u from a dead stop.
2007 MazdaSpeed 3~ Sri, HKS Exhaust, testpipe,HKS bpv, cobb rear sway bar, turbo inlet, autotech internals, short shifter, sure rmm, and cobb ap
2009 Honda CBR 600 RR Phoenix Edition~ Stock
stupidslow_ms3 is offline   Reply With Quote
 Old 11-15-2011, 05:22 PM   #7
kehbleh's Avatar
Well it's not racing..it's just driving around the city. Just truckin along at 2500 when a lane opens up..why not let 'er gallop! I was trying to foster discussion with this thread to learn more about how my car works but apparently some people are content with JUST DON'T DO IT LULZ. Thanks guys.
Also worth noting that nowhere in the owner's manual does it warn about accelerating fully below a certain RPM.
Last edited by kehbleh; 11-15-2011 at 05:22 PM. Reason: MSF Database - Automerged Doublepost
kmac (11-17-2011)
 Old 11-15-2011, 05:25 PM   #8
TRex's Avatar
Posts: 3,139   (View Stats)
my answer to this time and time again is WHY WOULD YOU WANT TO DO THIS
regardless if it is bad or not more power will be had if you simply downshift...stop being lazy...should have bought an automatic
 Old 11-15-2011, 05:31 PM   #9
kehbleh's Avatar
If the power's there, why not? Of course the answer to that is because it will damage your car. But why even have a small turbo at all if you can't put your foot down till 3k? Just seems counter-intuitive to me.
The Following User Says Thank You to kehbleh For This Useful Post:
fortressofcomfort (01-05-2012)
 Old 11-15-2011, 05:30 PM   #10
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I go WOT at 2000 RPM all the time. I'm at 21 PSI by 3000.
Bucker, rfinkle2, jthistle and 1 others like this.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
Bucker (11-15-2011), laxplayermjd (11-15-2011), rfinkle2 (11-15-2011), SWAY (11-16-2011)
 Old 11-15-2011, 05:32 PM   #11
rtabagaboy's Avatar
Posts: 363   (View Stats)
rtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the world
Groaned at 7 Times in 3 Posts
Well a BT should not spool at those low RPMs so you are putting less load on the engine at low rpm with a BT. This is why some people see BT as a safer option to the stock turbo, because the don't build boost until later in the RPM band.
Edit: In stock form the flow path is restrictive so it doesn't build boost at low rpm. Once you add breather mods that physical limitation goes away and you can boost 20+ Psi @ 2500 RPM.
2008.5 BlackMica Mods:
- Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it.
AZ Status!
rtabagaboy is offline   Reply With Quote
The Following User Says Thank You to rtabagaboy For This Useful Post:
kehbleh (11-15-2011)
 Old 11-15-2011, 05:39 PM   #12
kehbleh's Avatar
Hm, that makes sense. If stock it were impossible for it to boost that low due to air restrictions then there'd be no need to warn the consumer about it. It feels like it's got enough umph in it that it's got at least some boost though (specifically 2.5k in 2nd gear). Also...what's a BT?
 Old 11-15-2011, 05:42 PM   #13
Check the thread below out when you have a moment.
Some evidence shows that the Mazda factory tune (pretty lean in high boost situations, with aggressive timing), combined with catless downpipes (i.e. boost spikes) in early days of modding the ms3 led to the bent rods.
http://www.mazdaspeedforum.org/forum/foru...st-zoom-82908/
kehbleh (11-15-2011), kunfu (11-16-2011), manelscout4life (11-16-2011)
 Old 11-15-2011, 05:49 PM   #14
kehbleh's Avatar
Thanks! THIS is the kind of stuff I was hoping would turn up! Very interesting.
 Old 11-15-2011, 05:52 PM   #15
One thing to note is cld12pk2go (the linked thread's creator) has some pretty extensive knowledge of tuning the mazdaspeed3 (and other platforms {blown mustangs on spraying meth I believe}) for that matter.
He also runs an e85 mix with 100% meth injection.
Point being, his car is tuned properly.
Another thread concerning low rpm boost (not bothering to down shift) lol.
pwnin' some WS6
 Old 11-15-2011, 06:05 PM   #16
kehbleh's Avatar
pwnin' some WS6
To be fair, I'd say not downshifting on a highway is straight-up lazy. You're not gonna have passing power lugging around in 6th. However, if you're going 30 mph in 3rd gear, you don't need to downshift to 2nd to get the power you need. And there you have the origin of my question.
2009 GT
JBR shifter bushings, JBR shift knob, CP-E RMM, CP-E Nano SRI, CP-E TIH, COBB AP
 Old 11-15-2011, 05:40 PM   #17
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I do all of my logs from 2500-redline...
I personally have no issue going WOT under 3k RPM in 2nd or 3rd, but thats me.
403whp/451ft/lb Dry Shot
The Following 7 Users Say Thank You to Bucker For This Useful Post:
atvfreek (11-16-2011), kehbleh (11-15-2011), kunfu (11-16-2011), laxplayermjd (11-15-2011), silvapain (11-15-2011), skeeter149 (11-15-2011), skiptowncat (11-16-2011)
 Old 11-15-2011, 05:41 PM   #18
kehbleh's Avatar
Nevermind, big turbo ha.
Well that's the thing, it feels plenty strong and fine doing it, but everyone says DON'T SMASH GAS BELOW 3K OR HAVE FUN PICKING YOUR MOTOR UP OFF THE ROAD. Which is why I started this thread in the first place...I wasn't sure if those guys were talking about bigger turbos, or if it didn't matter how the car FELT, that damage was still being done when gassing it below 3k.
Last edited by kehbleh; 11-15-2011 at 05:41 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-15-2011, 05:47 PM   #19
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
i just drive my damn car however i feel like it,whichever rpm its at. Have you heard the one about not taking these on long trips too?
Ive got full boot between 2500-3k rpm. Only truth i see behind this is why go it in 6th gear on the highway, racecars downshift
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
The Following 2 Users Say Thank You to laxplayermjd For This Useful Post:
Novej (11-15-2011), rfinkle2 (11-15-2011)
 Old 11-16-2011, 09:14 AM   #20
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
Originally Posted by laxplayermjd View Post
Have you heard the one about not taking these on long trips to?
I want to know this too. I've driven from Virginia Beach to San Diego twice and no issues so far. I've also driven many times between Texas and Cali. Most of my miles are highway at 72k.
AtTheDriveIn is offline   Reply With Quote
 Old 11-15-2011, 06:45 PM   #21
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
The whole don't go WOT under 3K RPM's doesn't come into play when your in 1st and 2nd gear, shit or 3rd gear. I start my logs in 3rd gear at 2500rpm. People are mainly speaking of in 4th, 5th, and 6th gear you dont want to go WOT under 3k rpm. Downshift.. or baby the throttle till your above 3k rpms and go at it.
You can't really go WOT in 1st gear, well u can but your not going to hit 20psi.. might hit 20 psi for a second or two in 2nd gear, depending on when you shift.
The Following User Says Thank You to Spoofmastafly For This Useful Post:
kehbleh (11-16-2011)
 Old 11-15-2011, 07:17 PM   #22
Jake5713's Avatar
Posts: 1,775   (View Stats)
My only thing here is, I have always been advised to start when I datalog to start the log at 2.5 k
Is this wrong
@rfinkle2
I am here: http://maps.google.com/maps?ll=44.739728,-93.107847
-Jake
 Old 11-15-2011, 07:39 PM   #23
drag0nfire's Avatar
Posts: 60   (View Stats)
drag0nfire will become famous soon enough
Hi all,
Sorry in advance for the dumb question, but I just read the whole thread, and I still don't understand what happens when you boost at low rpms.
If I have a CAI with a stock tune, it boosts easier, right? Does that mean I am at increased danger for problems associated with boost at low rpms?
Thanks!
drag0nfire is offline   Reply With Quote
 Old 11-16-2011, 01:18 AM   #24
jv92red's Avatar
Posts: 319   (View Stats)
jv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the worldjv92red is the leader of the world
This has been talked about many times in the blown engine threads. In a nutshell - a bolted K04 motor is capable of torque of 300ftlb+ at these low RPM's. Check out the dyno threads for K04 setups an you'll see 300ftlb+ levels at the wheels which means higher actual torque at the flywheel given drive line losses. This amount of energy down low in the RPM range is what overworks the stock rods. The engine is not spinning fast enough yet to be able to cope with the energy exerted on them - this leads to fail. BT's don't reach full boost till 3000+ so this is not so much an issue when going BT.
I'm no engineer so I'm sure someone can explain the reciprocating/rotational mass better than me but when it comes down to it, we only have 4 rods to distribute the generous amount of torque that built K04 motors put out at low RPMs. I would suspect the rods on a V12 Lamborghini Aventador with 510lbft @5500RPM would have less energy exerted on any given rod at it's 5500 RPM peak as it has 8 more rods and 3000 more RPM's to deal with that energy. Again I am no engineer so if someone can jump in and explain better than this or correct the above please do.
jv92red is offline   Reply With Quote
The Following 2 Users Say Thank You to jv92red For This Useful Post:
59ksmall (12-02-2011), drag0nfire (11-16-2011)
 Old 11-30-2011, 09:04 AM   #25
icto0389's Avatar
Posts: 9   (View Stats)
icto0389 will become famous soon enough
I've always had an engineers mind, and when explained like this it makes a lot of sense.
This is MO on why its not a good idea...
If i can laugh at a SOHC ITT Civic as i pass him @60 in 6th (which is like 2200rpm) and hes got it matted in third as i slowly pull away faster and faster and....then BOOM. im not laughing anymore....
well, It makes sense because.... 300ftlbs of TQ @ 2200 means that with each revolution of the crank the rod is pushing very hard for a longer time to get the rotational mass converted into HP. all this tq force is applied for a much longer duration to each rod, possibly stressing the components about 50% more than when @ 3k (since at this higher RPM the rod received the same TQ but for a shorter time. IMO this means 50% less stress and TQ displaced to the engine when at higher RPM.) Now im sure if you ask an engineer; he could probably prove this with math. and im sure he will tell you that there are additional lateral forces on internal components as the RPM's increase, AKA redline BOOM...
After reading through the tread i am 100% sure that at these low RPMs and such a large amount of Air and fuel being thrown in for such a low combustion cycle it changes the chemical process (only slightly) when the fuel is ignited, which from what i understand could have or probably did cause the early years of BOOM!
You know what, the general message of this thread, and i would agree...
JUST DON'T DO IT....
icto0389 is offline   Reply With Quote
The Following User Says Thank You to icto0389 For This Useful Post:
mirage (01-13-2012)
 Old 11-16-2011, 04:13 AM   #26
kmac's Avatar
Posts: 1,792   (View Stats)
Neutral  -2 score
I don't understand why this is so hard to grasp. Eventually u will bend a rod or wear your rod bearings due to the tremendous amount of load and cyl pressure. So considering you didn't get the answer u wanted u just keep asking till u get the one u want. So here u go , It's great for the car , you should do it anytime given the chance . The more the better.
First 500whp stock block mazdaspeed3 (503whp 423wtq)
<3 Tokay.
The Following 2 Users Say Thank You to kmac For This Useful Post:
BeastMS3 (11-16-2011), Realgib3 (11-16-2011)
The Following 2 Users Say NO Thank You to kmac For This Un-useful Post:
59ksmall (12-02-2011), kehbleh (11-16-2011)
 Old 11-16-2011, 04:52 AM   #27
Jake5713's Avatar
For logging is it or is it not safe to start at 2500 rpm
This is something I believe is in @Abilor guide
This is something I need to confirm
-Jake
 Old 11-16-2011, 05:05 AM   #28
-Jake
It is safe to log from 2500 rpms. Yes.
(I believe that Cobb, the Perm team, Phate, atvfreek would ask you to log from that rpm in addition to your tuner. I think cld12pk2go would ask you to start @ 2000 rpms)
If you are logging, and see kr>2 @ any rpm, I might let off the go pedal.
To the best of my knowledge, 95% of the logs on this forum are started @ 2500 rpms.
 Old 11-16-2011, 05:19 AM   #29
kmac's Avatar
Creating torque that low is not good for any engine that's not built.
<3 Tokay.
Realgib3 (11-16-2011), rfinkle2 (11-16-2011)
 Old 11-16-2011, 05:35 AM   #30
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
Neutral  -1 score
theyre all wrong op
i go wot in 4th at 2k and the car eats it up, i gotz datalogs to prove it
bunch of paranoid bitches on their rag up in this joint
 Old 11-16-2011, 06:35 AM   #31
Atlanta's Avatar
Posts: 233   (View Stats)
Atlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the worldAtlanta is the leader of the world
Groaned at 26 Times in 14 Posts
i go wot in 4th at 4k and the car eats it up, i gotz datalogs to prove it
I don't think anyone said that WOT at 4k is bad. They are talking about 2k and 2.5k WOT.
Atlanta is offline   Reply With Quote
The Following 2 Users Say Thank You to Atlanta For This Useful Post:
8.5MS3 (11-16-2011), rfinkle2 (11-16-2011)
 Old 11-16-2011, 04:43 PM   #32
kehbleh's Avatar
theyre all wrong op
Your avatar is fitting haha.
2009 GT
8.5MS3 (11-17-2011)
 Old 11-16-2011, 06:46 AM   #33
8.5MS3's Avatar
Groans: 326
oo my bad i meant 2k
The Following User Says Thank You to 8.5MS3 For This Useful Post:
 Old 11-16-2011, 06:53 AM   #34
I guess it all comes down to risk. The rods in our cars are documented as being the weak link.
Is there more chance of breaking / bending something @ high load low rpm?... it certainly seems like a sound idea, both from a mechanical standpoint and opinions of other members.
Are some of the guys willing to take the risk? Yes. With a bit more success now than in the past.
In 1st, 2nd and 3rd, I think it is unavoidable tbh.
While datalogging, it is going to be asked of you to be sure the car is timed properly.
The remainder of the time, I guess it is entirely up to you if you decide to downshift or not.
kmac (11-16-2011)
 Old 11-16-2011, 08:19 AM   #35
Mizzle's Avatar
Groans: 324
The rods are not a weak link if they handle 500whp (which they do.)
Flooring your car in 5th or 6th at 2,800 rpm because you're too lazy to downshift = blown motor. Not because they're weak, but because they're spending a lifetime in that crank rotation making maximum torque... when suddenly shitty gas detonates from the raised temperatures and *poof* blown engine.
Until you fully tune your car, downshift at 3k when accelerating from 4th on up.
 Old 11-16-2011, 08:21 AM   #36
silvapain's Avatar
Groans: 136
It's all detonation. Cylinder pressures spiking drastically BTDC bend conrods, not boost.
Tapadatass
Lex (11-16-2011), rtabagaboy (11-16-2011)
 Old 11-16-2011, 08:29 AM   #37
8.5MS3's Avatar
Groans: 326
i have peak tq pushed out to 4k
so i dont care when i floor it haha
 Old 11-16-2011, 08:32 AM   #38
And the debate continues. LOL.
 Old 11-16-2011, 09:23 AM   #39
wankular's Avatar
Posts: 4,343   (View Stats)
The long trip controversy had to do with cruising too long at one RPM and then trying to accelerate and boom. PTP John had a long thread about it, something about oil pooling somewhere.
Also I think a guy blew up while in cruise control.
2009 MS3 sport MGM
 Old 11-16-2011, 09:28 AM   #40
kmac's Avatar
Cyl pressures r way higher at lower rpms and detonation also plays a huge roll in bending rods, but if we look at this in terms of this was a real engine in displacement terms instead of a weed wacker. If u had a 4.6 twin cam cobra and it made peak torque at pre 3k or 3200 and if your making 350 in a 2.3 now your 4.6 technically makes 700wtq at those rpms eventually there is definitely going to be a problem . Instead of looking at it as the wtq not being that much at that rpm compare the wtq to rpm and displacement and It's a little scary.
<3 Tokay.
rfinkle2 (11-16-2011), sripple0402 (08-08-2017)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/hearing-conflicting-things-about-boost-low-rpm-97145/
Need help terribly - Page 3 - Dodge SRT Forum This thread Refback 11-30-2015 03:54 PM
Big Torque at Low RPMs This thread Refback 07-08-2015 11:26 AM
Toyota is making conflicting claims on runaways, U.S. lawmakers say Haltech Automotive News 0 02-03-2010 10:10 PM
Guzzler ads canceled, sales halted amid conflicting reports Haltech Automotive News 0 07-31-2009 08:10 AM
Ads canceled, sales halted amid conflicting reports Haltech Automotive News 0 07-31-2009 01:01 AM
Conflicting details: Volkswagen's LA-bound mid-engine coupe Haltech Automotive News 0 10-10-2008 02:30 PM
Page generated in 0.62434 seconds with 41 queries
