 Old 03-02-2014, 05:27 AM   #1
CoolChris's Avatar
Posts: 9   (View Stats)
CoolChris will become famous soon enough
Default Help to a brownie
Hi. I'm Chris. I'm new to the tune world and just got a 2008 Speed 3. I hearing a funny clunk coming from passenger side front end. It's driving me crazy! I looked at notorious motor mount next to wheel well and it looks good. Could it be the struts/shocks? How can I tell?
CoolChris is offline   Reply With Quote
 Old 03-02-2014, 06:24 AM   #2
shamie's Avatar
Posts: 952   (View Stats)
Read, search, read - then read some more. This has been covered before.
Clunks up front can come from struts, strut hats, sway bar bushings, end links, CV axle, wheel bearings, etc. in that order. Search for those and see if you can narrow it down.
 Old 03-02-2014, 07:26 AM   #3
jbmazda6's Avatar
Posts: 1,230   (View Stats)
jbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the worldjbmazda6 is the leader of the world
If you have stock suspension my best guess would be endlinks. Buy MOOG's which are fairly cheap and a little beefier. You'll have the peace of mind of new endlinks and your clunking might go away.
JBR: Whale Penis, SSP+Weight+Bushings+Knob, Boost Tubes, Bypass Valve Hose, TMM, PMM, RMM, OCC, TIG's, Small Battery Tray
Other: Stratified 3-Port EBCS, Stratified Guardian Angel, Cp-e Catted Downpipe, Cp-e Top Mount Intercooler, Cp-e Rear Diff Mount, Autotech Internals, H&R Coilovers
Sponsored By: JamesBaroneRacing.com
jbmazda6 is offline   Reply With Quote
Page generated in 0.23893 seconds with 22 queries
