![]() Join Date: May 2015
Rep Power: 0 ![]() Thanks: 14
Groaned at 8 Times in 5 Posts
(Thread Starter) | Not Ranked : 0 score Hi everyone, I recently replaced my clutch slave cylinder and attempted to bleed it with my brother and didn't have much luck. So I went on amazon and bought a hand vac pump. I have repeated the same process of overfilling the reservoir, opening the bolt on the bleeding nipple, pumping till I fill about half my small container that is connected to the pump, closing the bolt, and finally refilling about 10 times now. I have spent the past hour doing this and don't think I have made much, if any progress. Here is a video, in the beginning I'm clearly not pumping but you can see when I do because of all the bubbles. https://youtu.be/6rxfYztBAZw Maybe I'm stupid and It's completely bleed, if it is, please let me know lol And if I'm correct and it's still not fully bleed, do you think that I'm doing the process wrong, should I be pumping slowly for a low pressure or quickly for a higher pressure? This is my first time bleeding anything so any advice would be appreciated. Thanks -Kyle |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
| Not Ranked : 0 score How to bleed MazdaSpeed 3 clutch slave cylinder Planning to do mine soon too. Going to follow the instructions above when I do. |
![]() Join Date: Oct 2013 Location: Detroit, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 509
| Not Ranked : 0 score Try to have the tube from the bleeder going upward if you can. Not that that's the problem since it's obvious all that air that isn't coming from the catch bottle. You either don't have enough fluid in the reservoir to go above the baffle wall and fill the clutch side of the bottle (likely... go fill it all the way to the rim rather than just to the full line), or you have a leak somewhere between the clutch master cylinder and the bleeder valve. That bleeder valve looks new and doesn't appear to have any teflon sealant, so are you even sure that it seals properly to the slave housing? And as an aside, WTF is with that brass monstrosity underneath it? Is this the special MPS steampunk edition?
__________________ 2013 'speed3, silver Stage Bro |
I have been over-filling the reservoir every time and only took out a little at a time to prevent any air from getting in through there. The clutch slave cylinder is brand new therefore there is no sealant on the bleeder valve. When you say "sure that is seals properly to slave housing", do you mean the tube connected to the pump being properly sealed to the bleeder? The fitting was a little loose therefore I wouldn't be surprised if air was able to escape/enter through there. I figured this wouldn't make a difference as people have successfully bleed their clutch without a pump, and clearly the pump was pulling the air/fluid through. Thanks for the response Kyle | |
Watch this https://www.youtube.com/watch?v=n1NvtUwfRJc&t=5m0s from about 5:00 to about 6:30 and you'll see how the fluid should come out if everything is working correctly. The fluid going into the tube from the bleeder won't even look like it's flowing if things are working properly. This air bubbling is WAY wrong.
__________________ 2013 'speed3, silver Stage Bro | |
![]() Join Date: Feb 2009 Location: Dupont wa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
| Not Ranked : 0 score OP what was the final outcome??I am going thru almost same situation using a hand pump but in my case air bubbles are not coming out is just a little bite of brake fluid at time.That is my concern that more brake fluid should come out.Brake fluid is coming out in drops and not constantly stream.I replaced the clutch and slave,Anybody has any ideas?????
__________________ |
| How to bleed MazdaSpeed 3 clutch slave cylinder | y2kc0wb0y | Mazdaspeed3/6 General Discussion | 4 | 11-27-2017 07:11 PM |
| About to bleed my slave cylinder | Speed3Pedro | Mazdaspeed3/6 General Discussion | 11 | 07-08-2016 10:22 AM |
| Clutch Bleed Screw | El_Diablo | 2010 MS3 - Engine, Transmission & Driveline | 2 | 07-12-2013 12:17 PM |
| How to bleed ur brakes | MSP611 | MazdaSpeed 6 - How-To's | 17 | 07-18-2010 11:16 PM |
