![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
(Thread Starter) | Not Ranked : 0 score If you know of a better price, part, have another suggestion or are a vendor looking to deal, hit me up and/or post in here. As far as parts I'm not decided on yet, I'm fine with DIY so if another OCC will work but doesn't have a check valve, I'll get a check valve ya know? Wheels: _Enkei PF01 17x8 ET50 (silver) with centers _~ $1,100 _TireRack Tires: _Continental ExtremeContact DW 245/45ZR17 Purchased @ $620 _Tire Details - Discount Tire Direct Lugs: _McGard 65557BK SplineDrive Wheel Installation Kit Purchased @ $81.35 _Amazon STS: _Ralco RZ 914950 Purchased @ $116.61 _Ralco RZ Short Shifter MAZDA 3 2007 - 2009 914950 Programmer: _AP AP-MAZ-002 _$535.00 _07-11 Mazdaspeed3 Cobb Tuning Accessport Side Mounts: _JBR obv. _$350.00 Springs: _Swift _$319.00 _Swift Spec R Springs Mazdaspeed 3 MS3 2010+ Fuel Pump Internals: _$349.96 _Autotech Hi Volume Fuel Pump Upgrade HPFP Internals Mazdaspeed 3 6 MS3 MS6 Help: Spark Plugs: _? Strut Mounts: _What adjustable mounts are out there? Rear camber arms: _Brand loyalty aside, which ones are a.) awesome & b.) adjustable on the car? BSD Kit: _Which would you recommend? OCC: _Which would you recommend? Easiest to drain? EGR Blockoff: _I'm thinking JBR? FSB: _Stiffest? RSB: _Stiffest? Is the Whiteline bumpsteer thing worth it? Is the Whiteline caster kit worth it? Should I get rear toe adjuster thingies? What else am I missing? I don't (yet,) want a FMIC/TMIC, dp, etc. I don't have the money for internals or the AP yet, hence why it's mostly the stuff at the beginning of the list. How are we so far/what do you think? :edit: Please include links. Last edited by Mizzle; 05-13-2012 at 10:57 AM. |
![]() Join Date: Jul 2011 Location: Elk Grove Village, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,411
Groans: 124
| Not Ranked : 0 score Md occ.....(Matt Damond oil catch can) Rsb-jbr.
__________________ DBB Gen2 Pte6266, kozmic pte top mount manifold kit, Kozmic 4'' Intake, kozmic hood exit Dp+Dump, 11:1 Custom Wiesco Pistons + Monlar rods, Freek PnP head w/Supertech springs&retainers, L19 Head Studs, JMF PI Intake Manifold W/ custom single Walbro 450+ Fuelab Inline Pump, HKS BOV, Cp-e Stage2 RMM, Trz Tranny Mount, MD PMM, JBR Egr Block Off Plate, Cp-e Fuel Pump, Sheepey Built Fmic Core, 3.5 Bar Map Sensor, Precision Wastegate, TWM Shifter bushings, Freak Tuned! 713whp/569wtq! FIRST MS3 IN 10s! 10.963 @ 136.79 (8/12/2015) 10.72 @ 139.44! (10/1/2015) 10.43 @ 140.95! 10/9/2015 10.35 @ 140.86 (10/30/2015) New Time! Fastest Ms3 to date 10.27 @ 141.55 (5/22/2016) |
Groans: 324
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I seem to recall having heard some not-so-great things about the Ralco RZ short shifters. I think if you look around a little bit, you'll find some mentions of it being "weak" or "rattly" or something along those lines. I think I'd go with the TWM kit instead, though it is significantly pricier.
![]() Join Date: Jun 2009 Location: Old Bridge, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,044
Groans: 125
| Not Ranked : 0 score i got my rpf1's for 1k shipped, pm me |
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score From what I've read, the Conti's are okay at everything, great at nothing. I still say a summer setup and a winter setup.
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
| The Following User Says Thank You to predapio For This Useful Post: | CWP_MS3 (05-09-2012) |
Groans: 124
| Not Ranked : 0 score I hear front sway bar isn't worth it since u will get way too much oversteer or understeer, one of those. Umm but for rear sway bar......I'd just go jbr Mazdaspeed 3 (07' - 2012) : James Barone Racing, Custom Fabrication And the oil catch can you can get from Matt damond. http://www.mazdaspeedforum.org/forum/foru...-thread-36097/
Groans: 324
| If you want to know about the Ralco RZ for sure, I suggest you chat with Daddy Chinkus. I think he's got one in his car.
Groans: 324
(Thread Starter) | Not Ranked : 0 score I want more of a "If it were my car and I could do it again, I'd buy ____ because ____." |
Groans: 324
(Thread Starter) | Not Ranked : 0 score OP updated. Easiest to drain OCC that'll work with a CAI. |
Groans: 224
| Not Ranked : 0 score OCC=matt damond or JBR EGR delete=JBR RSB=no clue Plugs=Denso ITV22's BSD=I personally like the SURE BSD Rear Camber Arms=Megan or SPC. Both adjust on the car
Groans: 324
(Thread Starter) | Not Ranked : 0 score Is there a bsd walk-through? Any less expensive occ's or would making a cheaper one work negate the savings? Link to Megan camber arms? @jbarone - does yours adjust when installed? What is the consensus on rear toe adjusters? |
Groans: 124
| Not Ranked : 0 score No, his arent adjustable once on the car.
Groans: 324
(Thread Starter) | Not Ranked : 0 score Thanks. Do Megan arms have stiffer bushings? |
Groans: 224
__________________ MS3 has been retired to daily duty Project 1G; 1991 Eagle Talon TSi. 63MM Borg Warner Powered, Corn-Fed, 2.4L Long Rod Monster Under Construction Stock Turbo-Stock Engine Grand Champion of the World! 501WHP & 569WTQ (PERM Tuned, 93 OCTANE PUMP GAS K04 W/N2O!!) NATOR PA | |
![]() Join Date: Dec 2011 Location: Fort Lauderdale, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,358
Groaned at 18 Times in 16 Posts
I have heard it from reputable source, but I am NO EXPERT! May somebody who know about the possible problems that short shifter can bring can comment here...it will be nice to know for sure. Last edited by Constantin; 04-24-2012 at 08:00 PM. | |
![]() | | #19 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score Whoever said a STS ruins your synchros is retarded. That said, I'm just buying that to replace my stock unit. I'm going to add a 2" extension to bring it back to stock height anyways. |
![]() | | #20 | ![]() |
Hotchkis FSB Install @Tomas sais (post #5) that he does not experience oversteer. In fact he highly recommends Hotchkis FSB. | |
| The Following User Says Thank You to Constantin For This Useful Post: | Mizzle (04-27-2012) |
![]() | | #21 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score Ralco STS ordered from THMotorsports: $116.61 shipped. ![]() Hubcentric rings ordered from EBay - $9. McGard lug kit ordered - $38 after using AMEX points (from ~$85) Question: Why are the spark plug part numbers for 2010 MS3's and 2008 MS3's different? @Daddy Chinkus - is the shifter a STS because they cut the shaft down or because the linkage connection is longer? NGK 2008: ILTR6A-8G .032" NGK 2010: SILTR6A-7G .027" Obviously the gap, but what else? Last edited by Mizzle; 05-05-2012 at 02:49 AM. |
![]() | | #22 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 253
| Not Ranked : 0 score If you are getting an AP, you might as well invest in one step colder plugs. For the OCC....yes, MC's is a great setup, but it isn't anything you can't do yourself. You can install the OCC by the horn bracket, which lets you drain the easiest, or by the CAI (should still fit). When you do install the OCC, you should also clean your valves and do the EGR blockoff at the same time, since it is a seriously big PITA without the I off. |
![]() | | #23 | ![]() |
| 2zz mr-s ![]() Join Date: Nov 2010 Location: katy, tx
Rep Power: 3483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groans: 239
| Not Ranked : 0 score linkage is but the shifter itself is also shorter
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #24 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score Any knowledge on the plug part numbers? |
![]() | | #25 | ![]() |
![]() Join Date: Jun 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 176
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score +1 for TriPoint Rear Swaybar. Their customer service is better than amazing. I'd rather support them then someone who's an ass to anyone who questions their products (JBR). |
![]() | | #26 | ![]() |
Groans: 324
B.) My thread is not for bickering. C.) Anyone that says shit like the following doesn't get to speak unless spoken to: Soo any input on the plugs? | |
![]() | | #27 | ![]() |
| Not Ranked : 0 score JBR is also one of the cockiest people ever on the forum. Shifting a car without using the clutch says nothing about someone's knowledge oor experience with car setup. ![]() I'm also not the one who can't use the search function for one of the most commonly discussed maintenance upgrades. |
![]() | | #28 | ![]() |
| lulz @Raider ![]() Join Date: Jun 2010 Location: St Louis Mo
Rep Power: 3779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,132
| Not Ranked : 0 score I have the ralco and I have had it on ye car for about a year...... I am pretty happy with it..... Only thing I don't like is I think it is about 1/2 an inch shorter than the twm and when you put the car in reverse it rubs on the shifter boot.... I am on my second shifter boot
__________________ 2008 MS3 gt 470hp/463tq on GT35r at 29psi Wiseco Pistons/Molar Rods/ACT 6 Puck/ARP Head Studs/TurboXS FMIC DP and RP/TurboSmart BOV/Tial 38mm EWG/PERM 5th/6th port injectors HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned |
![]() | | #29 | ![]() |
Groans: 324
Second, get off your soap box and fuck off / gtfo.
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
| Not Ranked : 0 score And yes that is the short boot
![]() | | #32 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score Weird. Is it something on the inside? I ask because I have a grinder... and mine is already purchased |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Yeah there is a plastic piece that you could prolly trim down..... I am just to fucking lazy
![]() | | #34 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score So lazy, in fact, that you can't type two "o's," in "too." <3 |
![]() | | #35 | ![]() |
![]() Join Date: Feb 2012 Location: Sacramento, CA
Groaned at 33 Times in 13 Posts
| Not Ranked : 0 score All these mentions of Matt Damond.. I don't think the guy exists. I think he is made up. Either that or he has been on location with Ben for the last 6 months. The guy reminds me of the R.O.U.S.es or Keyser Söze.
__________________ 2010 Liquid Silver MS3 - COBB SRI/TIH, AP, JBR 88 Duro RMM, JBR Bushings, JBR SSP, AT Internals, CP-e Catted DP/RP, Michelin Pilot Super Sports 235/40 18, Motorcraft MT Fluid, Step Colder NGK's Wife's Car: 2013 CX5 AWD Grand Touring (It's slow but handles nice) OBAMA SUCKS Stratified Tune by Lex |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Shit, fuck ..... You are right
![]() | | #37 | ![]() |
| Not Ranked : 0 score He is there, he just hides well @Bosox
![]() | | #38 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score Hello, They are very similar, but have different part numbers. The SILTR6A-7G is dealer only. The ILTR6A-8G is the option available for purchase in the aftermarket. Best Regards, Andrew Hauenstein Technical & Training Specialist NGK Spark Plugs (USA), Inc |
| The Following User Says Thank You to Mizzle For This Useful Post: | rfinkle2 (05-07-2012) |
![]() | | #39 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score Note: Holy crap, I got my hubcentric rings already. I bought them on 5.3.2012 for $8.90 with free shipping on they're here... cray. I highly recommend "aaiautomotiveaccessories," on EBay. |
![]() | | #40 | ![]() |
Groans: 324
(Thread Starter) | Not Ranked : 0 score McGards came in. One point of contention: The spline-drive nuts have rotating seats so they don't fuck your wheels up. The locks that came with it do not. I'm happy because they'll protect my shit, but still... wtf? |
| Looking for a shop in NYC | bigx5murf | Mazdaspeed3/6 General Discussion | 0 | 02-16-2011 06:56 PM |
| Car is in the shop | desertrat | MazdaSpeed 3/6 - Turbo Induction | 2 | 11-15-2010 10:15 PM |
| The Shop | crbalch | Mazdaspeed3/6 General Discussion | 4 | 11-08-2010 06:37 PM |
| 08 In the Shop | Shanems3 | MazdaSpeed 6 - Engine, Transmission & Driveline | 6 | 04-24-2010 08:46 AM |
