![]() | | #161 | ![]() |
| Police ![]() Join Date: Dec 2009 Location: Guadalajara MX
Rep Power: 3113 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,737
Groaned at 9 Times in 9 Posts
(Thread Starter) |
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQSOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes |
![]() | | #162 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
| Not Ranked : 0 score Raise your idle to 1000? LOL Is that misfiring at idle? What are your plugs gapped at again? I know you've swapped coilpacks but what about plugs?
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
![]() | | #163 | ![]() |
| Not Ranked : 0 score Car needs air fuel and spark. You covered spark by looking at plugs and swapping coils. The next would be air and fuel. I would do a leakdown test just to make sure all is well and then look at the injector, seals and valves next. Was VVT replaced?
| The Following User Says Thank You to Lex For This Useful Post: | btstarcher (10-07-2013) |
![]() | | #164 | ![]() |
(Thread Starter) |
__________________ SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQSOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW! MS3 vs Focus ST vs Camaro LS1 ---> Click here TEH MEXICAN'T PERM! Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes | |
![]() | | #165 | ![]() |
| Not Ranked : 0 score Maybe it's just me but your fuel pressure seems high. Mine is only in the 400-500 psi area at idle. About a month ago I had an issue where I kept getting a P0303 code but my idle fp was 200-300 psi and wot fp was down to 1600ish where it was normally 1800. I narrowed it down to it either being an injector issue or my relief valve. I'm mostly sure it was my rv because fuel pressure dropped when the engine was off and warm. I never resolved the issue though because my fp returned to normal right before I was going to buy a replacement rv. I haven't had any issues since and there haven't been any codes. Also here's what Mazda says about P0302 Screen Shot 2013-10-07 at 6.30.31 PM.png If I was in your position I'd check all the wiring again to see if anything is amiss. If it all checks out then try something like this to check injectors. Screen Shot 2013-10-07 at 6.40.14 PM.png
| The Following User Says Thank You to Mazdazilla6 For This Useful Post: | Tokay444 (10-07-2013) |
![]() | | #166 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Nice. Mazda can control individual injectors with their scan tool.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #167 | ![]() |
(Thread Starter) |
:S
![]() | | #168 | ![]() |
![]() Join Date: May 2009 Location: Chicago, IL
Rep Power: 10249 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,116
Groans: 136
| Not Ranked : 0 score Also as a quick check if you haven't already done it: take out the #2 coil and swap it for another cylinder. See if the misfire moves. Pull the plugs and see if #2 shows any damage; if not, clean them up and move the plug to a different cylinder. See if the misfire moves.
__________________ |
![]() | | #169 | ![]() |
| Not Ranked : 0 score He swapped coils but not plugs yet....
| The Following User Says Thank You to btstarcher For This Useful Post: | silvapain (10-08-2013) |
![]() | | #170 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
| Not Ranked : 0 score I'm going to speak for ganque in case it might move along the discussion, but he has already moved coils and replaced plugs.
Sent from my LG-MS770 using Tapatalk now Free
__________________ it's fun to do bad things | |
| The Following User Says Thank You to jack_hammer For This Useful Post: | silvapain (10-08-2013) |
![]() | | #171 | ![]() |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score im no expert at all, but in the vid i see your temp gauge is at the cold side. was the fp higher because the idle was higher to warm up the car? it came down a bit in the vid as i assume idle was settling with temp
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
![]() | | #172 | ![]() |
![]() Join Date: Jul 2013 Location: Streetsboro ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
(hooking up a air compressor to cylinders etc) id message daafisch, i remember him mentioning that his compression results werent to far apart or something, then it turned into a catastrophic mess | |
![]() | | #173 | ![]() |
Groans: 793
| Not Ranked : 0 score Same here. Compression is +/- 2psi. Leak down 31% on cyl 3. Lol.
![]() | | #174 | ![]() |
Groans: 793
| Not Ranked : 0 score Are you consuming any oil homie?
| The Following User Says Thank You to Tokay444 For This Useful Post: | azazelthegreat (10-11-2013) |
![]() | | #175 | ![]() |
| Not Ranked : 0 score I think he found a bad injector.
![]() | | #176 | ![]() |
Groans: 549
| Not Ranked : 0 score That's got to be disconcerting to anyone who takes comfort in good compression numbers Sent from my LG-MS770 using Tapatalk now Free
![]() | | #177 | ![]() |
![]() Join Date: Dec 2011 Location: Wooster Oh, 44691
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,721
Groans: 769
| Not Ranked : 0 score A compression test just shows that the engine can compress the air and fuel where a leak down test will tell you if it can hold that pressure as well as where its bleeding off.
__________________ 2011 Mazdaspeed 3- AccessPORT V2, Autotech HPFP Internals, 3 Bar MAP Sensor, 3" Catless Downpipe, CPE Stage 2 RMM, CPE TMM, Custom Saikou Michi OCC, CXR FMIC, Devils Own DVC-30, Forge V2 BPV, 3.5" HTP Intake, JBR TIG's, MME Shifter Bushings, NGK LTR7IX-11's, PNP Intake, SPEEDPERF6MANC3 Valve Cover Breather 2004 Mazdaspeed Miata #3142- Stock, but not for long. ![]() Equal rights for all, special privileges for none. ~ Thomas Jefferson |
![]() | | #178 | ![]() |
![]() Join Date: Jan 2011 Location: Vancouver BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score Going to resurrect this shit b/c I'm throwing p0302s all day, rando p0300s and I'm on my 2nd qrt of oil between oil changes (not a full 2nd qrt tho, just up to 1.5L with 2200km's to go before next oil change). What would this extra oil consumption mean besides something bad?
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters |
![]() | | #179 | ![]() |
Groans: 793
| Not Ranked : 0 score BESIDES something bad? Nothing. It's something bad.
| The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #180 | ![]() |
![]() | | #181 | ![]() |
![]() Join Date: Jun 2014 Location: Westminster, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score Another thread revival. I'm displaying similar symptoms that are worsening recently (possibly colder weather) My exception is that I have a warranty replacement motor from mazda with ~4000 miles on it sooo I'm assuming that the cylinders hold pressure just fine and that the valves are pretty clean. Dealership mentioned that I might need injectors prior to swap but never replaced/mentioned it again. Time to check injectors?
__________________ 06 MS6 Sport,ZZB and warranty motor replacement 8/9/14 SU SRI w/ COBB MAF:::JBR TIP:::JBR 80aTRILOGY:::Strat+ Base Map:::MATT DAMOND FULL EGR DELETE:::VTCS Delete:::CP-E SafeSeals [SIGPIC][/SIGPIC] |
![]() | | #182 | ![]() |
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters | |
![]() | | #183 | ![]() |
| Not Ranked : 0 score 68,xxx. I've had it looked at and I don't think it's anything to do with the injectors at this point but we'll see
![]() | | #184 | ![]() |
| Not Ranked : 0 score I'll re-reference my recent thread for some moar infos: How I (seem to have) fixed my Early Speed6 Misfire Issue Is yours the early model speed6 or post 2006.5?
![]() | | #185 | ![]() |
| Not Ranked : 0 score Thank you I just read through that. And at risk of sounding like a brownie fuck-tard, I didn't know there was a difference with the ms6
![]() | | #186 | ![]() |
Mazda made a few changes mid production.
![]() | | #187 | ![]() |
![]() Join Date: Mar 2019 Location: Germany
Rep Power: 13 ![]() ![]() Thanks: 4
| Not Ranked : 0 score sorry for posting in your old thread, but we didnt get the answer to these problems. did you solve the startup misfire you posted years ago?? got the same issue and already changed coils, spark plugs and injectors and tested compression. I got spark and suspect the already changed clean injector to bei failing. but idk for sure if something bad is happening in this cylinder for some reason. greets from germany |
![]() | | #188 | ![]() |
![]() Join Date: Jun 2009
| The Following User Says Thank You to MSMS3 For This Useful Post: | Vansquish (06-24-2019) |
![]() | | #189 | ![]() |
| Not Ranked : 0 score i tried before, but dont have permission with only 1 post on my account. Would you mind, send a pm to him for me and help some buddy from overseas |
![]() | | #190 | ![]() |
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
As far as diagnosing your problem, have you tested the harness to see if there are any weaknesses? Specifically, have you checked the ignition harness to make sure that there are no broken/bent pins that would cause cylinder 2 to get weak or no spark? Similarly, have you checked the injector harness for the same sorts of faults?
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following User Says Thank You to Vansquish For This Useful Post: | ghost-rider (06-25-2019) |
![]() | | #191 | ![]() |
| Not Ranked : 0 score youre right sir, i saw the video on top of this page from "ganque". Already saw a lot of threads an contacted a lot of people since over a year with this problem, and never got an advice which solved this problem, just the started threads... you know this problem on the internet for sure. Hopefully its okay to use this thread for my personal problem. Otherwise is will start a new one. I tried new and old coils and spark plugs, they all worked well and got strong spark. Checked compression on cold engine (not optimal, i know) tested all cylinders with 135-140 psi. Only on cylinder 2 i dont see any response if i unplug the coil, so i would think on injectors, but these got cleaned an checked recently. Curious the misfire only persists in idle oder very low rpm, if i push on the pedal it seems to work. I will check the injector harness next and clean the plugs, as i lubed the o-ring with engine oil there could be a culprit. Even when i cleaned with brake clean after. |
![]() | | #192 | ![]() |
| What was the gap on the spark plugs that you installed?
![]() | | #193 | ![]() |
| Not Ranked : 0 score installed the genpu Plugs ILTR6A-7G, and tested also the old 8G Plugs which were only 2 years old. The Coils were also NGK, new ones mod. 42899. Also changed Intake Manifold and Throttle Body Gasket, aswell as Header and both Turbogaskets as i installed a new Turbocharger at this point. I got an primary EGR Delete and added also new Gaskets to be sure and threadsealant on the Plug in the Intake Manifold. Will check the harness, if some of the lubrication oil got inside the plugs an clean them with contactspray. You can see the jumping stft in the logfile |
![]() | | #194 | ![]() |
| You didn't answer the question. What was the gap in the spark plugs? Did you check to make sure that they were in spec between 0.024 and 0.027 inches (about 0.61mm - 0.68mm)?
| The Following 2 Users Say Thank You to Vansquish For This Useful Post: | ghost-rider (06-26-2019), MSMS3 (06-25-2019) |
![]() | | #195 | ![]() |
| Not Ranked : 0 score Not to pile on but proper plug gap is critical on this particular engine. Vanquish is right to ask you twice. They need to be tighter than most sets come from the factory and never trust the factory to get them right, anyway. The fine wire iridium tip is very easily damaged in gapping. Do not use a gapping tool that scrapes that tip. I don't know if that solves your problem, but it will eliminate one variable.
| The Following User Says Thank You to MSMS3 For This Useful Post: | ghost-rider (06-26-2019) |
![]() | | #196 | ![]() |
| Not Ranked : 0 score yes sure, i gapped them just a little bit more than they were stock to 0.65, the old ones were 0.8 as spec. No gapping on these ones was needed to spec. Do you think that some engine oil could make its way into the injector plug also because of oiling the o-ring? i dont get you wrong guys, im familiar with this platform since 6 years now, before i had a 3 MPS and for over 2 years the 6 now Last edited by ghost-rider; 06-26-2019 at 12:50 PM. |
![]() | | #197 | ![]() |
| Not Ranked : 0 score i took the intake manifold off today an cleaned the harness connectors and injector connectors with electric cleaner, now i get a response from cylinder 2 when i unclip the coil. Not as much noticable as when i took the other cylinders off but still hearable from the exhaust. With the cylinder 2 unclipped i get much more misfires at idle. Hold the RPM at 2000 for expample and get no misfires, mysteriously. Sure without the Intake on the car, the MAF was not on the car at this moment, it runs in limp mode. How about the o2?? That would be my last idea, as the ECU just regulates with the o2 and throttle?
__________________ HM-Upgrade K04 Turbocharger, 3" Corksport Catted DP, 3" FMS Catback Exhaust, HG-Motorsport HPFP Internals, Upgraded TMIC, Silicone Turbo Inlet Pipe+Neck, Silicone Intercooler Hose, Simota Podfilter, GFB Mach 2 BPV, Primary EGR Delete Kozmic, PTFE Intake and Throttle Gasket, Throttle Coolant Delete, Cobb Accessport V3 |
![]() | | #198 | ![]() |
| Not Ranked : 0 score no one looking at the video or log yet??
| P0302 misfire... | SlickDevil | Gen2 MS3 General Discussion | 42 | 08-24-2016 08:48 PM |
| p0302 misfire only under pressure? | Fan2zo | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 12 | 02-06-2015 05:48 PM |
| Injector seals - need to replace injector/fuel line O-rings? | TheRealDefman | 2010 MS3 - Engine, Transmission & Driveline | 3 | 03-02-2014 09:35 PM |
| Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon | Haltech | Automotive News | 3 | 04-17-2010 08:40 PM |
