Like Tree17Likes
 Old 08-31-2013, 03:01 PM   #1
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Groaned at 9 Times in 9 Posts
Unhappy Help! P0302 issue! Possible injector failure?
EDIT:
New issue started a week ago. Now getting P0302. Please go directly to post
#149
http://www.mazdaspeedforum.org/forum/foru...ml#post2285548
Everything else got resolved (boost leak and ECU issues).
Sup everyone,
So after installing the Matt Damond SSP and replacing my DO7 nozzle I took my car for a spin and looks like it started to act really weird when the turbo starts to spool.
I decided to take it back home and checked my STFT and they where around -7% on idle and then got back to 0% ~ -2%.
I decided to check the SRI pipe, MAF housing, everything was fine... did a hard reboot on my ECU... reflashed my AP map... still the car gets those numbers on idle.
When I take my car for a drive if I try to add some load to the engine it feels like it's running rich, and gets come hicups...
Decided to replace my spark plugs today, brand new NGK.... still same issue...
Did a compression test, here are the results:
138
140
155
155
I may have done the compression test in a wrong way since I didn't remove all the plugs, just 1 by 1 and kept the engine running.... So that might be my bad... but again it doesn't sound like a cracked piston, or rings from my experience.
My theories are either a bad coil, or well worst case scenario a cracked piston...
Any ideas???
Attached are 2 logs:
One on idle and another one revving it at 3000 rpms.
Please help
EDIT:
Forgot to mention that spark plug on cyl #1 was soaked in oil... checked oil and it was overfilled with almost a quart... removed the excess and it's still doing the issue...
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
 Old 08-31-2013, 03:12 PM   #2
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
To do a compression test you need to keep the engine from firing. You don't have to pull all the plugs to do this but you might aswell. With your compression tester installed in place of a plug you need to hold the throttle wide open and crank until the pressure stabilizes.
 Old 08-31-2013, 08:50 PM   #3
Police
ganque's Avatar
still.. the engine doesn't sound like a bad piston/rod issue...
Any other idea?
@jack_hammer; @Lex; @silvapain;
TEH MEXICAN'T PERM!
 Old 08-31-2013, 10:04 PM   #4
You mentioned this happened right after you replaced the D07 nozzle. Based on LTFTs the first thing I would do is a boost leak check.
theurgy likes this.
btstarcher (08-31-2013), El_Diablo (09-01-2013), rfinkle2 (09-01-2013), silvapain (09-03-2013)
 Old 09-01-2013, 11:51 AM   #5
Police
ganque's Avatar
The only things that I moved where the intake and TIP, but that might be true... I need to get a boos leak tester.
What about a bad spark coil? Could that also be a possibility? I'm so worried to see a bad piston ring, cause I only saw oil on cylinder #1 .
Sent from my iPhone using Tapamex
TEH MEXICAN'T PERM!
 Old 09-01-2013, 02:15 PM   #6
El_Diablo's Avatar
Groans: 769
You can move the plug and coil each to different cylinders. If the issue moves with the coil or the plug you know where your issue lies.
 Old 09-01-2013, 02:54 PM   #7
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
haha buddy, i'm flattered to be mentioned with lex & silvapain, but i obviously am no gear head.
the first thing i would suggest is to take a deep breath. you always think of the worst possible scenario.
i think you're working a couple different issues. so, try to keep the separate in your head until you see they're related.
1) the AFRs. as mentioned previously, check for leaks.
2) compression - different people do them differently and still consider their way the "right" way. i take a simple approach. remove all plugs. hook up tester to #1 . crank until the needle stops moving. i do not hold down the throttle. then, do the next one. also, if your readings are varied (less than 15% of each other) then maybe try a wet test, too. drop a shot of oil in the cylinder and retest. just try to add the same amount of oil to each so you can get consistent results.
3) oil on spark plug. could easily be related to the compression. but i'm not sure what you mean by spark plug coil. do you mean spark plug or coil pack? like diablo said, though, you can move them around and see if the issue follows. i would not put the #1 plug with the #1 coil pack, though. just make a note of what you do so you don't forget.
take your car apart, put it back together carefully. drive around and see what happens. don't panic about the oil and compression. there's no need. if your engine is toast, then worrying won't fix it.
ganque and budzinski like this.
it's fun to do bad things
 Old 09-01-2013, 06:16 PM   #8
Even with a bad ringland you are unlikely to get sputtering on spool. People run with these around without too much in terms of driveability. Take a log showing the symptoms.
 Old 09-01-2013, 06:17 PM   #9
btstarcher's Avatar
Posts: 4,852   (View Stats)
My money is on where the TIP meets the turbo.
SnailTune in progress
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
Easter Bunny (09-07-2013), ganque (09-01-2013), rfinkle2 (09-01-2013)
 Old 09-01-2013, 10:30 PM   #10
Police
ganque's Avatar
Thanks everyone for your feedback...
I'm planning on getting my coil pack replaced with a friend's MS3, also will remove entirely the TIP and reinstall everything.
TEH MEXICAN'T PERM!
The Following User Says Thank You to ganque For This Useful Post:
btstarcher (09-02-2013)
 Old 09-02-2013, 09:24 AM   #11
Police
ganque's Avatar
took the TIP off, redo everything from turbo to air filter... same issue...
Last hope is the coil pack...
TEH MEXICAN'T PERM!
 Old 09-02-2013, 10:36 AM   #12
Groans: 549
Are you sure the meth is flowing like it should?
 Old 09-02-2013, 10:42 AM   #13
Police
ganque's Avatar
100% sure.
TEH MEXICAN'T PERM!
 Old 09-02-2013, 08:55 PM   #14
btstarcher's Avatar
Wouldn't a vacuum leak also give you wonky idle afr's?
 Old 09-02-2013, 10:32 PM   #15
I have been surprised by leaks before - redoing an intake is not as effective as pressurizing it and if you have a compressor handy it's a very easy test to do.
 Old 09-03-2013, 12:58 AM   #16
btstarcher's Avatar
You're vacuum is only aroun -8.4, has it always been like that?
 Old 09-03-2013, 07:07 AM   #17
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
A couple things I noticed in your logs:
1. In the 3,000 RPM log, your LTFT's indicate you are in Open Loop, but you shouldn't be based on the boost PSI, throttle position, and calculated load.
2. Your Boost Air Temps are very high in both logs.
3. You are commanding WGDC even at idle.
4. Your vacuum readings are low in both logs.
5. The Mass Airflow reading in the idle log is very low. It should be around 6ish g/s, especially when you're idling at 900 RPM.
I suggest you build a boost leak tester and see what you find:
How-To NATOR A Boost Leak Tester for $15
How to DIY Boost Leak Tester
http://www.mazdaspeedforum.org/forum/foru...st-leak-89918/
The Following 4 Users Say Thank You to silvapain For This Useful Post:
btstarcher (09-04-2013), El_Diablo (09-03-2013), JTMS3 (09-03-2013), Little John (09-04-2013)
 Old 09-03-2013, 08:09 AM   #18
Police
ganque's Avatar
Thanks for all your responses. I ran a few tests last night, a friend came visit with his MS3 and I used his coil packs on my car, same issue, used his MAF same issue.
So yeah, I still have the Boost leak theory (which I will definitely address it today), but there's also another theory that might be related to bad gas. I've seen it tons of times where people find out that gas is mixed with water.... fucking gas stations are doing that...
What do you guys think?
Here's another interesting fact. Whenever I start the car it does sounds fine for the first 10 or 15 seconds, then after that everything just crashes... So those first 10 seconds the car runs on 0 on STFT and -10% LTFT. Then after that same thing from what you saw on my logs.
But yeah I'll run a boost leak test... I just need to get a compressor and all the things..
So @silvapain; from what I saw on those threads, I just need to connect the pressurized line into the TIP and that's it?
For some reason the AP has always read -9 ~ -8 on vaccum, however my dashhawk reads -18 ~ -19
TEH MEXICAN'T PERM!
Last edited by ganque; 09-03-2013 at 08:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-03-2013, 08:35 AM   #19
Groans: 549
i would build the tester so you can put it on your intake. just remove the filter and install the boost leak tester. that way you can make sure you're not leaking out of your maf housing as well.
 Old 09-03-2013, 10:05 AM   #20
silvapain's Avatar
Groans: 136
Luis, the DashHawk reads vacuum in inHg, and the AP reads in PSI.
It probably runs fine for the first several seconds because its in OL when you first start the car.
ganque (09-03-2013), phate (09-10-2013)
 Old 09-03-2013, 10:17 AM   #21
Police
ganque's Avatar
Thanks for this great info Dan!
I'm definitely running a boost leak test today... crossing fingers
TEH MEXICAN'T PERM!
 Old 09-04-2013, 11:57 AM   #22
Groans: 549
and then?
 Old 09-04-2013, 04:49 PM   #23
btstarcher's Avatar
Dumb question but is the OCC installed correctly? Hoses on tight?
 Old 09-06-2013, 06:27 PM   #24
Police
ganque's Avatar
and then?
I finally made my boost leak tester, I just need to get an air compressor. It's been an entire week already I just want this to go away
My current theories are:
- Leak at the inlet pipe from the BPV return line
- Leak from the purge valve? (not sure since there arent any CELs yet...
- Leak somewhere in the PCV? My PCV is still stock and no OCC installed yet
- Exhaust leak
- Bad Gas (some gas stations in Mexico might have water on their gasoline which is BS
TEH MEXICAN'T PERM!
The Following 2 Users Say Thank You to ganque For This Useful Post:
btstarcher (09-07-2013), jack_hammer (09-07-2013)
 Old 09-07-2013, 08:33 AM   #25
Police
ganque's Avatar
Crap. P0302 - Misfire on cyl #2 just popped! this was while cold start....
TEH MEXICAN'T PERM!
btstarcher (09-07-2013), El_Diablo (09-08-2013)
 Old 09-07-2013, 10:55 AM   #26
btstarcher's Avatar
Awwwww shit.....
 Old 09-07-2013, 02:19 PM   #27
Police
ganque's Avatar
Just checked for boost leaks, found 2 but still having the same rough idle...
No exhaust leaks at all... @Tokay444;
I'm going to remove the TIP again.... Going to do a closer inspection this time
ozziewog likes this.
TEH MEXICAN'T PERM!
btstarcher (09-07-2013), silvapain (09-08-2013)
 Old 09-07-2013, 02:21 PM   #28
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Check that turbo too while you're there.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 09-07-2013, 02:51 PM   #29
Police
ganque's Avatar
I actually checked the turbo last weekend while I removed the TIP, no issues from what I can tell, however I'll take video from it, I'm just waiting to it to cool down.
Maybe it's just bad gas. What do u think?
TEH MEXICAN'T PERM!
Last edited by ganque; 09-07-2013 at 02:51 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-07-2013, 03:01 PM   #30
Tokay444's Avatar
Groans: 793
I'm not sure about that.
Demodded.
The Seals
 Old 09-07-2013, 03:15 PM   #31
Police
ganque's Avatar
TEH MEXICAN'T PERM!
Tokay444 (09-07-2013)
 Old 09-07-2013, 03:34 PM   #32
Police
ganque's Avatar
TEH MEXICAN'T PERM!
 Old 09-07-2013, 03:39 PM   #33
Pull the spark plugs again. Is one still covered in oil? If yes, you have to look at the cylinder a little bit more closely.
 Old 09-07-2013, 04:04 PM   #34
Police
ganque's Avatar
I did that this morning, all plugs are clean and look good.
Ok guys so I've just reinstalled tip, issue is still going however the STFT changed a LOT.
Now it's between 0.62 and 1.40 on idle. LTFT are -7.96.
I'm really thinking that could be bad gas? It's mexico... you know...
TEH MEXICAN'T PERM!
AZSPEED3 (09-07-2013)
 Old 09-07-2013, 04:05 PM   #35
Police
ganque's Avatar
Another fact is that I changed my O2 sensor about a month ago... Could be also that?
TEH MEXICAN'T PERM!
 Old 09-07-2013, 04:22 PM   #36
Give the LTFTs time to settle. With STFTs in that range they will be close to zero and it seems you did fix a leak if the LTFTs are returning to 0.
 Old 09-07-2013, 04:36 PM   #37
Police
ganque's Avatar
Good!
So I took the car for a spin, when I started it went to -3.28 then after a few seconds jumped to -1.78 and stayed there for about a minute and then to 1.40. All this time in idle.
LTFT are still in -9.42.
There must be another leak somewhere cause I can spool the turbo on mid throttle but it fails when I go WOT.
I got another misfire on cyl 2 again.... WTF
TEH MEXICAN'T PERM!
 Old 09-07-2013, 04:38 PM   #38
SilverDemon's Avatar
Posts: 3,034   (View Stats)
What is the commanded afr? I am thinking that the narrow band O2 sensor could be the culprit. Since the stft and the ltft are well with in a "normal" range I would bet that the ecu is commanding the higher afr because of the feed back from the O2.
Edit: Do you have a way to log secondary O2 sensor voltage ?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 09-07-2013, 04:50 PM   #39
Take a log of this spooling and "failing." The logs tells you (and us) a lot of information about what is going on.
 Old 09-07-2013, 05:34 PM   #40
Police
ganque's Avatar
not sure if the AP does that, but I also have a Dashhawk. Which one should I use?
here is a video of the turbo check:
0FA14EEF-ABDA-42E3-8C59-C08DBDEA0CC0-450-000000218122D8B8_zpsad8b5174.mp4 Video by ganque | Photobucket
TEH MEXICAN'T PERM!
Last edited by ganque; 09-07-2013 at 05:34 PM. Reason: MSF Database - Automerged Doublepost
P0302 misfire... SlickDevil Gen2 MS3 General Discussion 42 08-24-2016 08:48 PM
p0302 misfire only under pressure? Fan2zo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 02-06-2015 05:48 PM
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Report: Toyota confirms Lexus GX handling issue, hoping to isolate issue soon Haltech Automotive News 3 04-17-2010 08:40 PM
Page generated in 0.55637 seconds with 28 queries
