 Old 01-29-2019, 03:06 PM   #1
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
The important thing is to have near equal reading and this is about what you got.
The altitude, gage, tests conditions etc can affect the final numbers but all 4 will be affected by the same parameter so if all 4 are equal, it is looking very good. I wouldn't worry about it.
Your #2 is a bit lower but it isn't a ringland, it would be worse than this.
i was worried at first because peoples talk about +/-180psi and the best i got with any of the 3 mzr i had + 1 rebuild, remain at best at 165psi.....I tested 2 gages and i used the same place to test them with throttle body opened etc and i never got 180 on any...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Reds3 (01-30-2019)
How to take account of high compression pistons EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 15 01-21-2017 04:43 PM
High Compression Input - DD use GroceryGtr MazdaSpeed 6 - Engine, Transmission & Driveline 8 11-27-2015 06:13 PM
Looking at high mileage MS6... anesthetize Mazdaspeed3/6 General Discussion 9 08-05-2015 02:06 PM
Mazdafreak's High Compression Build! mazdafreak Mazda MZR DISI Engine Builds (2006-2013) 159 06-04-2015 06:44 AM
Page generated in 0.24806 seconds with 21 queries
