Like Tree5Likes
 Old 07-10-2012, 09:33 AM   #41
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Wait, you guys don't have a way to vent under hood heat? huh? OH YEAH FORGOT GEN 1 SUCKS!
The Following User Says Thank You to G26 For This Useful Post:
f-castrillo (07-10-2012)
 Old 07-10-2012, 01:52 PM   #42
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
When correctly venting a hood you have to have balls lol
I just kept cutting until I liked it....and trust me you can tell its working very easily. Just watch the heat rise or put your hand over it. Its ridiculous how much hot air comes out of that vent! And soon ill have the entire back porition of the engine bay blocked off with a heat treated fiberglass barrier with only a connection to the hood vent so all of the turbo/exhaust heat stays contained in the back away from my IC piping and gets released out the vent through suction effect while driving. Ill post more once the setup is complete.
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
The Following 5 Users Say Thank You to ESB Jiu JItsu For This Useful Post:
f-castrillo (07-10-2012), Hectik1 (07-10-2012), IshiKage (12-02-2012), Jh8909 (07-10-2012), Juyoung (05-09-2013)
 Old 07-10-2012, 06:31 PM   #43
mason's Avatar
Posts: 946   (View Stats)
tried uploading pics
 Old 07-10-2012, 06:33 PM   #44
mason's Avatar
were did you get that vent? i like it. link?
 Old 07-10-2012, 07:45 PM   #45
I made it myself just drew a template i liked in some design software and cut it out on my cad table, then traced it on the hood and cut. then lined the edges with rubber molding and plastidiped a screen for the mesh on top.
I had a thread about it a long time ago but it was delete for some reason.... if i have time ill write it up again
The Following 2 Users Say Thank You to ESB Jiu JItsu For This Useful Post:
Code Monkey (07-13-2012), mason (07-11-2012)
 Old 07-11-2012, 06:58 AM   #46
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
More pictures, please!
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
 Old 07-11-2012, 07:21 AM   #47
Prior to my spring install but a good angle on the hood vent
This shows the grill material i used, just some stuff from home depot coated in plastidip
86AmishMs3 likes this.
The Following 7 Users Say Thank You to ESB Jiu JItsu For This Useful Post:
86AmishMs3 (07-14-2012), BigjohnB20 (07-11-2012), Code Monkey (07-13-2012), deadlandxtreme (07-11-2012), Hectik1 (07-11-2012), jracer (07-14-2012), Juyoung (05-09-2013)
 Old 07-11-2012, 07:29 AM   #48
jfspeed6's Avatar
Posts: 1,508   (View Stats)
jfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the worldjfspeed6 is the leader of the world
A friend of mine graphed a 2011 wrx scoop in his MS6 hood.
fredricktsang likes this.
2006 Titanium Gray Mazdaspeed6 GT
2002 Mercedes Benz CLK 430 Cabriolet
jfspeed6 is offline   Reply With Quote
The Following 8 Users Say Thank You to jfspeed6 For This Useful Post:
breakfstincluded (07-12-2012), Code Monkey (07-13-2012), Hectik1 (07-11-2012), jax ms3gt (07-14-2012), Jonathan92c (07-11-2012), Juyoung (05-09-2013), n810e (05-09-2013), Tenchix (05-08-2013)
 Old 07-11-2012, 07:30 AM   #49
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Hasn't anyone considered the factory airflow pattern of this car? In the front, out the rear bottom........are you going to do some panels to direct air in the path you want it to take now?
meicalnissyen likes this.
07 MS3
The original Genpoo Hater
 Old 07-11-2012, 07:33 AM   #50
My vent flows perfectly out the top I had attached tape and string to make sure the flow was correct. The flow against the windshield pulls air out of the vent when moving and allows air to vent naturally (heat rises) out the vent in traffic or at stops. Also since the air is being pushed in through the front air dams thats naturally where it will then escape. I have under hood temp readings i did last year when I did the mod and the drop, Ill have to find it
 Old 07-11-2012, 07:48 AM   #51
DiGi Faggot's Avatar
Posts: 1,212   (View Stats)
DiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the worldDiGi Faggot is the leader of the world
Groans: 148
Groaned at 89 Times in 51 Posts
Hood Vents :: Oman4x4.com
These louvers will look good IMO.
DiGi Faggot is offline   Reply With Quote
The Following User Says Thank You to DiGi Faggot For This Useful Post:
mason (07-11-2012)
 Old 07-11-2012, 01:04 PM   #52
chuckms6's Avatar
Posts: 1,618   (View Stats)
after you mentioning it in the other thread i took a look and youre right, but that doesnt allow for as much heat to escape that way. now with underbody panels channeling air to a rear diffuser or another method to increase airflow in that direction, that would be the ideal method for airflow. however, at this point venting through the hood area shows marked decreases in underhood heat, and you cant argue with results.
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
 Old 07-11-2012, 04:58 PM   #53
mason's Avatar
also when you add a FMIC it changes alot of the factory air flow values. i know that venting my hood helped alot with temps. even though im not done with it.
ESB Jiu JItsu likes this.
 Old 07-14-2012, 03:01 AM   #54
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I've been thinking about doing some naca ducts maybe one or two in my hood, and in carbon fiber for some street cred haha. I think this would be the easiest and probably look the best without needing to paint. Would compliment doing @PapaSmurf 's mod of using hood spacers to get that higher pressure air out.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 4 Users Say Thank You to 86AmishMs3 For This Useful Post:
breakfstincluded (05-08-2013), ESB Jiu JItsu (07-14-2012), Snyeed (07-14-2012), weakdog85 (08-01-2012)
 Old 05-08-2013, 02:40 PM   #55
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
I like the idea of the vent right on top of the turbo area. What the E46 M3 has also looks similar.
The Following 3 Users Say Thank You to breakfstincluded For This Useful Post:
mxlplx71 (05-08-2013), Tomas (05-09-2013), Voltwings (05-08-2013)
 Old 05-08-2013, 03:24 PM   #56
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
i did mine, whos next to release the heat?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 2 Users Say Thank You to mxlplx71 For This Useful Post:
AdamBomb (06-07-2013), breakfstincluded (05-08-2013)
 Old 05-08-2013, 03:30 PM   #57
BMW E46 M3 S54 3.2L > Exterior > View All > ES#77805 Hood Vent - 51132694723
this place has those vents for 22.38 btw if anyone wants to give it a try and upload pics (:
I'd just like to know if it had any kind of rain guard stock too
 Old 05-08-2013, 03:33 PM   #58
Voltwings's Avatar
Posts: 3,713   (View Stats)
The rain guard is it evaporating the second it hits your turbo / manifold haha.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
breakfstincluded (05-08-2013), mxlplx71 (05-08-2013)
 Old 05-08-2013, 03:36 PM   #59
mxlplx71's Avatar
Groans: 128
its going to rain here tomorrow, i'll let you know what happens
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-08-2013, 03:38 PM   #60
Voltwings's Avatar
I would love to make some sort of little box or enclosure around the turbo / manifold and use this to evacuate the heat. Maybe add some ducting from under the car from the fog lights or something to feed the enclosure and further evacuate the heat ... I think a vent behind the gen 2 hood scoop would look really stupid, but man is it tempting.
Past:
-Sold-
-Sold-
Current:
 Old 05-08-2013, 03:51 PM   #61
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
 Old 05-08-2013, 03:52 PM   #62
Voltwings's Avatar
Well I had my sister photoshop this up real quick, granted the scale of the pics may be off, but that E46 vent may almost be too small. Anyone else want to take a crack at this?
Past:
-Sold-
-Sold-
Current:
 Old 05-08-2013, 03:56 PM   #63
mxlplx71's Avatar
Groans: 128
i like it. i wouldnt make it so wide that it would be over the alternator unless you fashion a rain guard.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-08-2013, 04:06 PM   #64
Voltwings's Avatar
Yeah, I like where its going, I would just want it to look like it belonged there. Hell for $20 I may just grab one anyways and see what happens, may just plastidip the whole damn hood black haha, then it'll blend right in.
Past:
-Sold-
-Sold-
Current:
 Old 05-08-2013, 04:39 PM   #65
mxlplx71's Avatar
Groans: 128
the hood overlaps the firewall about 4" on genones
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-08-2013, 05:06 PM   #66
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
Looks like an '08+ Shelby GT500 scoop would work quite well on an MS6 and theyre fairly cheap. A lot of fox body and sn95 guys are using them on their road race cars.
 Old 05-08-2013, 05:53 PM   #67
mxlplx71's Avatar
Groans: 128
10-12 shelby
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
El_Diablo (05-09-2013)
 Old 05-08-2013, 07:35 PM   #68
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Doing this is going to disrupt the cooling airflow designed by the engineers. Air flows in the top and out the rear bottom of the engine bay. You open up another hole and you'll increase turbulence and slow down the airflow allowing less heat to escape.
Wanna understand more? look at a Ferrari and find info on how the vents and stuff are designed. Sure, we're not a Ferrari, but the airflow was designed in such a manner from the factory to move air through the engine bay, not just let air in or out at any old place.
07 MS3
 Old 05-08-2013, 07:57 PM   #69
I feel the same way, I wouldn't want my hood to start looking like those SRT4's that stick on their equivilant of shaker hoods.
I'd also be concerned with airflow and negative pressure areas and such, I don't understand it too well. I know I wouldn't mind if the K04 was cooler though.
 Old 05-08-2013, 07:58 PM   #70
mxlplx71's Avatar
Groans: 128
my tmic and vents ar off my car. the area where the ducting was is blocked off now so the only air entering my engine compartment come through the fmic and radiator.
i almost never do any highway driving.
sitting in stop and go traffic or in the staging lanes at the track, this is the only way to get heat out, and there's alot.
do alot of ferraris have turbos? idk, i dont read up on exotic cars much.
i can understand not wanting to cut up your car, thats why i bought a hood to f up and keep my stocker for winter.
...if you could see the heat pouring out, you may understand.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-08-2013, 08:08 PM   #71
stlskater92's Avatar
Posts: 78   (View Stats)
stlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond repute
Yes, our hoods/bays are designed to flow air through the car a certian way. but think, the second you add even so much as intake, let alone a FMIC you completely change the dynamics of the car. Air pockets will get created and you need to find ways to cure this problem. I've been messin with paper models since before I pulled the motor in my car, there's defiantly better ways to vent/flow air through the bay than the OEM options once you start doing any heavy modding.
White 2009 MS3:
100k mile pig
HTP built
gt3076r powered
6th port fueled
Tuned by Nishan
Black 2008 MS3:
under construction
#700orbust
stlskater92 is offline   Reply With Quote
The Following 2 Users Say Thank You to stlskater92 For This Useful Post:
El_Diablo (05-09-2013), mxlplx71 (05-08-2013)
 Old 05-08-2013, 09:07 PM   #72
chuckms6's Avatar
People keep saying this, but I see more evidence of the contrary in threads like this and my own personal results. My intake temps dropped 20°-30° when I pulled the weather stripping. I think there is more air entering the engine bay through the radiator than can exit the engine bay through the stock air route.
Sent from my SAMSUNG-SGH-I727
The Following User Says Thank You to chuckms6 For This Useful Post:
 Old 05-08-2013, 09:35 PM   #73
mxlplx71's Avatar
Groans: 128
2013 Shelby Focus ST | Photo Gallery - Yahoo! Autos
i know its an ST,,, but hood vents.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 05-08-2013, 10:03 PM   #74
crtguns's Avatar
Posts: 464   (View Stats)
crtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the world
Groaned at 340 Times in 107 Posts
This is in central CA, 98 degrees outside.
These mods:
1. Water wetter and distilled. No green shit.
2. Reroute passenger side duct down to radiator:
Make this:
Attach here:
Looks like:
3. dam up the driver side hood duct to only dump on the intake and battery. Cant get a good pic inside. The red marks the location of the dam inside the duct. The blue is a hole cut in the duct right above the SRI. This should be caulked when done to really trap air in the scoop.
The engine bay has proper ducting and louvres underneath to circulate the air while moving. Sitting still... not much you can do... period. The water wetter stuff helps a little. And being cooler when you get to the stoplight... takes longer for heat to climb up to bad temps
Next I'm working on ducts placed to the sides of the fmic to keep it all through the IC and AC and radiator. Too much gets pushed out to the empty areas in front of the wheels.
crtguns is offline   Reply With Quote
The Following 3 Users Say Thank You to crtguns For This Useful Post:
Chimmike (05-09-2013), mxlplx71 (05-08-2013), Voltwings (05-08-2013)
 Old 05-08-2013, 10:13 PM   #75
MS6 Sanchez's Avatar
Posts: 405   (View Stats)
MS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the worldMS6 Sanchez is the leader of the world
Groaned at 7 Times in 4 Posts
10-12 shelby
I think this would work best without disrupting too much airflow. The air flowing over this would create a vacuum thus sucking out the hot air... Kinda like the new jeep srt8 hoods
Edited: incorrect spelling
'06 Mazdaspeed6 Sport | LPM
MODS:
COBB SF | COBB TIP | SURE RMM | CXRacing FMIC | M2 DP | NGK Laser Iridiums | Magnaflow CB | COBB AP Stg 2 SF+TIH+IC 93 | Autotech FP Internals | JBR SSP, SSB, and Heavy Knob | EBC Ultimax Rotors | EBC Red Stuff Pads | Plastidipped Grill | 20% Tint all around 50% Windshield
I'm SO stock it HURTS
MS6 Sanchez is offline   Reply With Quote
The Following 2 Users Say Thank You to MS6 Sanchez For This Useful Post:
 Old 05-09-2013, 09:11 AM   #76
LocoMazda's Avatar
Posts: 48   (View Stats)
LocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to beholdLocoMazda is a splendid one to behold
So who wants to Photoshop the GT500 scoop on a MS6?
LocoMazda is offline   Reply With Quote
The Following User Says Thank You to LocoMazda For This Useful Post:
MS6 Sanchez (05-09-2013)
 Old 05-09-2013, 05:03 PM   #77
I have no engine......but my core support is taken off haha so I will post some pics of things I'm doing to it this weekend after the garage night on Saturday.
White 2009 MS3:
100k mile pig
HTP built
gt3076r powered
6th port fueled
Tuned by Nishan
Black 2008 MS3:
under construction
#700orbust
 Old 05-09-2013, 06:08 PM   #78
Novej's Avatar
Posts: 354   (View Stats)
Novej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the worldNovej is the leader of the world
Did you take both the front weather stripping and the rear weather stripping off....Or just the rear???
2007 Mazdaspeed 3 400.32whp 375.14wtq (STD) BNR STAGE 3 Stratified by Lex
Of all the military achievements I've accomplished my first 10 years of service (made MSGT/E-7 at age 29), the one that makes me most proud is simply being able to serve my country during her darkest hour...NEVER FORGET those who made the ultimate sacrifice doing the same....I SALUTE ALL OUR FALLEN
Novej is offline   Reply With Quote
 Old 05-09-2013, 06:27 PM   #79
chuckms6's Avatar
just the rear at first, but i pulled the ducting and front stripping eventually and saw an additional small gain.
 Old 05-09-2013, 06:28 PM   #80
86AmishMs3's Avatar
Groans: 338
what have you guys used to cut your hood?
Current: N54 135i
12.3@122
2009 Mazdaspeed 3:
390whp/400wtq
12.8@114
Sold
venting to atmosphere X lady killer X CX-7 > Engine, Transmission & Driveline 14 04-02-2011 10:28 AM
SURE TIP Installed, Noise when Venting Cue CX-7 > Issues & Troubleshooting 13 02-14-2011 11:24 PM
fucking venting bbjoy Mazdaspeed3/6 General Discussion 19 02-11-2011 11:20 AM
Page generated in 0.59058 seconds with 39 queries
