 Old 02-28-2018, 02:28 PM   #1
KhalidBiary's Avatar
Posts: 36   (View Stats)
KhalidBiary is on a distinguished road
Default How do I check VVT
I open up the oil cap to check the chain slack like everyone else but I have a plastic thing blocking it...
KhalidBiary is offline   Reply With Quote
 Old 02-28-2018, 03:41 PM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
You should be able to feel around that.
2010 black mica speed3
Soon:built motor
 Old 02-28-2018, 03:58 PM   #3
Lol my fingers aren’t that long
 Old 02-28-2018, 06:33 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Sorry for your significant other.
I felt my chain that way and it was loose. Bought all the stuff and went to change it out. Once I took everything apart, it all looked fine. So I boxed everything back up and it's going into my forged build. Put all my old stuff back on aside from new friction washers and crank bolt. Been running fine. That was 4-5 months ago.
What I found was, as the cams turn, the valve springs load them up differently through the rotations. Your chain will feel loose if the cams are being pushed towards each other at the top. A little turn of the crank and the chain might feel tight as fuck.
Long story short, you can't just check tension at one spot. Turn the crank a little, check again. Turn the crank a little more, check again.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 02-28-2018, 07:43 PM   #5
Djohns's Avatar
That and you’re not supposed to check it on a completely cold engine. Needs to be warm but not hot.
Soon:built motor
check my log please msspeed3 2010 MS3 - ECU Computer Tuning 8 09-05-2014 10:37 AM
Page generated in 0.26301 seconds with 22 queries
