 Old 05-09-2019, 11:45 AM   #1
shawnmos's Avatar
Posts: 60   (View Stats)
shawnmos is a jewel in the roughshawnmos is a jewel in the roughshawnmos is a jewel in the rough
Question How do I remove these ugly door sill guards?
I'm not sure what exactly they are called but they are the guards in the attached picture. They have discolored and turned black. I would like to remove them but I have tried goof off and it didn't seem like it loosened them at all. I supposed I could also try painting them if that doesn't work. Suggestions?
2008 Mazdaspeed 3
2010 Mazda 5
shawnmos is offline   Reply With Quote
 Old 05-13-2019, 08:46 AM   #2
MSMS3's Avatar
Posts: 2,826   (View Stats)
What you are seeing is most likely black mold. Mold grows in moist areas that stay dark, like a closed car door.
While the usual remedy for mold is bleach and sunlight, bleach can damage the car paint.
Try this instead:
https://itstillruns.com/remove-mold-...t-7528784.html
If you end up using bleach if above does not get the desired result, mask off the painted area around that strip, apply the bleach only to the mold. Scrub it in with a tooth brush or similar soft bristle brush. Let it soak a bit, brush some more until the mold is gone. and then thoroughly wash it off with soap and water. Vinegar also neutralizes bleach, but should be rinsed off as soon as it soaks in. Only takes a few seconds to neutralize the bleach. Thoroughly rinse and then dry with a blow dryer.
 Old 05-13-2019, 10:06 AM   #3
shamie's Avatar
Posts: 952   (View Stats)
Heat it up then peel it off. Then use your favorite adhesive remover to remove the residue.
 Old 05-13-2019, 02:42 PM   #4
shawnmos's Avatar
I waited until it got hot out and scraped them off with a plastic scraper. Took me like an hour but it was worth it. Looks much better now.
2008 Mazdaspeed 3
2010 Mazda 5
The Following User Says Thank You to shawnmos For This Useful Post:
MSMS3 (05-14-2019)
Door bumper guards or not? thecavemankevin Appearance - BLACK 15 08-17-2014 07:32 PM
How to remove front door from our speed3 ??? Atomic41 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 07-07-2013 06:02 PM
How to remove a very small door ding/dent? squale MazdaSpeed 6 - How-To's 32 03-17-2011 09:05 AM
Is it necessary to remove the splash guards when installing CAI? TongMan MazdaSpeed 3/6 - Turbo Induction 3 08-24-2009 10:14 PM
Page generated in 0.24822 seconds with 23 queries
