Like Tree50Likes
 Old 04-19-2012, 02:54 PM   #1
Neutral  :  +2 score
Default HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way)
Hey guys since our cars are developing more and more everyday with great aftermarket support it’s becoming easier to make a reliable, daily driven 400whp Speed. To make this power reliably the two most important things are a solid tune and proper maintenance to your vehicle! I can’t stress this enough guys. To check out you can do on stock internals see this thread.
big turbo stock block thread
Everyone’s results are going to vary due to tunes, dyno’s, hard parts, motor health, weather, and elevation etc.
Now this can be accomplished on just the stock injectors and an upgraded high pressure fuel pump. You will be very close to maxing out anywhere from 390whp-410whp depending on the tune and fuel choice. Please don’t ask if you can use less than 91 octane, the answer is no. Let’s get on to the parts that make this possible! Remember when building a car to this level do it once correctly and you will never have to do it again so don’t skimp on anything! Lol
Hard Parts
• Intake (Big MAF recommended, but not necessary in some cases)
• Big turbo inlet pipe
• Intercooler (Front mount recommended but TMIC will be able to get you there)
• Downpipe ( 3”)
• Catback Exhaust
• Bigger turbo (Choice of turbo varies on everyone’s desires of the drivability of the car)
• Colder spark plugs
• Motor mounts- You are definitely going to need a RMM but the PMM & TMM are something to seriously consider at this power level
• Injector Seals ( These are highly recommended but not necessary. The factory seals will wear over time so it’s better to upgrade before they go bad.)
• Manifold (Recommended but not needed, there are many stock manifold 400whp cars)
• Upgraded boost controller is highly recommended
Fueling- Don’t be this guy
• HPFP/HPFP Internals
Tuning
• Cobb AccessPort or Versa Tune (do yourself a favor and spend a few hundred bucks to have an experienced tuner tune your car)
• The tune is very key to all this power and to do it safely and reliably so make sure your tuner knows what’s going on and preferably has a good history with tuning speeds
Turbo
• To make this clear, there is not a best turbo. ANY GT30R turbo will easily get you 400whp including non-GTX versions. If anything, the GTX turbos seem to shine with higher boost levels than with low to medium boost levels. So if you’re planning on 400whp and that’s it, a GTX30R might be too much turbo.
If you want 400whp now and know that later on, you want to take advantage of future advancements in the platform to get even more power, a GTX30R would be great. There’s no right or wrong here. A GT2871R in theory has the ability to get there but the turbo will be pushing harder than a GT30R.
There are too many other variables to discuss. There are tons of ways to get it, but this is the most practical way to get 400whp.
Once you have done all of this hard work go enjoy your monster of a car. Don’t be afraid to drive it either, enjoy all the hard work you did to get it here.
The Following 141 Users Say Thank You to EdgeAutosport.com For This Useful Post:
06Speed6 (04-20-2012), 08blackms3 (12-10-2012), 09Speed3Z (04-19-2012), 3dpilot (04-28-2012), 86AmishMs3 (04-19-2012), air- (04-25-2012), ak_spray (06-11-2012), anavrinIV (04-20-2012), ArcticSpeed3 (04-19-2012), asall667 (04-20-2012), atvfreek (04-23-2012), Awesomesauce (04-20-2012), AZSPEED3 (04-19-2012), Big_Burd (04-30-2012), Black Metal (06-28-2012), bobbybennett23 (06-11-2012), Broxer (04-20-2012), captain slow (04-19-2012), charlesfist (04-19-2012), Clannad (04-24-2012), codykemmet (04-19-2012), Colin1337 (06-27-2012), Constantin (04-24-2012), Cusumano91 (12-15-2012), daafisch (04-22-2012), Darth_Nuruodo (06-11-2012), Dash08 (06-11-2012), Deldran (04-20-2012), Destro (04-19-2012), Domino81 (04-24-2012), Don06speed6 (04-19-2012), dot584 (04-19-2012), doubleflusher (04-20-2012), dton13 (04-30-2012), Dumyz (04-23-2012), eljefe62 (04-19-2012), Elusivellama (07-27-2012), emag remrofni (04-19-2012), Eric28243 (04-20-2012), ESB Jiu JItsu (07-30-2012), F1RacerX (08-09-2013), fcbrandon (04-19-2012), FightaX (06-11-2012), fishin53 (04-19-2012), forgedzoomzoom (06-11-2012), galens47 (06-28-2012), GunGuru727 (11-10-2012), Hamilton69 (04-19-2012), hartlch (06-27-2012), helmetface (04-19-2012), ImGryssLOL (11-22-2012), Ingle (04-23-2012), IshiKage (08-12-2012), iviagickiwi (07-28-2012), J'sSpeed3 (04-19-2012), JacksonMS30 (04-20-2012), jack_hammer (04-24-2012), JasonMzdSpd3 (04-20-2012), jeopardy98 (09-15-2012), jman46 (06-27-2012), Joellc2434 (04-20-2012), jracer (04-20-2012), jscape83 (07-23-2012), K7addict (06-29-2012), kgb (04-19-2012), KILLER_VIZ (07-02-2012), knarfies (04-20-2012), kobberr (09-18-2012), krazycoble (04-19-2012), kritz (05-05-2012), KusteLokal (04-24-2012), Kyle Undefined (09-17-2012), leon78 (04-20-2012), Lex (04-19-2012), lilred (06-29-2012), ljudgeii (04-19-2012), MaDCoW (04-20-2012), manelscout4life (06-29-2012), Mase (06-11-2012), mayer (04-19-2012), mazdamx3freak (04-20-2012), Mchart (08-05-2012), Micha (04-19-2012), mrmonk7663 (04-24-2012), MS3-a(sore)ASS-rex (04-19-2012), ms3bamf (04-19-2012), MS3G35 (04-19-2012), MS3KO (04-22-2012), Ms3_Miami (04-19-2012), MS6 Sanchez (12-28-2012), Mythyk (06-13-2012), Neverlift (04-23-2012), NJSPEED3 (04-24-2012), NoRegrets (04-19-2012), NoTraction (04-23-2012), Onelovesoccer (05-01-2012), Pointless (04-19-2012), predapio (04-19-2012), RayRay (04-24-2012), Realgib3 (04-20-2012), rfinkle2 (04-19-2012), rghispanic88 (04-19-2012), ricknm (04-19-2012), robertof (04-24-2012), robspeed3 (07-03-2012), sailorjerry12 (11-15-2012), SarcasticOne (04-19-2012), Seatime3 (05-01-2012), Sid3wayS (04-19-2012), silentwolf8 (06-11-2012), SilverDemon (04-19-2012), Silverlock88 (06-12-2012), SIXual Panda (04-24-2012), skinnydvc (04-24-2012), SKiZ0TT (04-20-2012), SLOWHATCH (04-19-2012), snailD (04-19-2012), Snotrocket (06-12-2012), SofaKingAwesome (04-19-2012), SS_27 (04-19-2012), stevehuff (12-22-2012), stogi1knobi (06-29-2012), stp (04-20-2012), SwineFLU (04-20-2012), taf0422 (04-24-2012), tddvrrn (04-19-2012), TexasSpeed3 (04-19-2012), TheRealDefman (04-19-2012), twincitySPEED6 (09-24-2012), TWOptSL0W (04-19-2012), uncorked11 (04-19-2012), UnknownSuperhero (04-19-2012), Vader (04-22-2012), Vinnie (04-23-2012), warlockfan92 (06-29-2012), xdm88 (04-19-2012), xhymer (04-20-2012), xI Leveler Ix (06-28-2012), yurples (02-11-2013), Zimmo (11-26-2012), []V[]addog (05-29-2012)
 Old 04-19-2012, 03:03 PM   #2
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
In before, "I listened to you and I can't get traction YO"
JasonMzdSpd3 likes this.
What a lovable bunch we are!!
The Following 31 Users Say Thank You to predapio For This Useful Post:
aaronc7 (06-11-2012), asall667 (04-20-2012), AZSPEED3 (04-19-2012), Broxer (04-20-2012), charlesfist (04-19-2012), Dash08 (06-11-2012), doubleflusher (04-20-2012), EdgeAutosport.com (04-19-2012), emag remrofni (04-19-2012), Eric28243 (04-20-2012), GunGuru727 (07-31-2012), iviagickiwi (07-25-2012), JacksonMS30 (04-20-2012), JasonMzdSpd3 (04-20-2012), KILLER_VIZ (06-11-2012), KusteLokal (04-24-2012), Mortose (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), Ms3_Miami (04-19-2012), nycMS3 (06-11-2012), Pointless (04-19-2012), rghispanic88 (04-19-2012), robspeed3 (04-20-2012), SilverDemon (04-19-2012), SKiZ0TT (04-20-2012), SLOWHATCH (04-19-2012), SofaKingAwesome (04-19-2012), taf0422 (04-24-2012), TexasSpeed3 (04-19-2012), TWOptSL0W (04-19-2012), uncorked11 (04-19-2012)
 Old 04-19-2012, 03:20 PM   #3
The Following 39 Users Say Thank You to EdgeAutosport.com For This Useful Post:
ak_spray (06-11-2012), ArcticSpeed3 (04-19-2012), asall667 (04-20-2012), atvfreek (04-23-2012), AZSPEED3 (04-19-2012), breakfstincluded (07-28-2012), Broxer (04-20-2012), charlesfist (04-19-2012), daafisch (04-22-2012), Dash08 (06-11-2012), doubleflusher (04-20-2012), duappleganger (04-20-2012), emag remrofni (04-19-2012), Eric28243 (04-20-2012), Hamilton69 (04-19-2012), iviagickiwi (07-25-2012), J'sSpeed3 (04-19-2012), JacksonMS30 (04-20-2012), JasonMzdSpd3 (04-20-2012), jracer (04-20-2012), K7addict (06-29-2012), KusteLokal (04-24-2012), Mase (06-11-2012), Ms3_Miami (04-19-2012), NoTraction (04-23-2012), nycMS3 (06-11-2012), p057 (06-29-2012), Pendarus (04-19-2012), Pointless (04-19-2012), predapio (04-19-2012), rghispanic88 (04-19-2012), SilverDemon (04-19-2012), SKiZ0TT (04-20-2012), taf0422 (04-24-2012), tddvrrn (04-19-2012), TexasSpeed3 (04-19-2012), TWOptSL0W (04-19-2012), uncorked11 (04-19-2012), xI Leveler Ix (06-28-2012)
 Old 04-19-2012, 03:21 PM   #4
Noodlesincup's Avatar
Posts: 298   (View Stats)
Noodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the worldNoodlesincup is the leader of the world
Groaned at 37 Times in 9 Posts
Awesome info here subbed for future reference
2012 CWP Mazdaspeed3 Current Mods: Cobb Turbo Back|Cobb Sri/Tip|Cobb XLE|Cobb Ap|Jbr Heavy Shit Knob|AutoTech Internals|JBR Short Shifter Plate/Brushings|Corksport Tmic|
Noodlesincup is offline   Reply With Quote
The Following 3 Users Say Thank You to Noodlesincup For This Useful Post:
EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), skiptowncat (04-25-2012)
 Old 04-19-2012, 03:23 PM   #5
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
I know a better way....just sayin'
NATOR PA
The Following 7 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
8.5MS3 (04-19-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), predapio (04-19-2012), SilverDemon (04-19-2012), SIXual Panda (04-24-2012), Snotrocket (06-12-2012)
 Old 04-19-2012, 03:24 PM   #6
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
@eric@edgeautosport
you told me these were necessary as well when we went to get food the other nite
The Following 41 Users Say Thank You to 8.5MS3 For This Useful Post:
86AmishMs3 (04-19-2012), air- (04-25-2012), atvfreek (04-23-2012), AZRushki (05-13-2012), AZSPEED3 (04-19-2012), balint (01-25-2016), BigRedSpecial (05-02-2012), BrianB6 (04-19-2012), Broxer (04-20-2012), charlesfist (04-19-2012), ChimmyChong (08-15-2012), daafisch (04-22-2012), Darksun280 (04-24-2012), Dash08 (06-11-2012), doubleflusher (04-20-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), Illusion (05-02-2012), JacksonMS30 (04-20-2012), JasonMzdSpd3 (04-20-2012), kgb (04-24-2012), Mase (06-11-2012), Monotonous ONE (04-19-2012), Mortose (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012), Ms3_Miami (04-19-2012), myt_tuf1 (06-29-2012), NoRegrets (04-19-2012), NRSpeed (06-11-2012), Onelovesoccer (05-01-2012), Pendarus (04-19-2012), predapio (04-19-2012), rghispanic88 (04-19-2012), SilverDemon (04-19-2012), Sines (07-11-2012), stogi1knobi (01-04-2013), tddvrrn (04-19-2012), theschrum (04-24-2012), TriO (04-20-2012), TWOptSL0W (04-19-2012), vdgmcool (04-23-2012)
 Old 04-19-2012, 03:25 PM   #7
This is 400 all day everyday all you have to do is press the gas not rely on a button
The Following 9 Users Say Thank You to EdgeAutosport.com For This Useful Post:
AZSPEED3 (04-19-2012), Broxer (04-20-2012), Clannad (04-24-2012), doubleflusher (04-20-2012), Eric28243 (04-20-2012), knarfies (04-20-2012), MS3-a(sore)ASS-rex (04-19-2012), SilverDemon (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 03:27 PM   #8
Groans: 224
It'll be set to flip a switch and mash the gas pedal soon enough, come at me bro!
NATOR PA
AZSPEED3 (04-19-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), JasonMzdSpd3 (04-20-2012), knarfies (04-20-2012), SilverDemon (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 03:27 PM   #9
@8.5MS3
Im already on it
8.5MS3 (04-19-2012), Eric28243 (04-20-2012), JasonMzdSpd3 (04-20-2012), SilverDemon (04-19-2012)
 Old 04-19-2012, 03:28 PM   #10
8.5MS3's Avatar
Groans: 326
in before gopro vid of tom with leaky NOS tank laughing his ass off for no reason in traffic
Andjo likes this.
The Following 32 Users Say Thank You to 8.5MS3 For This Useful Post:
06Speed6 (04-20-2012), 09Speed3Z (04-19-2012), asall667 (04-20-2012), ASHMS3 (04-19-2012), atvfreek (04-23-2012), Boosted Beluga (04-24-2012), Broxer (04-20-2012), Ckmazdaspeed3 (04-19-2012), daafisch (04-22-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), JacksonMS30 (04-20-2012), JasonMzdSpd3 (04-20-2012), jracer (04-20-2012), kgb (04-24-2012), KusteLokal (04-24-2012), MS3-a(sore)ASS-rex (04-19-2012), Ms3_Miami (04-19-2012), NJSPEED3 (04-24-2012), NoRegrets (04-19-2012), nycMS3 (06-11-2012), Pointless (04-19-2012), predapio (04-19-2012), SilverDemon (04-19-2012), SLOWHATCH (04-19-2012), snailD (04-19-2012), SofaKingAwesome (06-11-2012), taf0422 (04-24-2012), TexasSpeed3 (04-19-2012), uncorked11 (04-19-2012), Vinnie (04-23-2012), xfeejayx (04-24-2012)
 Old 04-19-2012, 03:29 PM   #11
Mortose's Avatar
Posts: 2,441   (View Stats)
Groans: 39
Subbed so i know where to come to find evidence that my need for tires every six months is erics fault.
99 miata: sold
The Following 3 Users Say Thank You to Mortose For This Useful Post:
 Old 04-19-2012, 03:30 PM   #12
Groans: 224
LOL
Thank god I fixed that issue yesterday
NATOR PA
The Following 4 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
8.5MS3 (04-19-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), SilverDemon (04-19-2012)
 Old 04-19-2012, 04:18 PM   #13
LOL
how did you fix it? was it just loose?
 Old 04-19-2012, 04:19 PM   #14
Groans: 224
Turned out it wasn't the feed line I thought it was, but the adapter that goes between the bottle and line where the gauge is mounted. I just gave it a quick turn and it sealed right up!
NATOR PA
The Following 3 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
EdgeAutosport.com (04-19-2012), SilverDemon (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 04:28 PM   #15
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I just want to let you know Tom, THAT YOU RUINED ME WITH YOUR STUNT YOU PULLED ON THE DYNO WITH THE GIGGLE GAS!!!!!! You bastard!!
I just got off the phone with Jegs talking to a tech about the best way to run an enrichment fueling system for the N2O set up I am working on
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 10 Users Say Thank You to SilverDemon For This Useful Post:
atvfreek (04-23-2012), Bucker (04-19-2012), EdgeAutosport.com (04-19-2012), JacksonMS30 (04-20-2012), MS3-a(sore)ASS-rex (04-19-2012), NJSPEED3 (04-24-2012), predapio (04-19-2012), TexasSpeed3 (04-19-2012), The Panda (04-20-2012), TWOptSL0W (04-19-2012)
 Old 04-19-2012, 04:35 PM   #16
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Must be a slow day at Edge.
Holy shit Eric..
EdgeAutosport.com likes this.
______________________
Built By NATOR
Tons of Ricer Mods
The Following 4 Users Say Thank You to 09Speed3Z For This Useful Post:
Constantin (04-24-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), SilverDemon (04-19-2012)
 Old 04-19-2012, 04:38 PM   #17
Groans: 224
My work here is done.
lol
NATOR PA
JacksonMS30 (04-20-2012), NJSPEED3 (04-24-2012), SilverDemon (04-19-2012)
 Old 04-19-2012, 04:58 PM   #18
Holy shit Eric..
The Following 14 Users Say Thank You to EdgeAutosport.com For This Useful Post:
09Speed3Z (04-20-2012), air- (04-25-2012), emag remrofni (04-19-2012), Eric28243 (04-20-2012), JacksonMS30 (04-20-2012), kgb (04-24-2012), maisonvi (04-20-2012), MS3-a(sore)ASS-rex (04-19-2012), NJSPEED3 (04-24-2012), rghispanic88 (04-19-2012), SIXual Panda (04-24-2012), snailD (04-19-2012), The Panda (04-20-2012), thehead (07-28-2012)
 Old 04-19-2012, 05:33 PM   #19
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Tom, we need to spread the N2O love. I have guys PMing and emailing left and right asking to get tuned on it now. Seriously.
403whp/451ft/lb Dry Shot
The Following 5 Users Say Thank You to Bucker For This Useful Post:
EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), m249saw (05-27-2012), MS3-a(sore)ASS-rex (04-19-2012), SilverDemon (04-19-2012)
 Old 04-19-2012, 05:35 PM   #20
Groans: 224
Or should we get really selfish and be the only 2 badasses on here?! LOL
Bucker likes this.
NATOR PA
The Following 6 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
atvfreek (04-23-2012), Bucker (04-19-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), JacksonMS30 (04-20-2012), SilverDemon (04-19-2012)
 Old 04-19-2012, 05:38 PM   #21
Not for long bitches... I have some ideas up my sleeve..
Eric, sorry for jacking your thread...the original post is very informational
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 2 Users Say Thank You to SilverDemon For This Useful Post:
EdgeAutosport.com (04-19-2012), MS3-a(sore)ASS-rex (04-19-2012)
 Old 04-19-2012, 05:39 PM   #22
lol no worries guys im also on the n20 Train.
CHOOOOOOOO-CHOOOOOOOO
The Following 8 Users Say Thank You to EdgeAutosport.com For This Useful Post:
atvfreek (04-23-2012), Broxer (04-20-2012), Bucker (04-19-2012), JacksonMS30 (04-20-2012), JasonMzdSpd3 (04-20-2012), MS3-a(sore)ASS-rex (04-19-2012), SilverDemon (04-19-2012), TexasSpeed3 (04-19-2012)
 Old 04-19-2012, 06:05 PM   #23
JP@edgeautosport.com's Avatar
Posts: 887   (View Stats)
We have NOOOOOOOOOOOOOOS!
Bucker and JasonMzdSpd3 like this.
The Following 5 Users Say Thank You to JP@edgeautosport.com For This Useful Post:
 Old 04-19-2012, 06:21 PM   #24
nattun's Avatar
Posts: 260   (View Stats)
nattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond repute
Groaned at 3 Times in 1 Post
Haha jk, nice write up
2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled
2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820
nattun is offline   Reply With Quote
The Following User Says Thank You to nattun For This Useful Post:
 Old 04-19-2012, 06:23 PM   #25
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
but who wants to be practical not me lol
Hard Parts
• Downpipe ( 3”)
• Catback Exhaust
Tuning
Turbo
dturboman is offline   Reply With Quote
The Following 2 Users Say Thank You to dturboman For This Useful Post:
atvfreek (04-23-2012), EdgeAutosport.com (04-19-2012)
 Old 04-19-2012, 06:23 PM   #26
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
That's like saying if you only want to have sex once a day dating a porn star is too much for you.
You can never have too much turbo.
The Following 6 Users Say Thank You to captain slow For This Useful Post:
atvfreek (04-23-2012), EdgeAutosport.com (04-19-2012), Eric28243 (04-20-2012), MS3-a(sore)ASS-rex (04-19-2012), predapio (04-19-2012), Rich990 (11-24-2012)
 Old 04-19-2012, 09:24 PM   #27
I love the minimum 10 characters stuff
 Old 04-20-2012, 11:32 AM   #28
bmylez's Avatar
Posts: 3,197   (View Stats)
Groans: 31
One thing I noticed you didn't mention was a MAP sensor. So you're saying that, in general, you can hit 400whp with 21.5, maybe 22psi (gt3071/76)?
Also, no mention of meth...has anyone made 400 on 93 oct with just those simple bolt-ons? If someone has, then my car really does suck the biggest donkey nuts on the planet, because I'm getting some KR up top at 20psi and 8.5:1 compression on a BNR stage 3 spraying 25% meth.
Just don't want to get everyone's hopes up.
2007 CTS-V - Trying to sell
The Following 4 Users Say Thank You to bmylez For This Useful Post:
atvfreek (04-23-2012), EdgeAutosport.com (04-20-2012), Eric28243 (04-20-2012), rfinkle2 (04-20-2012)
 Old 04-20-2012, 11:36 AM   #29
Ive personally done it without meth with the mods listed above. Stock map sensor is good for 22.95 here at sea level. At 22ish psi you should be in the ball park and as I mentioned results will vary.
 Old 04-20-2012, 11:50 AM   #30
doubleflusher's Avatar
Posts: 20,650   (View Stats)
Groans: 1,443
I'm here for the pictures.
Beanfab / Tuned by Nishan
The Following 4 Users Say Thank You to doubleflusher For This Useful Post:
Cataphract_40 (04-25-2012), EdgeAutosport.com (04-20-2012), Eric28243 (04-20-2012), JacksonMS30 (04-20-2012)
 Old 04-20-2012, 11:50 AM   #31
supertubesocks's Avatar
Posts: 404   (View Stats)
supertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the worldsupertubesocks is the leader of the world
Something is off in your tune then.
supertubesocks is offline   Reply With Quote
 Old 04-20-2012, 12:55 PM   #32
also the bnr stage 3 is working a lot harder at 20psi vs a gtx3071 @20psi.
 Old 04-20-2012, 01:04 PM   #33
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
You forgot this
Seatime3 likes this.
Damond Built Speed 6
The Following 4 Users Say Thank You to Deldran For This Useful Post:
EdgeAutosport.com (04-20-2012), JacksonMS30 (04-20-2012), thehead (07-28-2012), xantho99 (08-08-2013)
 Old 04-20-2012, 01:16 PM   #34
On a GT30 turbo you'll be in the 400whp neighborhood around the 22-24psi range depending on your setup. This is coincidentally also the limit of the stock fuel system.
You can run more boost and get more torque down low but in terms of hp that's where things are at.
atvfreek (04-23-2012), Broxer (04-20-2012), Bucker (04-20-2012), EdgeAutosport.com (04-20-2012), NJSPEED3 (04-24-2012), rfinkle2 (04-20-2012)
 Old 04-20-2012, 01:25 PM   #35
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
eric, I love you. I've been aiming at 400 with a 3071 on pump gas and basically all the mods you listed. good to know I've had realistic expectations and can hit my goals.
Blue Pu.
 Old 04-20-2012, 01:27 PM   #36
Groans: 224
You forgot this
Man that's a real knee slapper
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
EdgeAutosport.com (04-20-2012), SilverDemon (04-20-2012)
 Old 04-20-2012, 01:28 PM   #37
I should mention, a 3 Bar MAP sensor and/or a Guardian Angel is a good idea if you don't want to settle for 380hp and 21 - 21.5psi. If you set your boost cut at 22.5psi on the stock sensor and shit hits the fan, it won't save your butt - it is too close to its limit.
 Old 04-20-2012, 01:29 PM   #38
The Panda's Avatar
Posts: 1,229   (View Stats)
The Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the worldThe Panda is the leader of the world
Groaned at 8 Times in 7 Posts
When I get NAWS i want tags that say 2SOONJR....winning.
uberspeed3 likes this.
2011 BLACK MS3
ZZB on GT3076 Rebuild in progress
The Panda is offline   Reply With Quote
The Following 3 Users Say Thank You to The Panda For This Useful Post:
anavrinIV (04-20-2012), Broxer (04-20-2012), EdgeAutosport.com (04-20-2012)
 Old 04-20-2012, 01:33 PM   #39
knarfies's Avatar
Posts: 2,568   (View Stats)
knarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the worldknarfies is the leader of the world
at the time i had 2.5bar running 22 psi with stock mani' and stock maf.
made 408hp 409tq
if your going to complain about traction then i suggest you not get a bigger turbo. im not saying, im just sayin.
**********************Riding Rainbows Since 1986.**************************
knarfies is offline   Reply With Quote
The Following 3 Users Say Thank You to knarfies For This Useful Post:
EdgeAutosport.com (04-20-2012), MS3-a(sore)ASS-rex (04-20-2012), Rich990 (11-24-2012)
 Old 04-20-2012, 01:40 PM   #40
Deldran's Avatar
Groans: 118
i thought u had to have that to use NOS, thats what fast and furious taught me
EdgeAutosport.com (04-24-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/how-get-400whp-your-speed-3-practical-111319/
How can I make my speed3 close to 400whp? - Yahoo! Answers This thread Refback 07-29-2013 04:25 AM
My 400whp journey wcf I Love Brownies MazdaSpeed 3/6 - Dyno Sheets/Discussions 79 12-15-2011 12:12 PM
Realgib3 - GTX3076 - 400whp Realgib3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 10-13-2011 02:57 PM
Mommies on Minivans: Practical, but where's the style? Haltech Automotive News 0 01-21-2011 04:20 PM
The 400whp Club gsrtype1 MazdaSpeed 3/6 - Dyno Sheets/Discussions 16 09-26-2008 03:19 PM
Page generated in 0.66347 seconds with 41 queries
