![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
(Thread Starter) | Not Ranked : 0 score NOTE: This does NOT shorten your throw by much. You will need a Short Shifter Plate for that. But, if you are fond of not spending a ridiculous amount on a shifter, not feeling like a truck driver, are somewhat happy with your stock shifter and just want it a bit lower, this thread is for you. Disclaimer: I will not be held responsible for messed up shifters. Do this at your own risk. I got fed up with “overpriced” short shifters and “shotty” knock-offs (Ralco RZ) and chose to jump on the grenade. The thread pattern of the stock thread pattern is 10mm x 1.25. Step 1: Ace Hardware Trip!! Step 2: Next, remove your shift knob and boot. **This next step is optional. It really depends if you want to go a little bit beyond that point.** ***Also, you will want to protect the ball joint, by covering it, to ensure that no metal shavings fall into the area.*** Step 3: Using vise grips, clamp down on the spot welded washer, to the side of one of the two weld locations. This can be determined by looking underneath. Mine was the from and back. Should be the same with all. Step 4: Start to bend upward and downward until you hear a little snap. That would be the weld breaking. Do the same with the other side and remove the washer. Step 5: Place 10mm x 1.25 die on the threading and screw it down until it stops. Of course, be careful not to cross-thread. It should just screw on smoothly. Step 6: With a wrench (I used a large crescent wrench for leverage) start cranking it down to start cutting new threads. Be sure to go slow; a little at a time, backing it off a bit, from time to time, to break off the metal shavings. Step 7: Determine how much you want to shorten, within reason, and cut the excess threading off. I used damp paper towels to catch all the metal saw dust. *** If you choose not to unintall the shifter, as I did, TAKE YOUR TIME. You DO NOT want to mess up the threading or your interior.*** Here is how much I chose to remove. Step 8: Replace the console/shift boot and shift knob. BEFORE: AFTER: This pic does not do it justice. The angle it off. It sits a bit lower than it looks.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-09-2014 at 06:25 PM. |
| The Following 13 Users Say Thank You to Atticaz For This Useful Post: | 3starmagnum (02-09-2014), alien_sporez (03-19-2014), Fjager (02-24-2014), Hush (02-09-2014), ItsNox (02-09-2014), jm211 (02-09-2014), Johnasaurus (02-09-2014), neotide87 (04-25-2014), pwdunmore (02-09-2014), RdotQelo (02-10-2014), Sid3wayS (02-10-2014), thricestrat (02-10-2014), thrisnospork (02-09-2014) |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score All this did was shorting the shift knob but it really doesnt make it a short shifter
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
| The Following User Says Thank You to blackms3_71 For This Useful Post: | daafisch (02-10-2014) |
Also, I named this thread "shorten stock shifter". Not make stock shifter short throw. Plus, the way our shifters are designed, there is not way to lengthen the pivot point to make it a true short shifter. Therefore, aftermarket shifters for our cars, themselves, are not really short shifters.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-09-2014 at 04:58 PM. | |
(Thread Starter) | Not Ranked : 0 score All in all, I am happy with the fact that I get to keep my stock shifter and not feel like a truck driver. I have a SSP. That is my short shifter.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD |
| The Following User Says Thank You to Atticaz For This Useful Post: | MazdaBoy2.3 (02-09-2014) |
| Not Ranked : 0 score Well very nice glad it worked out well!
| v8 convert ![]() Join Date: Sep 2009 Location: (actually in) Tampa, FL
Rep Power: 1203 ![]() Thanks: 2,634
Groans: 220
| Not Ranked : 0 score go drive the previous gen GTI. jesus christ talk about ultra high stick shifts :/ I've been considering doing this for a while, looks a lot better.
__________________ |
(Thread Starter) | Not Ranked : 0 score Yeah. Those are pretty tall. My previous car, Protege5 was tall as shizzle too.
![]() Join Date: Oct 2013 Location: Vermont
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 139
| Not Ranked : 0 score Nice job! Might have to look into this as I'm not feeling spending a ton of money for an aftermarket shifter. |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
The svt focus had a pretty high tractor shifter in there. Sent from my iPhone using Tapatalk
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals | |
| Not Ranked : 0 score Did you take the shifter down to the washer? Looks good. Might notice the shortened length with a different knob. Sent from my iPhone using Tapatalk
I don't feel like a truck driver and I still get enough leverage to have a smooth shift. I also have my SSP almost maxed out to shorten the throw. Hence the title "Shorten Stock Shifter".
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 02-09-2014 at 05:55 PM. Reason: MSF Database - Automerged Doublepost | |
![]() Join Date: Aug 2012 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 166
| Not Ranked : 0 score i was agreeing with your earlier post.
__________________ 2012 black mica. Totaled 10/31/14. |
(Thread Starter) | Not Ranked : 0 score I know. I just said that so that others don't think this will actually shorten the throw a significant amount. I added a note in the beginning. I should have done that in the first place.
![]() Join Date: May 2012 Location: Ontario
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 89
Good idea though! | |
| Not Ranked : 0 score I like it, I use a short shifter plate also. this will just lower the profile of the shifter in the cab of the car. this was never meant to make it a short shifter.
![]() Join Date: Oct 2013 Location: Burbank, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 216
| Not Ranked : 0 score This is rad! I'm kinda nervous to do something permanent like that to my whip, but it looks like a good option. Asthetically, i like it a lot. I had a short shift kit in my old '04 v6 accord. Fucking loved it.
__________________ Car - 06' Mazdaspeed 6 GT Black Mica/Panda Interior Work - Content Creation (www.goodedreams.com) Dream - Liver "Life's a garden; dig it." -Joe Dirt |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score For cleaner threads use a die handle and cutting oil, this will keep the die flat and the oil will decrease the friction and clean up the cuts. Also if you put a 10x1.25 nut below the point where you're cutting you can unthread it after you cut the shifter to length and straighten out any threads that were bent or moved when cutting. Personally I don't like how low the stock shift knob is, I put an extender on mine and love it.
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
| The Following 4 Users Say Thank You to anavrinIV For This Useful Post: |
I managed to cut so straight that the thread stayed perfect. Great idea on the nut to do that. I will remember it for any other threading projects.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD | |
![]() | | #19 | ![]() |
![]() Join Date: Sep 2013 Location: Harker Heights Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 73
Groaned at 4 Times in 1 Post
| Not Ranked : 0 score how well would the shift boot stay up?
__________________ 2011 CBM Speed 3 // Turbosmart Dual port BOV // KMD HPFP internals // CNT 3" Catless downpipe // CorkSport StageII Intake // Cobb AP V2 - FREEKTUNE // [SIGPIC][/SIGPIC] |
![]() | | #20 | ![]() |
(Thread Starter) | Not Ranked : 0 score It didn't stay up too well. But I am going to dremel two slots and add a retaining ring clip, like the TWM and Ralco shifter use. For now I am using tape on the underside to hold it up. Works good for now and is out of sight. But Summertime in AZ will melt that crap. The retaining ring clip is the way to go.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD Last edited by Atticaz; 01-03-2016 at 01:03 PM. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/how-shorten-stock-shifter-164264/ | ||||
| Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 06-05-2014 05:42 PM | |
