 Old 07-31-2013, 05:52 PM   #1
AKmac11's Avatar
Posts: 277   (View Stats)
AKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the worldAKmac11 is the leader of the world
Default Initial log...how's it look?
Alright guys, this is my first 4th gear WOT log after completing a CL MAF cal. Mods are SRI/TIP/TP with internals and other goodies on the way. This is a stage 1 aeros v2 map. Looks like the map targets an 11.6:1 AFR. Ambient temps were ridiculous today, a little over 100 F. Any thing that sticks out as abnormal? Thanks for looking. Sorry for noobness.
AKmac11 is offline   Reply With Quote
 Old 07-31-2013, 06:22 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Looks normal, just start logging a bit sooner in the pull, get settled in 4th at 2500, start logging, then go WOT till redline. You should log LTFT also.
 Old 07-31-2013, 06:24 PM   #3
AKmac11's Avatar
Just so you can see when the car transitions in to open loop?
Initial E40 Results... Redline143 MazdaSpeed 3/6 - E85 Fueling 16 01-10-2013 09:44 PM
no boost on initial startup. wowitswil 2010 MS3 - Turbo Induction 23 01-16-2012 02:33 PM
PAE OCC Install initial thoughts vatordoc 2010 MS3 - Engine, Transmission & Driveline 3 04-13-2011 11:19 PM
Page generated in 0.23674 seconds with 22 queries
