 Old 10-13-2012, 07:16 PM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Default Installed SURE Full 3 Aeros with 3" MAF (k04)
Holy shit, that Aeros setup couldn't get bigger in any dimension and still fit with the battery there. It's like a gelatinous mass that contorts to fill the volume between the intake filter in front of the battery and the turbo. I had to trim my battery tray a bit and muscle the turbo intake hose into position. It took me a while to get a solid square grip on the turbo inlet with a hose clamp. I had to trim the battery hold down also and drill an anchor for the MAF housing.
By comparison, the 2.5" COBB TIH is much easier to install. This one takes a little more elbow grease. Previous to this install, I had a superb calibration on my MAF cal and was hitting my WOT AFR targets with the AEM + COBB, so I just upscaled my existing maf cal 19% (76.2mm^2)/(69.85^2) and went for a quick run.
I think my hunch was right; I think I found my car's weakest link in the AEM CAI + COBB TIH combo in relation to all of the other mods I have done. In a very short run, I saw my car flow ~250g/s at 5000rpms with more to give. Previously my car flowed 230g/s at 5000rpms. I am expecting to flow 270g/s @ 6,000, up from 250g/s with the AEM + TIH. WOT AFRs were ok from scaling up the MAF cal. The acceleration was near violent in the way the car responded. It really surprised me. My car usually pulls very smooth.
Of course I am going to quantify this with runs compared to my baseline. I will hopefully sneak in a few runs tonight to share. I am expecting some pretty decent gains with this intake on my k04.
BigjohnB20 (10-14-2012), Code Monkey (10-13-2012), Dr. Speed (12-17-2012), Easter Bunny (10-14-2012), Pointless (10-15-2012)
 Old 10-13-2012, 07:24 PM   #2
2.3speed06's Avatar
Posts: 811   (View Stats)
2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world
I've been thinking about getting this intake. But I think I'm flowing just fine with my C-PE set up at 280 :-)
2006 Black Cherry Mica Mazdaspeed 6 GT
Cobb AP 50/50 FREEKTune/Cobb 3port EBCS/C-PE Nano Intake/C-PE TIP/C-PE TMIC/HKS SQ3 BOV/Auto Tech HPFP/M2 DP/Custom CB/Denso ITV 22's/JBR RMM/Sure SSP/Sure Shifter Bushings/Custom EGR Kit/TB&IM TIG/MD Stage2 OCC/Koni Yellow S&S/H&R LS/Stoptech Blanks/EBC Red/Techna-Fit SS Brake Lines/
2.3speed06 is offline   Reply With Quote
 Old 10-13-2012, 07:26 PM   #3
xb2ms3's Avatar
Posts: 636   (View Stats)
xb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the worldxb2ms3 is the leader of the world
250g/s @ 5k doesn't seem like a big gain, I was getting about the same with 2.5" sri/tip. Ambient temp?
Can you post logs before and after 3" ?
2011 Black Mica MS3
NJSPEED3 Ported IM + other shit
NJ NATOR NY
316.52 hp / 352.12 tq 93 oct K04@ Nator DC Dyno Day 11.10.12
xb2ms3 is offline   Reply With Quote
 Old 10-13-2012, 07:33 PM   #4
Ya, I will definitely post some logs. My k04 has always been flow challenged. It's a big deal for my car.
xb2ms3 (10-13-2012)
 Old 10-13-2012, 07:42 PM   #5
ckMS3's Avatar
Posts: 1,112   (View Stats)
G/s isn't a great way of showing power my stock ko4 was flowing 330g/s during the winter but only making ~315whp. If your g/s increased that should tell you that you made some gains.
348tq/367whp -21.5 psi
 Old 10-13-2012, 07:56 PM   #6
Ya, I am not saying I have more power because of flow alone and I understand flow is relative. I am saying based on a solid baseline and a lot of empirical data that my car appears to be flowing about 20% more air through the maf compared to before. It is likely that this increase in airflow will contribute to more power.
MINI H1 6.0 - CAR LED TAILS
 Old 10-13-2012, 08:03 PM   #7
I am just prepping for my bnr which is next on the list.
 Old 10-13-2012, 08:05 PM   #8
First of all to make back to back comparisons in an MS6 you have to cal the MAF table so that your AFRs match with what they were previously.
Secondly, throw an AEM dryflow filter on there for maximum gains.
An increase in g/s (when properly calibrated MAF) when the WGDC is maxed out at the same temperatures shows an increase in flow.
 Old 10-13-2012, 09:18 PM   #9
LilGator's Avatar
Posts: 136   (View Stats)
LilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond repute
Groaned at 6 Times in 3 Posts
This guy was indeed a bitch to squeeze in there.
Considering this is a $400 SRI/TIP, why didn't Sure include a high flow filter?
This guy should work, yeah?
AEM 21-203DK 3AEM 21-203DK 3" Inlet x 5" Element Dryflow Air Filter
Only issue I see is that AEM says flange inside diameter is 3 in., and Sure says the MAF internal diameter is 3.00 in., but I assume you've got some flex to stretch it over.
2007 Speed6 GT - LPM
RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP
SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV
MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports
E85 Stratified
LilGator is offline   Reply With Quote
 Old 10-13-2012, 09:39 PM   #10
The AEM filter should be this: 21-204DK for the 3" MAF housing.
FistPump20fo7 (01-22-2013), Pointless (12-17-2012)
 Old 10-14-2012, 08:43 AM   #11
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
A better comparison would be from switch from a COBB SRI/TIP to this. I flow over 300g/s on my CPE SRI on the K04, so I am sure you have room to grow on your tune
mczimer is offline   Reply With Quote
 Old 10-14-2012, 08:46 PM   #12
Honestly, Lex wrestled with my car on an e-tune for about 5 weeks... He noted early on that my car doesn't flow as well as others he has tuned in my area given similar conditions and fuel.
When he tells me my car is flowing as well as it can, my car is flowing as well as it can. My tune is about as dialed as it can get given my mods.
 Old 10-14-2012, 08:57 PM   #13
JDW1's Avatar
Posts: 486   (View Stats)
JDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the worldJDW1 is the leader of the world
I want one of these. How did you come up with the 19% increase for the cal?
07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas AlphaTuned. Parting out.
11 Mustang GT current.
JDW1 is offline   Reply With Quote
 Old 10-14-2012, 09:26 PM   #14
I came up with the 19% scaling factor from ms3blackmica's post:
MAF Calibration Tutorial
It was a great ballpark to start. My LTFTs are a little off and my WOT MAF cal needs a minor adjustment, but within 10% across the board.
JDW1 (10-14-2012)
 Old 10-14-2012, 09:33 PM   #15
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Do you have any logs to show yet
2012 MS3
Stratified 91
 Old 10-14-2012, 09:46 PM   #16
Karmat's Avatar
Posts: 1,179   (View Stats)
I'm really interested in the gains of a 3in MAF. I am currently sitting on a Cobb Intake without a TIP thinking this may be the bottleneck at this point.
What are your other mods?
2002 Corvette Z06 (Black)
 Old 10-14-2012, 10:11 PM   #17
I have the CX racing fmic, internals, race pipe, 3" catback, AP, Stratified tune. I spent today getting my maf dialed in. I should have some good logs tomorrow.
Based on some prelims, this setup is flowing better than my aem cai + COBB tih. I just can't quantify how much better until I get wot maf Cal done.
 Old 10-15-2012, 01:57 AM   #18
mmmkay. Here are prelims...
It was stupid hot here in SoCal again (93F in October, really?), so I had to run against an older baseline (same tune) where I ran at 93F. In the baseline run, I had an AEM CAI, all other mods were otherwise the same between the runs. In the AEROS run, I had the 3" AEROS system + MAF cal for Aeros system.
Here are two graphs; in one, you can see airflow g/s v. WGDC (%). In the other, you can see BATs/IATs v/airflow. The AEROS setup does flow more air than the AEM CAI across the board.
This translates in what appears to be a decent power gain for me. More importantly, it restored some of my car's performance even when running in higher temps. Log files are attached.
Easter Bunny (10-18-2012), Lex (10-15-2012), Pointless (10-15-2012)
 Old 10-15-2012, 02:06 AM   #19
Stand by for the 72F comparison where I stack my AEM CAI + Cobb TIH baseline against the 3" AEROS system. As soon as I can get a good comparison run, I will post results.
Based on what I know, I am expecting good gains over the AEM CAI/COBB TIH combo also. My car typically picks up about 10% more hp with a 20 degree outside temp drop. If I apply that to this graph, I should be seeing ~285HP which is a nice pickup from the AEM/COBB combo.
 Old 10-15-2012, 02:19 AM   #20
One more thing regarding CAI v. SRI now that I have run both on the same car. I learned a few things. When cruising on the highway, my IATs are quite a bit higher with the SURE SRI than the AEM CAI setup. That's about where the advantages of the CAI end.
Once I start boosting or end up in stop and go traffic, the temps pretty much fall in line. I also learned that the IAT on the SRI is a pretty good representation of the engine compartment's ambient temp, which coincidentally is very close to the BATs. This taught me two things:
1. I was considering running one of those 'intercooler' pipes to replace one of the hot side pipes on my FMIC. However, after learning that the IATs and BATs kind of equalize in stop and go or when boosting, I don't see any value in doing so. The pipe can't dissipate any more heat of it is thermally equalized with the engine compartment ambient temperature.
2. Lower IATs don't have a proportional impact on BATs. It isn't a directly proportional, rather logarithmic. In other words, if you lower your IATs with a CAI by 10 degrees, it doesn't equal 10 degree cooler BATs, even when cruising. My BATs were pretty much the same between the two.
This is all probably common knowledge, but a reaffirmation for me. Also, I much prefer the sound of the SRI to the CAI. I won't miss the vacuum sucking sound of my CAI at all.
 Old 10-15-2012, 09:40 AM   #21
mczimer's Avatar
I am really curious if there is any real gain from swapping a SRI setup to this. CAI's have long been shown to flow less, so that is obviously going to show some nice gains for you.
Since most people run SRI's though, I think that would be a good comparison for us looking to squeeze a few more g/s out of a setup
 Old 10-15-2012, 11:12 AM   #22
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
i am going big maf as well. hopefully once everything is dialed in i will be able to chime in here. i really want to see the difference between my CS TIP which is aluminum vs one of the silicone ones for BATs. the underhood temps in the speed6 are crazy so i'm convinced that doesnt help my bats at all. i have a fmic too so my bat arent that bad but it frustrates me seeing high bats.... yeah im BAT crazy...
see what i did there?
oh and for reference, my k04 maxes flow at 290g/s right now.
 Old 10-15-2012, 11:38 AM   #23
There's another ~7 g/s to be gained with the AEM filter in the top end. Well worth the ~$40.
dale_gribble (10-15-2012), Easter Bunny (10-18-2012)
 Old 10-15-2012, 11:44 AM   #24
And after that it's time to regain some of your intercooler's efficiency through WMI while increasing knock resistance at the same time.
dale_gribble (10-15-2012), Pointless (12-17-2012)
 Old 10-15-2012, 12:33 PM   #25
Thanks! I just ordered one of these.
 Old 10-18-2012, 10:58 AM   #26
So, it looks like after running the 3" AEROS 3" ID at 72F against my AEM CAI + COBB TIH, there is no real gains to be had with my current setup on the stock k04. It seemed to help at the higher temps as shown above which is great, but at the lower temperature, the runs were damn near the same. I might see a little more gain with the AEM dryflow filter with the SURE intake, we'll see.
The green line is the 3" AEROS and the yellow line is the AEM CAI + COBB TIH. Regarding the attached logs, '4th_72F_10512_2.16_NB_pass2_alone...csv' is the baseline with AEM + COBB TIH and the '2.20_72F_SB_passenger run 1.5.csv' is with the 3" AEROS.
Since I am going with a BNR at point, I imagine that the gains of the 3" AEROS will become more apparent.
File Type: csv 4th_72F_10512_2.16_NB pass2_alone (1).csv (15.6 KB, 9 views)
 Old 10-18-2012, 12:37 PM   #27
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
At first I was thinking that since the intake is silicone, you can't use an adapter when you have to switch turbos.
But BNRS3 is the same size, it hink ive heard a tiny bit bigger than the OEM 2" outlet maybe.
 Old 10-18-2012, 12:56 PM   #28
I think I should be good to go for the BNR inlet with this intake.
 Old 12-17-2012, 08:35 PM   #29
I decided to turn the Aeros Short RAM into a CAI; I ordered these two parts after taking measurements off of my AEM CAI tube. This should be plug and play, I will just need to find a way to secure the cold air tube to my car by the intake filter somewhere. The metal coupler will connect to the Sure Aeros MAF housing via coupler, and the air filter will screw onto the other end in the fender.
I figure I will paint the metal intake piece black to match the intake.
Metal coupler: 60 degree, 3.5" OD, 6" leg lengths, eBay PN 271074750025
3.5" intake coupler- 3.5" OD, ebay item 280896324664
As usual, I'll post logs when I convert this to a CAI.
Hush (12-21-2012), Koke382 (12-17-2012)
 Old 12-17-2012, 08:57 PM   #30
Why not aluminum?
 Old 12-17-2012, 09:28 PM   #31
Why not aluminum?
The tube is 6061-T6 aluminum.
Lex (12-18-2012)
 Old 12-21-2012, 11:01 PM   #32
Here is how the CAI conversion turned out. I posted this in another thread-
http://www.mazdaspeedforum.org/forum/foru...ri-cai-133478/
I hacked about 2" off of each side of the aluminum 60 degree pipe to line the pipe up well with the AEROS MAF and into the fender. I made a custom mount for the CAI extension so the CAI can bolt to the body and take strain off of the SURE hose. I bolted this to the 3.5" tube with a hose clamp and aligned it for a good fit. I slapped the filter on the other size of the extension, and done. The whole thing took me about an hour. I am going to get the CAI extension powder coated black if I find there are gains from it.
I'll post logs when I get a chance. I am expecting to see cooler IATs and probably some gains from this mod.
Chicagospeed6 (12-22-2012), eljefe62 (12-28-2012), Hush (12-21-2012), Mike@Stratified (12-22-2012), scubasteve711 (01-21-2013)
 Old 01-13-2013, 07:20 AM   #33
mrdouble99's Avatar
Posts: 256   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Can't wait to install mine
Mazdaspeed3 - sold
- Engine: Cobb AccesPort - Sure Full3 Aeros ID300 - Autotech internal - CP-e 3" cated Downpipe - CP-e xflex RMM 75A - Street: H&R spring - Koni Yellow - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50 - BFgoodrich Gefroce KDW2 235/40R18
- Drag : 16x8 et50 FD wheel - Hoosier Quick Time Pro D.O.T. 26x9.5x16 -
- 2010 drag time : 12.737@108.51mph - 259whp@280wtq
- 2013 drag time : 12.432@111.02mph - 28?whp@3??wtq
2014 Black Mazda 6 GT MT
- Corksport Lowering Spring - Corksport LED fog Light Kit - Corksport LED Interior Light Kit - Corksport Shifter bushing
- RX8 R3 19x8 et47 wheels - Michelin PSS 245/40ZR19
- 3M Gloss Black Chrome Wrap
- Autoexe Shifter Knob
mrdouble99 is offline   Reply With Quote
 Old 01-20-2013, 07:50 PM   #34
cessnan1315efw's Avatar
Posts: 34   (View Stats)
cessnan1315efw has a spectacular aura aboutcessnan1315efw has a spectacular aura about
If i switched my Cobb sf intake filter for one of those dry filter AEMs would I get any gain? Just wondering as my Cobb filter hasn't been changed in about 2.5 years. Thing looks clean tho!
cessnan1315efw is offline   Reply With Quote
Sure Aeros 3 full intake Moreira 2010 MS3 - Turbo Induction 72 07-28-2013 12:28 PM
Installed the SURE Aeros today iggy097 Gen2 MS3 General Discussion 10 08-19-2011 12:48 PM
SURE aeros installed! blakkat Mazdaspeed3/6 General Discussion 30 05-02-2011 01:12 PM
Page generated in 0.55248 seconds with 34 queries
