Like Tree5Likes
  • 1 Post By 2010mps
  • 1 Post By Whitebullet
  • 3 Post By 5doorsoffury
 Old 11-19-2018, 05:10 PM   #1
2010mps's Avatar
Posts: 2   (View Stats)
2010mps is an unknown quantity at this point
Default Installing a sub
Can you plug and play a sub into a 2010 speed3 with the wires that are already there for the stock sub?
jrosvaldoavila likes this.
2010mps is offline   Reply With Quote
 Old 11-26-2018, 09:05 PM   #2
Mezdee's Avatar
Posts: 7   (View Stats)
Mezdee is on a distinguished road
updates on this?
Mezdee is offline   Reply With Quote
 Old 12-30-2018, 08:46 PM   #3
Whitebullet's Avatar
Posts: 24   (View Stats)
Whitebullet has a little shameless behaviour in the past
Someone was selli g a wire harness on FB mazdaspeed forum for this recently
2010mps likes this.
06 MS6 GT
SP63 Stage 1, bnr s3, hpfp, cai, cs tmic, southbend stage 2, E30 tune
Whitebullet is offline   Reply With Quote
 Old 12-31-2018, 07:41 PM   #4
Carskick's Avatar
Posts: 315   (View Stats)
Carskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond reputeCarskick has a reputation beyond repute
Any amp with a high pass input will allow you to splice into factory speaker wiring. Then set LPF to 70-100 depending on preference. Not the best solution, but relatively easy with factory wiring.
2009 Mazdaspeed 3 Sport (Original Owner) - 95k miles on original Motor & Turbo and counting
Current Performance Mods: APv3 Freektune 93 & E-30 | JBR 3.0 SRI | ETS TMIC w/JBR Red Tubes | SpeedDaddy TP | AT HPFP | Damond Triple Mounted | Southbend S2 Endurance Clutch/Fly | Stoptech Slotted Rotors | EBC RedStuff Pads | Enkei PF01 18x8.5 +48 | Continental EC Sport 245/40R18 | KWv2 Coilovers | Whiteline LCA Bushings, Anti-Lift, & Bump Steer | Whiteline Endlinks | JBR .125 FSB & RSB w/billet bushings/mounts | CS Lower Tie Bar | DM OCC w/VTA | JBR Shifter Bushings
Stereo Mods: Pioneer AVH4100NEX | Phoenix Gold 6.5" Comps Front | Focal 6.5 Coax Rears | Polk 12" in Trunk Floor Enclosure | PPI 4x125W amp driving Fronts & Sub
Other Mods: FIAMM 72112 Low Note Horn alongside stock
Mods Awaitting Install: Redline Leather Center Armrest & Handbrake Boot
Future Mods: Injector Seals | Built Block & BNR S3v2 if ZZB
Removed Mods: JBR 70A RMM | Koni STR.T Orange Shocks
Carskick is offline   Reply With Quote
 Old 01-01-2019, 06:46 AM   #5
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
My .02 on this subject just for the hell of it.
The oem sub is dvc. I think there dual 1 ohm. So the amp puts power out at .5 ohm load. Anything above that and the power output drops. Any 1 ohm dvc sub that you find will have such a high power rateing that the power out from the amp into this sub will be like throwing a cup of water into a well. At that point just get a self powered sub and use the amp output as a signal input.
MECP
2012 BM
Rfinkle tune in progress
2010mps (01-14-2019)
 Old 02-07-2019, 10:03 AM   #6
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
I didn't pay attention to that so it mean the factory sub amp is probably based on a IC chip directly connected to the car 12v to save the voltage step up power supply usually found in an aftermarket amp.
Do you know if door speaker are the same low impedance with bose system?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 02-07-2019, 07:03 PM   #7
Groans: 74
Yes. I posted the specs at one point but i believe they are the usual 1.5-2 ohm woofers and the cross over for the tweeters are done in the amp but dont quote me on that last part. Every channel is done with the Bose amp. Door components d pillar mids along with the sub.
The big suck with a high level in from the stock amps output is very filtered/ crappy bass . I believed i just tapped rca's on the bose amp inputs before i did my full system.
I want to say the amp is 200w so @80% efficiency thats about 20amps.
Edit: as far as the voltage stepup comment is concerned i am pretty sure there is a dc to dc converter vs coils if you were talking about the amps power stage. I dont see how looking at the sub being connected to a multi channel bose amp would make you come to that conclusion.
MECP
2012 BM
 Old 02-07-2019, 08:14 AM   #8
tinycafe1972's Avatar
tinycafe1972 is an unknown quantity at this point
Easiest way is the splice into the rear speaker wires just as others have suggested. Just make sure your amp has a low pass filter. You will have to run a power wire from the battery and a ground wire to the nearest ground by the amp.
While one this topic does anyone have an elegant solution to positioning a remote sub level control somewhere around the dash?
Sent from my Moto G (5) Plus using Tapatalk
tinycafe1972 is offline   Reply With Quote
 Old 02-07-2019, 09:41 AM   #9
Jeff23spl's Avatar
You definitely need an amp + a sub, i personally prefer to have an amp that is more powerfull than the sub or at least equal to keep better control of it. I did put a 10inch on the side using some of the jack holder space in my 2007 ms3. My FG amp did not had high level input so i just added a LOC adapter to make it work. It isn't as best as an RCA signal from an aftermarket unit but it isn't that bad for a sub.
Wife drive 2010 CX7
 Old 02-08-2019, 03:08 PM   #10
Jeff23spl's Avatar
I'm an electronic tech and used to be active in car audio before...i'm still curious about everything around this even if i stopped buying audio parts to save for performance parts.....(loading the trunk with a lot of heavy subs won't help 1/4 mile times...)
So With a 12v nominal at the amplifier stage and 4ohm load, you can expect at best 22w from the best IC chip...Any aftermarket head unit claiming anything above this is peak power or bullshit because i didn't see any yet with a voltage booster.
To increase power you either need to increase voltage or decrease impedance. My point was: If bose used very low impedance woofer in the range of 0.5ohms instead of the usual 4ohms/2ohms it could have been to use a simplified amplifier device. With an added power stage after the ic, you can get 100+w at 0.5 ohms with just 12v...
You can also combine to feed a 2 ohms load under 12v and get something like a 40+w rms that would be about what we have with the bose system....
I also found that old thread about the 3
Factory Bose Specs and Diagram
Wife drive 2010 CX7
CEL after installing CS SRI+TIP Nefarion 2010 MS3 - Troubleshoot/Diagnostics 38 11-01-2011 09:47 AM
need help installing ddm hid kit Dfresh619 Exterior 8 04-03-2010 11:28 AM
need hlp after installing SU BPV camdensms6 MazdaSpeed 6 - Engine, Transmission & Driveline 3 11-02-2009 02:54 PM
help on installing MBC tburton101 MazdaSpeed 3 - How-To's 1 08-27-2009 02:35 PM
Page generated in 0.31488 seconds with 26 queries
