![]() Join Date: Jan 2019 Location: Straya
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
(Thread Starter) | Not Ranked : 0 score Reaching out to the brain trust here, about a month ago I cleaned my intake valves, and today I had to take of the intake to install a JBR TIG, and thought I would check the condition of the valves whilst I'm there. Intake valves for cylinder 2 and 3 are clean (3 is cleaner than 2) but the valves on cylinder 1 and 4 are caked up again. I have tried to take pictures, but to be honest they aren't great. Is this normal or what is the cause for some to be worse than others? P.S I still have to install an OCC, but have changed the PCV valve last time and blocked off the EGR as well.
__________________ Mods slowly coming along!!!! Autotech HPFP, CircuitWerks Down/Testpipe, Cobb Accessport V2 and a CPE Turbo Inlet Pipe (Waiting to put it on) |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Is your signature mod list correct? If you are running that 3” catless downpipe (even with the required hpfp upgrade) on stock tune you are likely to soon blow your engine. You are likely getting really high nasty boost spikes and unsafe AFRs. You need a tune compatible with the increased flow on the exhaust side. You should be a lot more concerned about that than what direct injection does to the back of your intake valves. Do you have a way to monitor and log engine operation?
![]() Join Date: Feb 2017
Rep Power: 0 ![]() ![]() Thanks: 8
As far as the valves... considering that you do have the DP some say that an Oil Catch Can could help with carbon buildup. From chemistry class I learned that the based way to clean carbon is with massive heat. Since Cyl 2 + 3 run the hottest could explain why you see less buildup on those two cylinders. Also if emissions allow it in your state delete that nasty ass EGR too. That shit is dirtier than a coal plant in West Virginia. | |
(Thread Starter) | Not Ranked : 0 score Thanks for the response, sig is correct, I have my wedding coming up, so all funds are on hold, but I have been monitoring via Torque and baby the car, until I can afford a Cobb. AFR goes as low as 13 ish, but generally staying around 14.7.
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Yeah, but under even fairly mild throttle, it should be around 10.5-11.0 on the stock tune. You're really running dangerously uncontrolled right now.
| Not Ranked : 0 score Way too lean for a direct injection turbo engine under boost. Be careful to avoid even mild boost until it is tuned.
| The Following User Says Thank You to MSMS3 For This Useful Post: | Vansquish (07-20-2019) |
| Not Ranked : 0 score For comparison the ots cobb map will put you around 11.6 @ wot. 13 is good for partial throttle and fuel economy but a big no-no for actual power
__________________ MODS: Autotech HPFP (Duh) Cobb SF Intake + TIP. Cobb AP Self tuned CPE Intercooler CPE Catback CS Turbo EBay DP HKS SSQV BOV (Recirc Kit) JBR Boost Tubes 1 Step Colder NGK Plugs gapped @ .28 COBB RMM Damond PMM JBR Shift Bushings Mishimoto Shift Knob Stock BCS (Already Purchased Grimspeed EBCS) Stock Suspension (Planning on purchasing BC Coilovers) |
| Intake valves never checked until 65k miles; meth injection definitely helps keep valves clean | dale_gribble | Mazdaspeed3/6 General Discussion | 59 | 08-03-2014 08:18 PM |
| Intake Valves at 10K | [R]usty | Gen2 MS3 General Discussion | 33 | 08-03-2014 10:23 AM |
| Cleaned my intake valves | polysynth | MazdaSpeed 3 - Engine, Transmission & Driveline | 154 | 08-01-2013 07:42 AM |
| Cleaning the Intake Valves | 802MS3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 42 | 06-17-2011 09:40 AM |
| Are Your Intake Valves All Guncked Up? | SpdFreak | MazdaSpeed 6 - Engine, Transmission & Driveline | 131 | 07-31-2010 08:24 AM |
