 Old 06-21-2015, 08:20 PM   #1
Savo1997's Avatar
Posts: 45   (View Stats)
Savo1997 has much to be proud ofSavo1997 has much to be proud ofSavo1997 has much to be proud ofSavo1997 has much to be proud ofSavo1997 has much to be proud ofSavo1997 has much to be proud ofSavo1997 has much to be proud ofSavo1997 has much to be proud ofSavo1997 has much to be proud of
Default intermittent smoke
One day prior to upping my idle 200rmp, I got heavy smoke after sitting with the car running for 10-15 minutes. I upped the idle and it went away.
2 weeks ago I had my mechanic install DP (I tried and failed to myself), and since then, if I start the car and drive a short distance, shut it off, and restart it within under 30 mins, the car smokes pretty heavy for about 5 mins then goes away. However, if I start the car, drive it until fully warmed up (15+ mins), turn it off, and LET IT SIT (for an hour or more), car doesn't smoke upon starting up again. So the car is only ever smoking after a quick trip and then restart. Confusing, tried searching/reading a bunch about smoky turbo stuff and this specific issue didn't seem to come up. She's got 57,000 with mods listed in signature.
Any thoughts?
Current: 07 ms3, JBR: TIP SRI, ETS: TMIC, CORKSPORT: RMM & HPFP, Hypertech Tune, EBay DP + Test Pipe & into stock CB
Planning/Dreaming: Cobb AP, Koni Yellows
Savo1997 is offline   Reply With Quote
 Old 06-22-2015, 11:36 AM   #2
acousticdefbot's Avatar
Posts: 319   (View Stats)
acousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the worldacousticdefbot is the leader of the world
this is not an uncommon issue and i'm not sure the way in which you're producing is all that different from others. it's likely that your previous setup was just masking the issue, and now that you've opened it up a bit it's become unmasked. is your downpipe with or without a cat? what kind of oil do you use? you might also consider a new intake setup with the ventilation hose relocated closer to your turbo inlet.
wonder twin powers activate! shape of, a wheel!
guzzlin' a guinness stout.
acousticdefbot is offline   Reply With Quote
 Old 06-22-2015, 12:39 PM   #3
Savo1997's Avatar
I have a DP + Test Pipe, using Pennnzoil full synth 5w 30... Interesting that the ventilation hose closer to the turbo would make a difference...
 Old 06-22-2015, 02:23 PM   #4
the fix created more vacuum. mazda issued a service bulletin for this. try running rotella t6 (5w-40) and then bump your idle back to normal to see if that alleviates it. bumping up your idle is another solution but not everyone wants their idle near a thousand. the intake is another solid fix and most aftermarket companies provide relocated ventilation via the turbo inlet pipe now.
 Old 06-22-2015, 02:41 PM   #5
Savo1997's Avatar
I have a JBR intake and TIP. That would have relocated it already, correct?
 Old 06-22-2015, 03:07 PM   #6
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
For stock size intakes I believe only CS has the option of having the ventilation hose relocated to the turbo inlet.
Larger +3" aluminum intakes and CP-E TIP have it relocated closer to the turbo.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 06-22-2015, 03:15 PM   #7
if you are running this particular intake where it is located on the elbow just behind the maf housing:
then it would not. an example of where it is relocated with the fix:
The Following 2 Users Say Thank You to acousticdefbot For This Useful Post:
Savo1997 (06-23-2015), tegxsi (06-22-2015)
 Old 06-22-2015, 07:51 PM   #8
Savo1997's Avatar
Yea. That top pic is mine... Damn. Wasn't aware of that issue when I purchased. Kinda pissed now.
Intermittent issue ty.thompson1981 Mazdaspeed3/6 General Discussion 15 06-05-2015 06:53 PM
Intermittent Horn myslow1 MazdaSpeed 3/6 - Car Audio & Electronics 1 12-30-2013 12:08 AM
Intermittent Fuel Cut - Need Help kore2000 MazdaSpeed 6 - Engine, Transmission & Driveline 0 03-18-2013 05:16 PM
Intermittent Hum/grind helmetface Mazdaspeed3/6 General Discussion 23 01-07-2013 06:05 AM
Page generated in 0.30558 seconds with 22 queries
