Like Tree18Likes
 Old 05-01-2014, 09:21 AM   #1
06wwpms6's Avatar
Posts: 29   (View Stats)
06wwpms6 will become famous soon enough
Default Just got stock downpipe out
Hey guys just found out how to post new thread haha. finally after 8 hours got my stock dp out what a bitch hope my new one goes in easier, should be here today sometime. I will let everyone know what it sounds like with cs dp, rp and the stock exhaust. will try to figure out vid clip. Thanks for all the help work starts next week so wanted to get this done.
Cobb sri/ Cobb tih/ Cobb ap v3/ Cobb xle bpv... Corksport rmm/ Corksport hpfp/ Corksport dp/ Corksport rp... JBR tmm/ JBR pmm/ JBR ssp&ssb... Denso ITV 22... Freektune...CPE single exit cb...HDI FMIC...
06wwpms6 is offline   Reply With Quote
 Old 05-01-2014, 09:35 AM   #2
littleloogy's Avatar
Posts: 4,005   (View Stats)
You mean how much power gains you will see right? We like power!!!
 Old 05-01-2014, 09:58 AM   #3
06wwpms6's Avatar
WHoooooo spark plugs and dp here fellas.
yes yes I love power my fraand
Last edited by 06wwpms6; 05-01-2014 at 09:58 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-01-2014, 10:29 AM   #4
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
lol@speed6 downpipe...
Did it once.
NEVER AGAIN
What a lovable bunch we are!!
The Following 10 Users Say Thank You to predapio For This Useful Post:
Agent_Orange (05-01-2014), BigjohnB20 (05-02-2014), Fatpig78 (05-01-2014), galens47 (05-01-2014), Gr8Speed (05-02-2014), HawkeyeGeoff (05-01-2014), jm211 (05-01-2014), mdl3v8 (05-01-2014), shnouz (05-01-2014), trancehead (05-01-2014)
 Old 05-01-2014, 11:08 AM   #5
Big Dog's Avatar
Posts: 730   (View Stats)
Groans: 89
Groaned at 9 Times in 9 Posts
I'm dreading my Speed6 downpipe install and the diff mount......... Speed6 makes my Speed3 look easy.
 Old 05-01-2014, 11:12 AM   #6
What about internals?
Lightweight likes this.
 Old 05-01-2014, 11:37 AM   #7
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
He's got HPFP in his sig- still a brownie tho
You'll enjoy the extra breathing up top with the dp- be sure to pull some WGDC to match!
340hp / 371tq
06wwpms6 (05-01-2014)
 Old 05-01-2014, 11:42 AM   #8
kladuscan's Avatar
Posts: 70   (View Stats)
kladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant futurekladuscan has a brilliant future
Threads like this make me not want to install the dp, or atleast save it for BT time...did the diff mounts last weekend...that was a pain...
BCM MS6 #5338
Mods: a few things here and there...
kladuscan is offline   Reply With Quote
 Old 05-01-2014, 11:45 AM   #9
ihasmazda's Avatar
Posts: 1,011   (View Stats)
The dp install isn't that bad, just time consuming. Make sure to have decent tools. 14mm crow foot wrench is great to get a couple of the turbo flange nuts tight. To get the stocker out just undo the rear and pass MM and have someone pull the motor forward and it'll squeeze out.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
The Following 4 Users Say Thank You to ihasmazda For This Useful Post:
cciepunk (05-01-2014), derek13p (05-01-2014), ItsNox (05-04-2014), JgamB (05-01-2014)
 Old 05-01-2014, 12:18 PM   #10
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Dropping the sub frame a couple inches makes it a helluva lot easier too. Just be sure to mark and unbolt the steering pin prior.
 Old 05-01-2014, 01:24 PM   #11
I cannot see signatures on Taptalk. Nor can I see if brown or not. He should really donate, no one likes brownies, not even me. If I would have know he was a freeloader, I would have told him to stick the DP up his ass.
Good luck on the install OP. Can you please post up any gains? I currently have the same setup as you (exhaust wise). I would like to see how much it increases flow.
 Old 05-01-2014, 01:47 PM   #12
rymanmazda's Avatar
Posts: 1,531   (View Stats)
Groans: 122
I don't know why everyone complains about the MS6 downpipe removal and install. I was in and out in 5 hours and fairly easy. The hardest part was modifying the alternator shroud to make the DP fit.
Freektune: 400whp/387awtq
-Autocross Setup-
Other Rides:
The Following User Says Thank You to rymanmazda For This Useful Post:
 Old 05-01-2014, 01:53 PM   #13
Groans: 665
Cuz fuck a speed 6, that's why.
Code Monkey (05-01-2014), predapio (05-01-2014)
 Old 05-01-2014, 01:59 PM   #14
rymanmazda's Avatar
Groans: 122
Mines a MS6 also. Wasn't that bad! You gain TONS of room if you take off the windshield wipers, WW motor, and the plastic shroud hiding the WW motor.
-Autocross Setup-
Other Rides:
 Old 05-01-2014, 02:05 PM   #15
predapio's Avatar
Groans: 309
AND if you take out the top motor mount.
None of which I did.
The Following User Says Thank You to predapio For This Useful Post:
rymanmazda (05-01-2014)
 Old 05-01-2014, 02:42 PM   #16
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
i pulled mine out through the top, no dicking around with the sub frame or rmm. you have to unbolt the heatshields from your dp and it should have enough room to come out, maybe the tmic bracket as well. its been awhile but pick your poison. rmm and rocking the engine is probally the easier option unless your by yourself.
also check your tire pressure
The Following User Says Thank You to dooderek For This Useful Post:
 Old 05-01-2014, 04:46 PM   #17
06wwpms6's Avatar
Downpipe in and experiencing boost cut haha.
 Old 05-01-2014, 05:06 PM   #18
rymanmazda's Avatar
Groans: 122
Tune?
-Autocross Setup-
Other Rides:
 Old 05-01-2014, 05:11 PM   #19
06wwpms6's Avatar
cobb ots stage 2 sri/tip
 Old 05-01-2014, 05:16 PM   #20
Big Dog's Avatar
Groans: 89
Shitty map maybe. Go back to a milder stage 1 map. If the issue goes away you're in desperate need of a tune.
Logs would help us, help you. If you can post them in a format us peeps can see it on our phones like excelor screenshot.
Also, why are your still Brown? Go VIP already.
The Following User Says Thank You to Big Dog For This Useful Post:
 Old 05-01-2014, 05:26 PM   #21
06wwpms6's Avatar
Thanks for the info I will try going to stage 1 and I start work next week so donation will be coming. Could the problem like TiGreySpeed6 said above be my wgdc?
 Old 05-01-2014, 05:29 PM   #22
rymanmazda's Avatar
Groans: 122
We won't know for sure unless we see some logs.
-Autocross Setup-
Other Rides:
 Old 05-01-2014, 05:31 PM   #23
06wwpms6's Avatar
Has anyone tried the corksport ots maps are they any better.
 Old 05-01-2014, 05:33 PM   #24
Big Dog's Avatar
Groans: 89
^^^^Ding Ding Ding.
Logs or bust.
Run Cobb ots stage 1 for just the upgraded intake, I think it's version 231 and it will boost around 15psi.
Last edited by Big Dog; 05-01-2014 at 05:33 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-01-2014, 05:49 PM   #25
Groans: 665
Downpipe in and experiencing fuel cut haha.
FIFY.
There's no such thing as "boost cut".
 Old 05-01-2014, 05:51 PM   #26
06wwpms6's Avatar
here is a log I did when I noticed it if anyone needs a better one let me know.
 Old 05-01-2014, 05:55 PM   #27
06wwpms6's Avatar
Thanks AgentO I still have many things to learn.
 Old 05-01-2014, 06:08 PM   #28
derek13p's Avatar
Posts: 1,195   (View Stats)
derek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the worldderek13p is the leader of the world
Groans: 38
I've taken off everything you could take off on the 6, worst thing by far is fmic. Fuck doing a fmic. I'd rather take the damn engine out again.
06 MS6 & 06 MS6
The beauty is the beast
Daily driven
derek13p is offline   Reply With Quote
The Following 2 Users Say Thank You to derek13p For This Useful Post:
ItsNox (05-04-2014), rymanmazda (05-01-2014)
 Old 05-01-2014, 06:12 PM   #29
Big Dog's Avatar
Groans: 89
I can't read the log on my phone because it's csv, got an excel format?
The level of work to do the FMIC on a MS6 is much more involved than a 3. I did a lot of research and said, Fuck it, I'm going CorkSport TMIC. Once all the other mods are done I might reconsider it but I'll probably go BT before I go FMIC.
Last edited by Big Dog; 05-01-2014 at 06:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-01-2014, 06:55 PM   #30
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
I'm just going to run a test pipe until it's big turbo swap time lol
08 cwp ms3
 Old 05-01-2014, 06:57 PM   #31
Nice. You are over boosting like a mother fucker. Are you still brown? Damnit! You are using the wrong tune. Try the correct map for your mods!
 Old 05-01-2014, 09:07 PM   #32
06wwpms6's Avatar
littleloogy I thought I was using the correct tune for my car I was running stage 2 sri/tih 91 octane ots map and the only other one I seen was for ic. Am I missing something.
Also I switched back to stage 1 and took some more logs I will try to find different format for phone faces
Last edited by 06wwpms6; 05-01-2014 at 09:07 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-01-2014, 09:19 PM   #33
Big Dog's Avatar
Groans: 89
I'm pretty sure it's the map switch to stage 1 and if everything is ok it's the stage 2 map. If you want to run stage 2 tune but not have issues get an etune.
 Old 05-01-2014, 09:27 PM   #34
06wwpms6's Avatar
here are my stage 1 logs it reached fuel cut once but didn't get it logged Im hoping its just a tune im really trying not to worry bout my speed. sorry but didn't know how to post excel format
 Old 05-01-2014, 10:46 PM   #35
Lightweight's Avatar
Posts: 199   (View Stats)
wgdc?
 Old 05-01-2014, 10:48 PM   #36
rymanmazda's Avatar
Groans: 122
Originally Posted by Lightweight View Post
wgdc?
Waste Gate Duty Cycle
-Autocross Setup-
Other Rides:
Lightweight (05-01-2014)
 Old 05-01-2014, 10:59 PM   #37
hey man I'm in the same boat as you. i just installed dp and running stage 1 91 v231. thought i had internals (bought car used) and the ap on the screen was saying psi is between 1800-2000psi but i pulled my pump today and it is stock, thx to will at pdt, so I'm going to drive it calmly lmao. got my autotechs ready to go in though so going to try and do it this weekend...work all weekend till 5 but it didn't take long to pull the pump now i know what i am doing.
 Old 05-02-2014, 07:33 AM   #38
Jtaylor's Avatar
Posts: 656   (View Stats)
I've been dying to get on this car since i put my DP on but I just don't feel comfortable until I have my internals installed. They arrive this coming Wednesday so hopefully they will be going in the following weekend
08 MazdaSpeed3
 Old 05-02-2014, 08:22 AM   #39
Yeah I was the same way. I've gotten on it but I don't go wot. It's very nice. I'm waiting to install my internals as well.
pt 2 coming soon..........
 Old 05-02-2014, 08:24 AM   #40
06wwpms6's Avatar
Hey lightweight I have the pump internals and am still hitting fuel cut with new downpipe. Let me know wen your autotechs are in how its going. and 1800 to 2000psi is right where you wanna be at if I understand correctly.
Page generated in 0.55417 seconds with 34 queries
