 Old 07-20-2009, 10:55 AM   #41
ozzzzz's Avatar
Posts: 24   (View Stats)
ozzzzz is just really niceozzzzz is just really niceozzzzz is just really niceozzzzz is just really nice
You are absolutly right about water to air being more efficient at transfering heat better than air to air. I have been in the HVAC field for 10 years and worked with large commercial chillers and very small ice machines (and a lot in between). Water to air is better. The thing is it has to be matched properly to the application for it to work its best. Just my 2cents.
ozzzzz is offline   Reply With Quote
 Old 07-20-2009, 11:52 AM   #42
TurboGhost's Avatar
Posts: 85   (View Stats)
TurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to beholdTurboGhost is a splendid one to behold
As far as safety.. I said replace the crash bar, not remove the crash bar - as in use less of a stronger material or a better shape to get the same structural properties in less space.
Edit: exactly like what SS did^^
I've seen some promising data on L/A intercoolers but I'm still not convinced they perform well for long periods of time or after the car sits in the sun for a while and the water heats up.
"I said replace the crash bar, not remove the crash bar"
Got it, I first read it as "replace the crash bar with an intercooler". Some ppl would just cut the bar without replacing it's function. It looks like it's intended to deal with fender benders and would play little role in a serious crash, but in a new car there's not extra structure. I'm guessing that the bar also helps stiffen the chassis from twisting.
SS Installer's welded in piece is the right way to go; not everyone thinks it through like that.
TurboGhost is offline   Reply With Quote
 Old 07-20-2009, 12:26 PM   #43
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
Let me tell you about L/A intercoolers. The only things it has an advatage over A/A is that it takes longer to heat soak and it can be filled with ice water for racing apps. Don't forget the heat exchanger in a LA intercooler will only be as effective as the air that is cooling it, this being the same air that would be used to cool the A/A intercooler, so its a wash. LA intercoolers also have the advantage of being more compact, but only at the cost of being more complex.
El Fantasmo Del Negro
Helicopter Cat LIVES
FantasmoNegro is offline   Reply With Quote
 Old 07-20-2009, 12:47 PM   #44
kilik2's Avatar
Posts: 1,254   (View Stats)
kilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the worldkilik2 is the leader of the world
Groans: 127
Groaned at 40 Times in 31 Posts
That is where a heatsink comes in, but no one realizes that no matter what system you use you need a heatsink. In an A/A IC you use the ambient air as a heatsink. In a L/A you can use a myriad of things as a heatsink, a seperate flowing water source, a condenser, refrigerant, tec's, most of these could be used with A/A too but L/A would be more efficient.
I am almost done with the DCR logo. I am going to ask a friend of mine for some input before I say I am done with it. (He is much more creative than I am.)
Do they want to keep the skill and pistons or would they like something completely different? I kinda used the skull idea.
kilik2 is offline   Reply With Quote
 Old 07-20-2009, 03:00 PM   #45
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
I don't understand the point of any A/L intercooler when you can do meth for half the price and get better results.
smakdown61 is offline   Reply With Quote
 Old 07-20-2009, 04:01 PM   #46
Thermonuclear Skeet
Groans: 188
Because A/L never runs out.
 Old 07-20-2009, 04:14 PM   #47
SpeedSixxx's Avatar
Posts: 4,184   (View Stats)
Groans: 778
lemme also explain something...
A/A is only more efficient when driving long distance or "road/course" racing as the core is always being cooled by flowing air.
in every other aspect the L/A set up blows away the A/A cores..
sitting at the track L/A will not heat soak as a A/A would and in everyday driving and weekend racing (driving along the strip looking for a quick drag) the L/A will blow a A/A away because the A/A will always need a bit of driving/air flow time to cool down where the L/A will always be at coolant temps and ready to go....this is what I read and learned in a few forums and web sites that offer L/A and A/A cores ...
good luck....buy a A/A and don't think about it...it's easier and cheaper!
Peace NIGGAHS
 Old 07-20-2009, 04:26 PM   #48
GQ_WhiteMS3's Avatar
Posts: 658   (View Stats)
GQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the worldGQ_WhiteMS3 is the leader of the world
+1 ... My A/A will get to 150* but I leave the light and step on it ... as soon as the meth is spraying it drops like a stone to and sometimes just below ambient ... I don't see L/A performing like that.
LOL 2 new title .... GIVE US MORE NEW PICS and we'll stop this incesive BS
GQ_WhiteMS3 is offline   Reply With Quote
 Old 07-20-2009, 06:58 PM   #49
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
In a vehicle your dealing with a finite amount of coolant in the system cooling down the charge air, but that coolant must then be cooled back down by AIR...
So essentially once you have brought the coolant temp of your L/A IC system up to ambient air temps you are essentially no more efficient than a traditional A/A IC.
If an A/A IC can't bring charge air temps below ambient, how is an L/A IC any more efficient when the coolant it uses to cool the charge air must be itself cooled down by the same air the A/A IC would be using.. The temperature change in an A/W system may be faster, but unless you add a secondary means to reduce the temperature of the coolant in the system, the end product is essentially the same---charge temps no better than ambient.
Originally Posted by glocK23 View Post
How can A/A be more efficient than A/L cooling? If not half assed, liquid cooling is more efficient at dissipating heat. Take for example engine coolant, PC watercooling, nuclear reactors as stated by klik.
L/A cooling is only more efficient in those situations because the airflow is very limited, or the surface area of those parts needing cooling is relatively small. In a vehicle traveling at speed you have an essentially limitless amount of ambient air to cool down your IC which has a MASSIVE surface area in relation to the amount of air flowing through..
The Following User Says Thank You to SSinstaller For This Useful Post:
SpeedSixxx (07-21-2009)
 Old 07-20-2009, 07:29 PM   #50
kilik2's Avatar
Groans: 127
done arguing. when I get some money I will build a real l/a intercooler and show why it works. I wouldn't just have water running over an air intercooler, I would have a heatsink. I take it no one has read that yet. You have to have a heatsink if you are going to use a liquid. I will not divulge what heatsink I will use for fear that someone will try and steal it. Two years bitches, and I will have that shit fabbed and on my next car.
But whatever, A/A is better...I concede, and no longer feel like debating.
 Old 07-20-2009, 07:46 PM   #51
Groans: 60
Sorry to ruin your party, but out here where the rest of us live you can't just say "my way is better" and expect people to take it as gospel.
Just to be clear, what happens when your magical heatsink reaches the same temp as the ambient air? What are you then going to cool said "magical heatsink" back down with--If not a fan using air? Also, how much does your magical heatsink weigh, how much current does it's magical cooling system draw, where will you put it?
Two years, and I'll have a new house, and 600hp with an air to air IC.....
It's not personal it's the INTERNET..
 Old 07-20-2009, 07:54 PM   #52
boosted3's Avatar
Posts: 855   (View Stats)
boosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the worldboosted3 is the leader of the world
I never made this a thread lol.who did this lmaooo
boosted3 is offline   Reply With Quote
 Old 07-20-2009, 08:00 PM   #53
Groans: 60
I'd guess that Randy separated this OT crap from the DCR manifold thread..
 Old 07-20-2009, 08:04 PM   #54
boosted3's Avatar
wtf thats gay,,,he wants to focus on making money thats why hahahhaha.So he makes this thread haha.wow whatever
The Following User Says NO Thank You to boosted3 For This Un-useful Post:
 Old 07-20-2009, 08:05 PM   #55
phailerider's Avatar
Posts: 4,639   (View Stats)
you made the thread when you asked why dcr was wasting their time on turbo manis when they should be working on "fixes" and "safety" measures. thread went to ass.
btw... with the all the knowhow that the big nascar teams have... why the hell do you suppose they arent trying to pioneer better fuel economy, and better minivan crashtest ratings?
seems like a waste to spend all that money to go real fast round and round in a circle.
whatcha think boosted3? dumbasses arent they? stupid rednecks that just want to go stupid fast. they dont spend their time on the important stuff do they?
phailerider is offline   Reply With Quote
 Old 07-20-2009, 08:07 PM   #56
gay?!?
its a vendor section dumbass. what else am i supposed to focus on here? i pay to have this section SPECIFICALLY to sell shit.
you are officially the biggest fucking idiot on this board....
dont post whore here anymore.... im gonna delete every one. your posts are totally flimflam junk.
The Following User Says Thank You to phailerider For This Useful Post:
AndyMS3 (07-21-2009)
 Old 07-20-2009, 08:45 PM   #57
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
Originally Posted by palerider View Post
Just curious... But why should dcr be trying to figure out why these motors blow? They already think they know why these motors blow. You just don't want to believe it.
I'll tell you what the fix is. Ready?
Suggestion.
After the manifold, develop and sell the DCR Accessport map/ standback tune for various mods, guaranteed to make max power and not to blow.
You and DCR would make a fortune.
Suspension:
 Old 07-20-2009, 08:51 PM   #58
Groans: 60
Suggestion.
The only problem with that idea is the word "guaranteed".. Remove that one word and you have a great idea..
Add a little checkbox on the bottom of the sale page for "add built DCR longblock +$5999.99", if you add that little option, then they'll put "guaranteed" back in..
phailerider (07-20-2009)
 Old 07-20-2009, 09:19 PM   #59
JMEngineer's Avatar
Posts: 2,122   (View Stats)
I can't wait until I can actually check that box...
-GTX2867R Coming Soon
 Old 07-20-2009, 10:13 PM   #60
The Kamikaze King!
Groans: 754
You all know what I mean, palerider included.
I posted half joking and yet serious.
The DCR thinks the blowing problem is PT tuning related. So solve that first.
The power is tuning plus hardware. Solve that simultaneously, as you add hardware sell new tunes to match.
= DCR & pale make bank.
Steve
Suspension:
 Old 07-20-2009, 10:35 PM   #61
killa cam's Avatar
Posts: 450   (View Stats)
killa cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the worldkilla cam is the leader of the world
isee the points many of you are trying to make about l\a vs a\a IC's, but i don't necessarily agree with them. in both cases, the most efficient you can get (without adding other methods like ice) is 100%. however, a\a IC's will be around 60-70% and max out at around 80% (with the absolute best being about 90%), whereas l\a IC's will be around 75-95%, with the possibility of 100%+ when adding ice. i dont see l\a IC's heatsoaking like a a\a IC would, as water is great at removing heat (4 times the specific heat of air!). a proper l\a IC will have a proper sized heat exchanger to cool the water. also cool is if you have a reservoir, you can add ice when you want for a cheap instant boost in performance!
the main downside to l\a is complexity. there is more shit to fail, and more shit to maintain. however, i think the benefits outweigh the drawbacks. you may want something that seldom requires maintenance, and in that case you should get an a\a. remember to take the core out and clean it every 15k miles or so, because they do get messy inside and that will destroy the efficiency of any IC!
killa cam is offline   Reply With Quote
 Old 07-21-2009, 06:21 AM   #62
Thermonuclear Skeet
Groans: 188
Where you say L/A is great at removing heat, its also a bitch to remove the heat once its there. A L/A intercooler is only as good as its heat exchanger allows it to be, and guess what that heat exchanger is cooled by? I currently own two cars, one with liquiad to air and one with air to air and there are differences, the air to air gets back to ambient temp much sooner, where liquid to air takes much longer to get heat soaked. So the real question is what YOU personally would rather have, a car that heats up quick in stop and go traffic, or a car that takes a forever to cool off once you are underway going down the road.
To be honest with yall my L/A intercooled car is getting an Air to Air When it enters the third stage of its life, maybe even a combo of both, but my flow requirements have outgrown my L/A in its current form.
The Following User Says Thank You to FantasmoNegro For This Useful Post:
subparpunk03 (07-21-2009)
 Old 07-21-2009, 06:42 AM   #63
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
and those bitches get mighty hot. trust me.
you dont even want to know how hot.
 Old 07-21-2009, 07:29 AM   #64
kilik2's Avatar
Groans: 127
My job requires me to.
 Old 07-21-2009, 09:45 AM   #65
socks's Avatar
Groans: 125
Heh, mine too. Ive been in a couple reactor buildings at full power. Not fun. 140* ambient, or 115* "wet bulb" temperature.
Where do you work?
 Old 07-21-2009, 12:35 PM   #66
kilik2's Avatar
Groans: 127
Are you a licensed operator? I am a reactor operator, Navy type, but I might be moving to the civilian sector at Southern Nuclear ( Southern Company) soon, we will see.
 Old 07-21-2009, 01:29 PM   #67
socks's Avatar
Groans: 125
Nope, contracted QC.
Which southern site? Ive been to Farley and Vogtle.
 Old 07-21-2009, 01:49 PM   #68
kilik2's Avatar
Groans: 127
probably farley, but I am looking at other options at the moment.
QC, is that the same as QA?
 Old 07-21-2009, 05:02 PM   #69
socks's Avatar
Groans: 125
Quality assurance/quality control... I actually work for a smaaaall niche division of GE that specifies in robotic/remote visual technologies.
 Old 07-21-2009, 06:37 PM   #70
kilik2's Avatar
Groans: 127
You QA/QC guys showing up and telling us everything is wrong, fucked up, and how the hell are we still alive. WE love you guys...LMAO.
That is cool as hell though. You probably do a lot of travelling then.
 Old 07-21-2009, 06:55 PM   #71
socks's Avatar
Groans: 125
Im not like that, I actually dont make any decisions or even inferences based on what i find. I provide the data to our customers and let them make decisions based on that.
I do travel a bit. Sometimes more than others.
 Old 07-21-2009, 07:04 PM   #72
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
wow this just became a bunch of public PMs. More bitching, complaining and arguing please. that is all.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 07-21-2009, 07:23 PM   #73
socks's Avatar
Groans: 125
did you miss the part in the title that said "random nonsense"
kthxbye.
 Old 07-21-2009, 07:26 PM   #74
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groaned at 196 Times in 127 Posts
don't buy the partial throttle thing. n54s run crazy af ratios, no1 changes shit part throttle, no1 blows. U blow cause the motor is weak, you dont make power with BT set ups cause.....? No1 knows, but i got a feeling if randy/dcr ever find out, they might be 1 of 5 in the whole country to dump that kind of change into a ms3.
Laloosh is offline   Reply With Quote
 Old 07-21-2009, 07:29 PM   #75
kilik2's Avatar
Groans: 127
way to be on topic, douche.
 Old 07-21-2009, 07:36 PM   #76
Laloosh's Avatar
dumbest comment of the year?
Didnt you derail this entire page with your reactor/navy bullshit? At least my comment was about this car, and about randys discussion about pt....fuck off
The Following User Says Thank You to Laloosh For This Useful Post:
Scatt Nasty (07-22-2009)
 Old 07-21-2009, 07:37 PM   #77
SgtP's Avatar
Groans: 106
kthxbye.
i guess that does fall into that category. here is some more random nonsense.
13.2@111
Sponsored By: CP-E
The Following User Says Thank You to SgtP For This Useful Post:
evidence (07-21-2009)
 Old 07-21-2009, 07:41 PM   #78
kilik2's Avatar
Groans: 127
Have a fucking sense of humor and check your shit talking at the door.
 Old 07-21-2009, 07:42 PM   #79
Laloosh's Avatar
ummm.....no, fuck off is still my answer
 Old 07-21-2009, 07:47 PM   #80
kilik2's Avatar
Groans: 127
Ok, we see where your maturity level is at.
Check the thread title this has become a banter thread. If you want you can read another thread.
Maybe you didn't notice that the original comment was a play on your fucking name. Some people got their panties in a bunch over nothing.
Actually, when the thread changed I missed SSI response completely..LMAO
I am not saying that the design I want to do is complete yet, still plenty of time left in 2 years to design, test, fabricate, test some more and finish/ install. I hopefully will be in the same predicament as you with a 600hp car be it this one or another one, no more houses though, two is enough for me. I was merely stating that l/a is more efficient at cooling, technically it is still l/a/a unless you use a different heatsink. I have a couple ideas but that is all still brainstorming. I don't expect to sway anyone's opinion without hard evidence especially on this forum.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/l-intercoolers-torque-random-nonsense-hosted-dcr-33092/
Day of 7/23/2009: Top 50 of 283 Referring Pages This thread Refback 07-24-2009 08:01 AM
Torque Wars: 2011 Ford Super Duty Now Tops GMC Sierra 2500 with 400 hp and 800 lb-ft of Torque Haltech Automotive News 0 08-03-2010 07:30 AM
Hennessey MaxBoost 435 for the MKS makes beautiful nonsense [w/video] Haltech Automotive News 0 03-01-2010 05:50 PM
CPe Intercoolers for the MS6/MS3 phailerider Custom Performance Engineering (cp-e.com) 24 11-10-2008 09:05 PM
Page generated in 0.58965 seconds with 35 queries
