| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
(Thread Starter) | Not Ranked : 0 score Pull that restriction out of your turbo and then try it, it might solve the boost control issues that you were trying to figure out. Just and FYI for you. |
| The Following User Says Thank You to ptperformance For This Useful Post: | occschemguy (04-02-2008) |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groaned at 196 Times in 127 Posts
| Not Ranked : 0 score lol i dont have any boost control issues. I've hooked up my bc every which way possible and it all does the same thing. Right now adn for the dyno day i had saturday it was hooked up inline witht he stock bc and it worked great...others said it was impossible....My car just seems to define what ever1 states will or will not work. I did dyno a lil low (302whp 336wtq) @ 18 psi falling to 10 by redline, but this was my base before i try your ptp k04 |
If your car does things different you may want to check and see if that restrictor is still in there. If not that would explain alot. You should not be falling off that much and I suspect that you would see a lot more WHP and WTQ if you could keep the boost up. WGA's are on the way... wait? Did he say WGA are on the way? Yes I did . | |
![]() ![]() Join Date: Mar 2008 Location: Boise, Idaho
Rep Power: 1904 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
| Not Ranked : 0 score How the hell do you get that out there?
__________________ 2008 Mazdaspeed3, Fully built then fully parted. Sold 2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily Mazdaspeed 12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp 11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp |
(Thread Starter) | Not Ranked : 0 score Its a bitch to remove. Back in my mitsu days we made a tool that had a sharpend tip on that has threads and tappered up. You would screw that in then tighten a nut on a sleeve to remove or "pull" it out of the turbo. The Mitsu tool will not work because the fitting on the turbo is just a little biggeron the MS3. The other way is to use a self tapping screw, pliers and a hammer. Good luck. |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,016
| Not Ranked : 0 score lol good luck is right |
| Not Ranked : 0 score i'm not sure where i read this but i remember cobb talking about this and they broke titanium drill bits tring to drill that out lol. |
(Thread Starter) | Not Ranked : 0 score Yep. To be honest they are easy to remove if you have the right tools, or you can drill the whole thing out and tap it for a standard unit. That has worked the easiest for us so far. |
![]() Join Date: Mar 2008 Location: Planet Earth, v3.7
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
__________________ The fastest MS3 in the whole garage... | |
| Not Ranked : 0 score ive installed it 3 different way so far. Btwn the wg and the compressor. Btwn the intkae and the top of the WG Inline with the stock bc It all does the same exact shit. |
| The Following User Says Thank You to Laloosh For This Useful Post: | driver311 (04-03-2008) |
(Thread Starter) | Not Ranked : 0 score We now have the Dual stage BC on the car with the rocket switch. I hope to have some video up of it with the gauge showing how well it works. I hope to have a WGA as well on the car here in a few days. |
| The Following User Says Thank You to ptperformance For This Useful Post: | driver311 (04-03-2008) |
![]() Join Date: Mar 2008 Location: Hudson Valley, NY
Rep Power: 246 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
(Where did you install the boost controller when you set it up in line with the stock boost solenoid? before or after the solenoid? I'm confused.)
Please explain the restricter pills function and how removing it / changing it's size effects boost. | ||
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/laloosh-something-you-may-want-try-1388/ | ||||
| Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more | This thread | Refback | 03-30-2008 05:27 PM | |
| Laloosh vs GTO | Laloosh | Street Racing Stories ( Bench Racing ) | 66 | 04-07-2008 08:40 AM |
