  • 1 Post By
 Old 09-20-2017, 11:46 AM   #1
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
Originally Posted by WillEngineer View Post
Well, I did get it. About 10 days ago.
Besides the weekend, I have driven it each day and it has been all in all an enjoyable experience. Fuel economy is a bit down on the Si, but that's what you get with 140ish more ft-lbs of torque on tap. First tank was 23 mpg and the 2nd tank was 25 mpg.
After doing some very non-aggressive driving for a couple of days and a lot of highway cruise control speed, I did hit a traffic light and floored it on a hard left and got some black smoke. I read through the forums and the rich fuel mixture seems to be fairly normal for this car and nothing to be alarmed at.
At any rate, I'm in for the long haul now so I imagine I'll see you guys/gals around the forum.
Yeah this is normal especially on the stock tune. This isnt officially documented or anything, but from what I've noticed false knock is much more likely to be registered when making a turn and accelerating. Fuel enrichment kicks in and timing is pulled and you get that puff of black smoke.
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
Page generated in 0.23994 seconds with 20 queries
