 Old 02-01-2020, 03:50 PM   #1
Roman-dude's Avatar
Posts: 56   (View Stats)
Roman-dude will become famous soon enoughRoman-dude will become famous soon enough
Default low beam headlight off but sometimes on - wtf? (bulb, ballast, etc?)
The driver's side low beam is mostly out but sometimes it comes on (for a minute or for a day). It also seems to momentarily flicker when I turn it on but that's all. From what I understand, the relay is one for both headlights, so it's not that. The fuses are also ok. Any idea if it's more likely to be the bulb or the ballast or something else entirely? Have the bulbs, can't say I am eager to buy a new ballast if it may not be that. The fact that the bumper needs to come off for this is not helping.
Thanks!
Roman-dude is offline   Reply With Quote
 Old 02-01-2020, 04:33 PM   #2
Tres3's Avatar
Posts: 61   (View Stats)
Tres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to behold
Switch the bulbs from side to side. If the issue follows, it's the bulb. If not, may be ballast.
Also check connectors for corrosion while you're at it.
_____________
2006 Platinum MS6 GT
zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI
Last edited by Tres3; 02-01-2020 at 04:33 PM. Reason: MSF Database - Automerged Doublepost
Tres3 is offline   Reply With Quote
 Old 02-02-2020, 02:00 PM   #3
MSMS3's Avatar
Posts: 2,826   (View Stats)
Thanks!
What year model? Sport or GT? They use different bulbs/systems. Sport is regular halogen. GT is HID xenon, at least that was one of the differences in Gen 1 MS3 cars.
 Old 02-02-2020, 02:20 PM   #4
Tres3's Avatar
Also, 3 or 6?
_____________
The Following User Says Thank You to Tres3 For This Useful Post:
MSMS3 (02-03-2020)
 Old 02-03-2020, 09:03 AM   #5
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
get 2 brand new bulb first as old bulbs gives less output and could be harder on the ballast start circuit...
then a ballast
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
MSMS3 (02-03-2020)
 Old 02-03-2020, 08:32 PM   #6
MSMS3's Avatar
Originally Posted by Tres3 View Post
Also, 3 or 6?
Maybe OP will tell us what car he has if we are to help him. MS3? Gen 1 or Gen2? Year model? Sport or GT or MS6?
 Old 02-03-2020, 09:48 PM   #7
Tres3's Avatar
I looked thru his other posts - '08 MS3, but no indication what trim.
OP?
_____________
 Old 02-04-2020, 06:07 AM   #8
Jeff23spl's Avatar
OP?
i did the same but then, figured out there is 2 different person with same question.
Wife drive 2010 CX7
 Old 02-05-2020, 09:35 PM   #9
Roman-dude's Avatar
Apologies for the delayed response - somehow did not get the email notifications.
To the point - the car is 08 MS3 with a GT trim (HID lights).
Interestingly, the headlight started to come on more often - if I turn the switch several times, fair odds it would come on and stay for a bit. Obviously, this is not sustainable. Thinking of picking up a ballast that I could return just so that I would have it on hand in case it's not the bulb (and to avoid having to remove the bumper twice).
thanks again.
 Old 02-05-2020, 10:53 PM   #10
Tres3's Avatar
OEM ballast from Amazon. Fully returnable.Ask me how I know.
_____________
 Old 02-06-2020, 08:34 AM   #11
Roman-dude's Avatar
thanks. Hope Mazda3 HID is the same as MS3 HID.
 Old 02-06-2020, 03:04 PM   #12
Jeff23spl's Avatar
i was able to replace bulb without removing the bumper cover but needed for the ballast....
Wife drive 2010 CX7
 Old 02-06-2020, 06:59 PM   #13
Tres3's Avatar
Oh, yes. Bumper can stay on for bulbs, as long as your hands are thin and wrists are flexible.
_____________
 Old 02-06-2020, 08:19 PM   #14
Roman-dude's Avatar
I cant see how once can do it for the low HID beams. The bulb can't even come out of the housing because it's blocked by the fuse box.
 Old 02-06-2020, 09:42 PM   #15
Tres3's Avatar
Oh yeah, I forgot is a 3. On a 6 it's tight, but doable.
_____________
 Old 02-07-2020, 11:28 AM   #16
Jeff23spl's Avatar
was ok for my speed6 d2s and i had h11 socket on the speed3 converted to hid...maybe it is harder with d2s...but i also have tiny hands...
Wife drive 2010 CX7
HID ballast/bulb install tips? SkippyScallop MazdaSpeed 3 - How-To's 0 10-12-2016 07:40 AM
Headlight Bulb Tiner Mazdaspeed3/6 General Discussion 8 07-26-2015 08:26 PM
Why is my low beam a 9003 bulb? kylejenson MazdaSpeed 3/6 - Car Audio & Electronics 8 06-24-2014 11:31 PM
low-beam bulb burned out bzwyatt CX-7 > General Lounge + New Member Welcome 14 06-05-2011 09:47 PM
Headlight out... it's not the bulb Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 02-11-2009 12:57 AM
Page generated in 0.35548 seconds with 23 queries
