  • 1 Post By mikelevi
 Old 01-31-2012, 05:47 PM   #1
Cameron Letcher's Avatar
Posts: 311   (View Stats)
Cameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the worldCameron Letcher is the leader of the world
Default M2 Downpipe V-band gasket
Does anybody know where to get a new 3in v-band gasket? I was on Google for like an hour, and I've had no luck. Any help to point me in the correct direction would be greatly appreciated.
Cobb AP, Cobb intake, Cobb TIP, Cobb shift weight, KMD internals, TWM stage II shifter, DNP manifold, BNR stage III, M2 performance DP, Grimmspeed ECBS, Sure rear diff mount, Sure rear eng mount, Street unit TMIC, PTP injector seals, Mazdaspeed springs.
"Verrà la morte e avrà i tuoi occhi. (Death will come and it will have your eyes.)"
— Cesare Pavese
Cameron Letcher is offline   Reply With Quote
 Old 01-31-2012, 05:50 PM   #2
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Audi Turbo Kits | VW Turbo Kits | Integrated Engineering
Skreets be calling...
 Old 01-31-2012, 05:57 PM   #3
Karmat's Avatar
Posts: 1,179   (View Stats)
I forgot who but someone was saying you don't need to use a gasket in a v-band clamp thread somewhere.
I'm going to be buying a new clamp and replacing it wondering if I need to get a new gasket too.
2002 Corvette Z06 (Black)
 Old 01-31-2012, 07:10 PM   #4
Thanks for the link Snail. @Karmat I just used the gasket because it came with one, but I'm gonna be buying a new clamp as well.
— Cesare Pavese
 Old 01-31-2012, 08:47 PM   #5
I would think you would need one because solid metal on solid metal won't seal properly and leak and since it's pre-o2 sensor prolly throw off a tune...just saying in your response to what someelse said is all.
 Old 02-01-2012, 07:26 AM   #6
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
That whole business was in this thread-
DIY DP Gasket (M2 DP)
340hp / 371tq
 Old 02-01-2012, 08:39 AM   #7
mikelevi's Avatar
Posts: 362   (View Stats)
mikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the worldmikelevi is the leader of the world
Just an update since I was the OP of that thread. After I made the DIY Gasket, I purchased a really solid new 3" V Band clamp from Amazon. When changing clamps the Gasket I made did the same thing, burned through on one side. Its because the V Band clamp that comes with the M2 sucks big floppy donkey dick. I didnt even bother making a new gasket for this new V Band clamps. You could tell that it is much better, and I dont believe this one will need a gasket.
TiGraySpeed6 likes this.
mikelevi is offline   Reply With Quote
 Old 02-01-2018, 06:31 AM   #8
GroceryGtr's Avatar
Posts: 472   (View Stats)
old ass thread, but wanted to update it as it came up on a recent thread I replied to and figured someone might reference this one.
the reason the ebay dps come with a gasket is because the majority use the old school flat/universal vband flanges instead of the male/female specific flanges. The male/female flanges have a lip that fits inside the other end making for a leak proof fit eliminating the need for a gasket. The cheapy ebay versions are just flat surfaces that mate together, no lip, hence the need for a gasket. So its not necessarily the cheap vband clamp(dont get me wrong I would still replaced it asap), but rather the flange style that causes most of the leaking issues.
downpipe gasket question phillyb MazdaSpeed 3/6 - Turbo Induction 24 02-15-2013 12:32 PM
atp stock to v-band austin102085 MazdaSpeed 3/6 - Turbo Induction 2 01-07-2010 09:20 PM
Page generated in 0.28937 seconds with 25 queries
