 Old 11-08-2018, 08:12 PM   #1
Wing7991's Avatar
Posts: 2   (View Stats)
Wing7991 is an unknown quantity at this point
Default Manual shift cables slipping out of bracket-help
Recently I was driving and when I tried to shift, I felt the cable pop when I shifted to 2nd and I couldn't shift anymore. After limping home in 2nd gear, I found out that the plastic collar that fits into the bracket that holds the sheathing for the shift cables (under the intake airbox) slipped out of the bracket. Right now I just have some scrap wire holding it in place, but I would like something more permanent without having to by a ~$300 set of new shift cables. I am nervous that it might come loose again while I am driving. Any advice?
Wing7991 is offline   Reply With Quote
 Old 11-08-2018, 08:46 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
Got a pic? The ms6 has clips that hold the cable in the bracket.
 Old 11-08-2018, 08:51 PM   #3
Wing7991's Avatar
This is from google but it looks the same.
MS6 Broken shift cables (is it fixable??). RalliartRsX Mazdaspeed3/6 General Discussion 11 01-10-2016 11:56 AM
aftermarket shift cables 2008_zoomzoom Mazdaspeed3/6 General Discussion 18 10-13-2015 08:37 AM
Page generated in 0.24380 seconds with 21 queries
