(Thread Starter) | Not Ranked : 0 score Questions: #1 Is this pump ready to go or is it still in development. #2 What remains to be finished if it is in development. #3 Does this pump require a return style fuel system. #4 Will the factory intank pump be adequite to fuel this pump without cavitation. #5 Has or can the spring pressure for the dump valve be modified to boost rail pressures. #6 Has the dump valve been ported (or does it even need to be ported) to handle the increased flow so that the rail pressures dont spike. Thanks.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | jwdp54 (12-07-2009) |
(Thread Starter) | Not Ranked : 0 score Bump...
| Not Ranked : 0 score Rump...
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 53
| Not Ranked : 0 score Dump.... |
| The Following User Says Thank You to Deadman For This Useful Post: | 06Speed6 (12-11-2009) |
(Thread Starter) | Not Ranked : 0 score I think I am going to bump it every few days till they say something.
![]() Join Date: Sep 2009 Location: CREVE COUER, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 263
Groans: 75
| Not Ranked : 0 score sump... |
Groans: 60
| Not Ranked : 0 score I don't have his full pump, or even his internals, but I did let him modify my dump valve and rail feed line. My idle is about 200 psi higher than the highest idle pressure I've seen anyone else post.
| Not Ranked : 0 score How did he modify the dump valve? Ported? I guess i'm wondering how important porting the dump valve is. First of all, by dump valve, we're talking about the relief valve on the fuel rail, right? Does it require porting because the internal spill valves are "maxed out"? If it wasn't ported, wouldn't the ecu just command a higher spill valve duty cycle, and regulate pressure that way? Plus the dump valve, as i understand it, shouldn't be doing anything at all at idle and pressures under ~1900psi.
Groans: 60
__________________ Fully Built : Arias Pistons: Pauter Rods : ARP bolts: Ported Head: Cosworth BSD : Spec 3+ Clutch : Fidanza Flywheel : AWR Engine mounts 90duro : Custom TIP/Intake : Custom Blow Through 3.5" MAF : Custom FMIC : HKS SSQV VTA : Ported IM : Custom DP : Custom Exhaust : CPBoost Top Mount EM : Garrett GT3582R : PTP Turbo Blanket: Tial V44 EWG : Perrin EBCS : MrLilGuy/PTP HPFP : Ported fuel line : Ported Fuel Rail : Custom Ported Fuel Injectors : Kenny Bell Boost-a-Pump : HKS Twin Power DLI II : HKS M-Series Plugs : Cobb AP : AEM 3.5bar MAP :Koni Sport shocks : RPM Kspec Springs : TWM STS : TT Front Diff Mount : CPE Upper Diff Mount : Whiteline RSB : AWR Endlinks Last edited by SSinstaller; 12-11-2009 at 03:14 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following User Says Thank You to SSinstaller For This Useful Post: | djuosnteisn (12-11-2009) |
(Thread Starter) | Not Ranked : 0 score Yeah I wanna know what exactly he can do with that valve. John made some posts today but skipped my thread lol.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | bani (12-25-2009) |
| Banned ![]() Join Date: Mar 2008 Location: On this planet (Washington)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 436
| Not Ranked : 0 score The Maxed out is ready to sell, but they take a week to get done (don't keep one on the shelf). This will allow for a much higher idle pressure, more volume and a very stable high pressure levels. There is a ton of work that goes into making the pump "flow" and it allows your car to make better use of the volume. We have had several testers out there for a while (SSinstaller got the line a valve upgrade) and we will have some additional fuel upgrades getting added to the site here in a while (higher pressure relief valve on the rail anyone? (we are getting them made right now)). The MAXED out pump will be for those looking for 500 WHP from the DI supply only and not requiring additional "fuel supply". If we get someone to actually make HP like this one day it will be the perfect tester for that car. Let me know if you have any further questions and sorry about not getting back to you sooner speedy, we have been avoiding the site lately (obvious reasons). Thanks.
2. the dump valve in the rail 3. No, but is sure would help to have twin pumps feeding it or a bosch 055 inline 4. yes, up to around 485 hp, but this is still to be determined if the HPFP needs anymore intank pump. The intank can flow more than enough fuel at 40 psi to supply a 500 HP motor, the HPFP builds the pressure to feed the motor. (I could go on all day about our new findings with this, but I need to get more testing done). 5. Yes, but its easier to replace it (4 weeks and we should have something for you to install on your rail). 6. Yes and no, still have to see what we can get done for this application.
Its very important, the factory hole is a joke even if your running 2200 psi. Yes, and no. The factory PCM can only go so far to control pressure, this is where the mods allow you to run more fuel with out the PCM controlling it (PCM thinks that your still feeding it xx volume, when in reality is xxx in volume). Wrong valve, but we have new ones on the way.
. Last edited by ptperformance; 12-11-2009 at 07:05 PM. Reason: MSF Database - Automerged Doublepost | ||||
| The Following User Says Thank You to ptperformance For This Useful Post: | 06Speed6 (12-12-2009) |
![]() If you need a beta tester, i'm in a great position to help! PM me!
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| Not Ranked : 0 score Will do, we have been working on getting this addressed for over a year now. We just found a supplier that can make them for us. If Cobb or CPE can address the control issues the pump, the valve will be needed for addtional fuel control. 2250 psi is where we decided to start with and we can continue to raise it from there. |
| The Following 2 Users Say Thank You to ptperformance For This Useful Post: | 06Speed6 (12-12-2009), djuosnteisn (12-11-2009) |
| Not Ranked : 0 score Some of us have already been addressing the issue , no need to wait for cobb or cpe. I can run upto 2100ish psi (or more, i need to verify exactly how high the ecu will meter rail pressure, and eventually i'll be able to measure exactly how high our rail pressure maxes out at.)Not sure if you've seen our thread on it, but here it is: How to scale the HPFP pressure sensor
| The Following User Says Thank You to djuosnteisn For This Useful Post: | bani (01-11-2010) |
The #1 problem your going to run into with the higher pressure is the hard line coming off the pump starts to leak. Been there done that. We also blew a rail apart when we blocked the dump valve and then started to mess with the pump control. This is why they have a dump valve on the rail. The pump can generate upwards of 4000 psi (spike pressure), I know this because I destroyed an $1100 pressure transducer when the rail blew apart. We couldn't figure out the control valve and that is when I started to get on Cobb's ass about finding the table so we could control this part of the pump. I would like to give a hand with your project but since Lex seems to have an issue with me and my products I will elect to stay out of that thread for now. Don't need anymore stress over the holidays. | |
| The Following 3 Users Say Thank You to ptperformance For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Sweet, ill probably pick up one of your big ass CDFPs next weekend then. Is there a core charge? I have two spare rails and dump valves...
| Rattner recounts auto bailout, was "shocked" and "stunned" at condition of GM, Chrysler | Haltech | Automotive News | 0 | 10-21-2009 01:50 PM |
| Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] | Haltech | Automotive News | 0 | 08-04-2009 09:40 AM |
| Review: 2009 Audi A6 3.0T suits high-speed cruising to a "T" - or is that an "S"? | Haltech | Automotive News | 0 | 07-01-2009 10:30 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
