Like Tree5Likes
  • 2 Post By JakeMS3
  • 1 Post By mglax36
  • 1 Post By Varomnia
  • 1 Post By JakeMS3
 Old 08-30-2017, 12:36 PM   #1
mglax36's Avatar
Posts: 6   (View Stats)
mglax36 has a little shameless behaviour in the past
Default Mazda 3 motor 2.3 into a mazdaspeed3
I blew my speed3 motor such a sad day I was curious if it was possible or if anyone tried to swap the non turbo 2.3 into the speed3. I'm looking to get back on the road again any advice would be greatly appreciated! Thanks
Sent from my SM-G955U using Tapatalk
mglax36 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to mglax36 For This Un-useful Post:
Thepedigree13 (08-31-2017), Thor Hammer (08-30-2017)
 Old 08-30-2017, 12:42 PM   #2
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
I assure you, no one on THIS forum has ever, or would ever try and do that.
Sandman978 and lwomario like this.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 08-30-2017, 02:05 PM   #3
Bexar's Avatar
Posts: 195   (View Stats)
Bexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to beholdBexar is a splendid one to behold
Groaned at 18 Times in 8 Posts
Not uncommon in the honda world 'cause it's ez
On this car I would image it isn't that bad. But you would run into alot of issues with getting the harnesses to match etc. Just not worth the time involved I would think.
Cobb: APV3, shiftknob, TIP Corksport: intake, SSP, HPFP, strut tower bar, hoodscoop
JBR:
rear sway bar + big brackets, recirc hose, shifter bushings CP-E: stage 2 RMM GFB: blow off HKS: filter
To install: downpipe, Damond EGR delete
Bexar is offline   Reply With Quote
 Old 08-31-2017, 10:41 AM   #4
JakeMS3's Avatar
This isn't the Honda world though is it.
2013 LSM w/tech
Cobb AP V3, CBE
DM OCC/TMM
Forge V2 BPV
Wilwood 6 pot BBK
 Old 08-31-2017, 12:50 PM   #5
Bexar's Avatar
That's not the point, the point is if these cars were easily swap able people would be doing it like they do Hondas....and they aren't, so it isn't easy
JBR:
The Following User Says NO Thank You to Bexar For This Un-useful Post:
 Old 08-31-2017, 04:18 PM   #6
JakeMS3's Avatar
In the Honda world, guys are swapping k20/24 engines into chassis that have less powerful engines. I see what you're sayin about the possibilities in the Honda world, but the swaps they are performing are for more powerful engines. They don't buy a civic SI and say oh let me swap a D16y8 engine into my car. That's what this guy was doing, taking a great car with powerful engine and replacing it with a less powerful one.
Bexar likes this.
2013 LSM w/tech
Cobb AP V3, CBE
DM OCC/TMM
Forge V2 BPV
Wilwood 6 pot BBK
 Old 08-30-2017, 01:42 PM   #7
mglax36's Avatar
Ok that's great, but that doesn't answer if it was possible. Speed3 motors are expensive. I was hoping for a cheaper alternative to that because parting the car out is my last option and I don't really want to do that. Or if there's another motor that would fit?
lwomario likes this.
 Old 08-30-2017, 03:44 PM   #8
Djohns's Avatar
Posts: 3,944   (View Stats)
Sell your car to someone who won't ruin it.
2010 black mica speed3
Soon:built motor
The Following 3 Users Say Thank You to Djohns For This Useful Post:
mcburtonsoft (09-02-2017), Thepedigree13 (08-31-2017), Thor Hammer (08-30-2017)
 Old 08-30-2017, 04:49 PM   #9
mglax36's Avatar
I don't think anybody goes out to intentionally ruin their car.
Originally Posted by Varomnia View Post
How is $4,100 expensive? Just rebuild it yourself to factory specs and it's even cheaper, or build it for about the same cost, assuming you don't go power hungry and start adding cost to a bigger turbo and manifolds etc. MZR DISI Remanufactured Long Block Mazdaspeed 3 Mazdaspeed 6 2006-2013
If somehow that is too expensive, go buy yourself a beater until you are financially stable.
Already got the beater. 4,100 is expensive when you don't have it laying around. I'll see what I can find thanks for the advise
Last edited by mglax36; 08-30-2017 at 04:49 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-30-2017, 04:55 PM   #10
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
OK Malox or whatever your name is. Take yourself on over to Ebay, or even "gasp" craigslist and search for a good used motor. Just because you blew your shit up doesn't mean you have to buy a new one.
Do you even understand that the wiring harness, ECU, etc etc would need to be swapped? If not, please do as Djohns said and sell it to someone that wont ruin it.
 Old 08-30-2017, 07:28 PM   #11
Djohns's Avatar
If you want to drop in a NA motor you are going out to intentionally ruin your car.
Soon:built motor
 Old 08-30-2017, 04:02 PM   #12
Varomnia's Avatar
Posts: 459   (View Stats)
 Old 08-30-2017, 04:57 PM   #13
Varomnia's Avatar
The short answer is, don't swap the 2.3 non turbo engine into your speed. Anything is possible with enough sweat and tears, and this scenario will most assuredly be more tears with a side of sweat.
Since you already have a beater, and money is not all there. I would rather take the time, research, and build the engine either to factory specs, or go crazy with it. You'll learn a lot and have life experiences from it as well, going to meets saying "I built that, it's a part of me now"
Edit: Just don't. Many sweats and tears to be had. Build or sell.
HarambeSpeed3 likes this.
 Old 08-30-2017, 05:19 PM   #14
mglax36's Avatar
Thanks man I probably will try and go the new route. Appreciate the help.
 Old 08-30-2017, 06:15 PM   #15
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
If you are in a no snow state, and your car is in good condition. I will give you a running 3 for it. You wont need to swap anything and I will put the speed3 to a good use.
Of course you would need to post proper pics in the forums.
The Following 3 Users Say Thank You to stockms3 For This Useful Post:
Djohns (08-30-2017), thatguy0o0 (08-31-2017), Thepedigree13 (08-31-2017)
 Old 08-30-2017, 07:20 PM   #16
Djohns's Avatar
Fuck yea we bout to build that shit?
Soon:built motor
 Old 08-30-2017, 07:45 PM   #17
stockms3's Avatar
Groans: 74
Yep
BTW did you ever install the 6 puck clutch? I need it for s4.
Page generated in 0.38225 seconds with 26 queries
