  • 1 Post By KiwiFlavor
 Old 03-02-2018, 12:48 AM   #1
KooshaS's Avatar
Posts: 24   (View Stats)
KooshaS is on a distinguished road
Groaned at 6 Times in 3 Posts
Default Mazdaspeed 3 BCS broke help!
Hey guys I recently went to intall a cobb turbo inlet pipe and when i went to connect the little vacuum line to the nipple of the TIP, the vacuum line broke easily and took a little chunk of the nipple of the boost control solenoid. I did my best to put back on and when i started it up and drove around, I couldn't get more than 11 psi of boost and i usually get around 15-16 psi. So I took the little vacuum line off completely and it went back up to 15-16 psi. I was wondering is it REALLY necessary to replace the BSC because I'm not getting too much boost and my fuel pressure and ATF ratio is good too. I just have a Cobb TIP, Cobb intake, autotech hpfp, and a stage 1 map from my accessport. I don't plan on upgrading my turbo and I heard some people driving more than 20k miles with no vacuum line to the BSC and having no problems. Is it really necessary to replace it?
KooshaS is offline   Reply With Quote
 Old 03-02-2018, 03:48 AM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I'm confused. You broke the EBCS nipple for the bleed line to your TIP and got 11psi? Then you remove that hose...which is essentially the same thing, and now you get 15-16....?
Broken, removed, or whatever of the bleed line will maintain proper boost control, but your fuel trims will be fucked.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
KiwiFlavor (03-02-2018)
 Old 03-02-2018, 04:54 AM   #3
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
In other words.. Yes that nipple is important. Every nipple is important.
danb likes this.
2012 NASA Spaceship Gray MS3
Db09ms3 (03-02-2018), Thor Hammer (03-02-2018)
 Old 03-02-2018, 06:06 AM   #4
KooshaS's Avatar
Thank you! I'm a little short financially so would it be fine to drive it for a while before replacing the BSC?
 Old 03-02-2018, 06:44 AM   #5
Fstrnyou's Avatar
In the other thread, you said the nipples are fine.
Low Boost Pressure
Other rides:
History:
 Old 03-02-2018, 06:58 AM   #6
KiwiFlavor's Avatar
Is it the line or is it the nipples?
Know that if your EBCS nipple breaks, you can cause overboost.
 Old 03-02-2018, 08:25 AM   #7
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
Getting suspicious about this one....
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 03-02-2018, 09:12 AM   #8
Fstrnyou's Avatar
Stock EBCS in this case:
Broken source line will overboost.
A broken bleed line will boost normal.
Other rides:
History:
 Old 03-02-2018, 09:59 AM   #9
KooshaS's Avatar
Sorry guys im a mess. I thought it was just the line at first but i checked it out and it was the nipple of the BCS too so I made a new post. But yes a little piece of the nipple of the BCS broke off and i tried to put the line back in and and i dont know how but i couldnt get more than 11psi of boost. When i took the line to the BCS completely off, then it went back up to normal psi around 15-16psi
 Old 03-02-2018, 10:29 AM   #10
KooshaS's Avatar
And by fuel trims you mean the car running rich or lean right?
 Old 03-02-2018, 11:43 AM   #11
Fstrnyou's Avatar
Yes.
Other rides:
History:
 Old 03-02-2018, 12:04 PM   #12
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Come on noob. You don't need to make a new post when something in your original post about the same subject changes. Dude.
I have a good used EBCS if you want it, no charge. PM me.
All the nipples...
 Old 03-02-2018, 12:10 PM   #13
Fstrnyou's Avatar
You have any extra nipples?
Me love you long time!
Other rides:
History:
 Old 03-02-2018, 12:29 PM   #14
Groans: 211
 Old 03-06-2018, 09:39 AM   #15
KiwiFlavor's Avatar
How much for these shipped? PM me.
Thor Hammer (03-06-2018)
 Old 03-06-2018, 10:06 AM   #16
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
i'm in for the nipple thread!
op, be carefull, breaking nipple may get costly!
If it is really the discharge from EBCS to TIH, it isn't that bad to drive few days without it. you have to temporary plug the TIH hole to avoid a leak at iddle for that side. And that little air wasted by the EBcS under full boost may not be a huge thing to drive your fuel trim crazy.
If it is any other connections between turbo and WG, then, you can overboost and break the engine....
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 03-07-2018, 01:14 PM   #17
MSMS3's Avatar
Posts: 2,826   (View Stats)
OP, take up the offer for the free EBCS. Just be careful or you will break one off again. It is a common issue with many, many threads and posts here you might have found had you done a search.
The permanent fix is something like the Grimmspead EBCS. It is a drop in replacement that the OEM wire plug will fit. Its nipples are brass. Will not break. I like hard nipples.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
Db09ms3 (03-07-2018), KiwiFlavor (03-09-2018), Thor Hammer (03-07-2018)
Well I broke her MortalMechanica Mazdaspeed3/6 General Discussion 7 06-18-2015 10:34 PM
This broke mazdaspeeding Mazdaspeed3/6 General Discussion 10 01-04-2013 05:47 PM
HELP! i broke it TheNewGuy MazdaSpeed 6 - Engine, Transmission & Driveline 1 02-26-2010 06:49 PM
Page generated in 0.35967 seconds with 27 queries
