  • 1 Post By sj9ers
 Old 09-03-2016, 10:41 PM   #1
sj9ers's Avatar
Posts: 29   (View Stats)
sj9ers will become famous soon enough
Default MS3 engine into MS6
I'm going to be swapping an MS3 engine from my totaled 08 MS3 into a 2006 Speed 6 that needs a new motor. My MS3 motor has 133k but was running fine and I just did the VVT and timing chain replacement in April so that is sorted. I have a couple questions below. Keep in mind this has to be my daily so no mods right now but I'm planning to keep the pulled MS6 motor and rebuild that plus mods.
1) Anything I should do to the motor while its out before putting into the MS6?
2) Anything need to be swapped from the MS6 motor to the MS3 or is it straight drop in?
3) Maintenance that should be done in the MS6 engine bay when everything is out and easily accessible tranny/trasnfer case etc?
Thanks
f15ms6 likes this.
sj9ers is offline   Reply With Quote
 Old 09-04-2016, 06:36 PM   #2
f15ms6's Avatar
Posts: 1,546   (View Stats)
f15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the worldf15ms6 is the leader of the world
Great plans, since you got done the vvt.. the only thing I could suggest is to do the rear main seal and a clutch/flywheel kit
Sent from my SM-N930T using Tapatalk
2006 MS6 GT - Titanium Silver - #05750 -Cobb AP V2 - AT HPFP - 3" JBR Full Intake-
FidanzdaFlywheel - AWR Trilogy - Techna-Fit Brakes & Clutch SSL - Turbo XS Test Pipe - Maganaflow Catback
99 Civic Dx 5spd - DD/Backup Car
f15ms6 is offline   Reply With Quote
Loud engine ticking on a built engine I_AINT_RICE MazdaSpeed 6 - Engine, Transmission & Driveline 112 08-10-2016 07:35 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 1 04-13-2012 09:13 PM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Pulsar Spark Plug Replacement, Pinging Engine, Jeep Liberty Engine Stalls, Windows Are Stuck, Blower Motor Runs On Low O Haltech Automotive News 0 07-10-2008 11:10 AM
Page generated in 0.23837 seconds with 21 queries
